#21
george writes:
And as to 'situational awareness' there's an extremely large blind spot in the modern sailplane right under the nose A Cirrus isn't a sailplane. And a pilot with a blind spot needs to fly in such a way that he makes allowances for his inability to see in that blind spot. |
Mike Ash writes:
It's trivial to imagine many other plausible explanations. The others are not LIKELY, but there are tons of scenarios which are plausible. Such as? If they are not likely, why bother to imagine them? The purpose of an accident investigation is to find the most probable cause for an accident, not to find alternative but unlikely explanations that exonerate the pilot. |
Do you mind helping me on the gramma here, Bug Dout... I'm not sure how to read this in the correct context?? Thanks Loek "Bug Dout" schreef in bericht ... "John Ward" writes: Don't forget that Loek is a former F-16 pilot He's a current ass. |
#24
In rec.aviation.piloting Mxsmanic wrote:
george writes: And as to 'situational awareness' there's an extremely large blind spot in the modern sailplane right under the nose A Cirrus isn't a sailplane. And a pilot with a blind spot needs to fly in such a way that he makes allowances for his inability to see in that blind spot. All real airplanes have a large blind spot through an arc that starts at the nose, follows the fuselage around to the tail, and continues over the airplane to the rearmost window or top of the windscreen depending on model. -- Jim Pennino Remove .spam.sux to reply. |
#25
Mxsmanic wrote: Mike Ash writes: It's trivial to imagine many other plausible explanations. The others are not LIKELY, but there are tons of scenarios which are plausible. Such as? Such as, Cirrus pilot had a heart attack thirty seconds before, Cirrus had an engine failure, Cirrus hit large bird whose entrails covered the forward view, etc. If they are not likely, why bother to imagine them? The purpose of an accident investigation is to find the most probable cause for an accident, not to find alternative but unlikely explanations that exonerate the pilot. You said "plausible", not "relevant to the purpose of an accident investigation". Nice to see that you're still twisting out of every argument to make yourself look good, but you forgot to do your usual excessive snipping this time around. -- Mike Ash Radio Free Earth Broadcasting from our climate-controlled studios deep inside the Moon |
#26
#27
Mike Ash writes:
Such as, Cirrus pilot had a heart attack thirty seconds before, Cirrus had an engine failure, Cirrus hit large bird whose entrails covered the forward view, etc. Possible, but not very probable. Why look for highly improbable explanations when there is a very probable and plausible one (pilot error)? |
#28
"Mike Ash" wrote in message ... In article , Mxsmanic wrote: Mike Ash writes: It's trivial to imagine many other plausible explanations. The others are not LIKELY, but there are tons of scenarios which are plausible. Such as? Such as, Cirrus pilot had a heart attack thirty seconds before, Cirrus had an engine failure, Cirrus hit large bird whose entrails covered the forward view, etc. If they are not likely, why bother to imagine them? The purpose of an accident investigation is to find the most probable cause for an accident, not to find alternative but unlikely explanations that exonerate the pilot. You said "plausible", not "relevant to the purpose of an accident investigation". Nice to see that you're still twisting out of every argument to make yourself look good, but you forgot to do your usual excessive snipping this time around. -- Mike Ash Radio Free Earth Broadcasting from our climate-controlled studios deep inside the Moon Mike, Please don't feed the trolls. It is similar to mud wrestling with pigs. Real pilots accept that it is better to avoid bad weather rather than attempt to change it. Happy landings, |
#29
writes: All real airplanes have a large blind spot through an arc that starts at the nose, follows the fuselage around to the tail, and continues over the airplane to the rearmost window or top of the windscreen depending on model. So? So read your previous statement. -- Jim Pennino Remove .spam.sux to reply. |
#30
On Feb 9, 7:34*pm, Mxsmanic wrote:
george writes: And as to 'situational awareness' there's an extremely large blind spot in the modern sailplane right under the nose A Cirrus isn't a sailplane. And a pilot with a blind spot needs to fly in such a way that he makes allowances for his inability to see in that blind spot. |
| Ohio midair crash kills 3 | Larry Dighera | Piloting | 33 | May 21st 07 12:38 PM |
| Cirrus crash in NYC | SAM 303a | Soaring | 18 | October 16th 06 04:14 PM |
| I think I know why so many Cirrus' crash | Ron Lee | Piloting | 103 | January 29th 06 06:32 AM |
| Another Cirrus crash | James L. Freeman | Piloting | 42 | April 25th 04 12:21 AM |
