....here are your wierd questions of the week that are the result of
several bored people talking about building airplanes: Can a thin foil tape be fastened to the front of a wooden spar to act as a VHF antenna? The antenna would be encapsulated in several layers of epoxy or spar varnish and would not be penetrated by rib nails (wood ribs) or compression member bolts. The leading edge would be composed of wood ply. Can a steel wingtip bow in a rag and wood wing also be used as an antenna? Thanks, Bob1234 |
On Feb 9, 7:18*am, bob1234 wrote:
...here are your wierd questions of the week that are the result of several bored people talking about building airplanes: Can a thin foil tape be fastened to the front of a wooden spar to act as a VHF antenna? *The antenna would be encapsulated in several layers of epoxy or spar varnish and would not be penetrated by rib nails (wood ribs) or compression member bolts. *The leading edge would be composed of wood ply. Yes, in fact Jim Weir taught Bellanca how to do this on Vikings years ago. You need a some RF baluns, but the composite antenna kit from RST engineering has everything you need. You can do VOR antennas too. Can a steel wingtip bow in a rag and wood wing also be used as an antenna? Probably not very well. It's oriented the wrong way, and tuning it would be a PITA, if it's possible at all. Thanks, Bob1234 |
On Tue, 9 Feb 2010 07:18:59 -0800 (PST), bob1234
wrote: ...here are your wierd questions of the week that are the result of several bored people talking about building airplanes: Can a thin foil tape be fastened to the front of a wooden spar to act as a VHF antenna? The antenna would be encapsulated in several layers of epoxy or spar varnish and would not be penetrated by rib nails (wood ribs) or compression member bolts. The leading edge would be composed of wood ply. We've been doing foil antennas in plastic airplanes for about thirty years and it seems to work just fine. The only thing you want to watch out for is keeping relatively large (either in area or length) pieces of metal away from the outer halves of the antenna "ears". Things like flying wires and control cables will drive it nuts. You also need to feed a balanced dipole antenna with a balun (BALanced to UNbalanced) between the antenna ears and the coax. Can a steel wingtip bow in a rag and wood wing also be used as an antenna? Sort of. As an antenna for an FM radio it will work just fine. However, as a tuned antenna, the odds of it being just the right length are somewhere around the odds of winning an argument with an FAA inspector. Jim |
| Thread Tools | |
| Display Modes | |
| antenna | et | Home Built | 7 | June 29th 08 05:00 PM |
| GPS Antenna | 150flivver | Owning | 14 | December 11th 05 06:38 AM |
| Antenna questions | Steve Ruse | Home Built | 10 | January 27th 05 03:30 AM |
| Mig-29 questions & general aviation questions 2003 | Steven | Military Aviation | 1 | October 20th 03 07:06 AM |
| Seven Questions For Michael Moore from a Blogger (was Questions for Mr. Bush, from Michael Moore) | Jim Yanik | Military Aviation | 2 | October 9th 03 10:36 PM |
