			#21
Darryl Ramm wrote:
	If the threat aircraft you are worried about are on flight following (i.e. they have a transponder and can be seen on radar by ATC and have bothered to actually contact ATC for flight following) then by definition you are both likely to be in radar coverage and ATC should be able to provide traffic advisories under flight following. The above phrase "should be able to" is correct. ATC in the U.S. is only required to provide VFR traffic advisories on a "workload permitting" basis. If the controller has his hands full with IFR traffic, you lose. Remember that lots of people file IFR on perfectly good VFR days. Tony  |
Hagbard Celine wrote:
	When it came to the battery part of the article there was still nothing on an specific NiMH or LiLon batteries. I was wondering if anyone has tried either of the batteries from this company: http://www.atsipowermanagement.co.uk/lynx.html 10 A/H in a PS1270 size would be nice if it works. It looks like it would be a good choice, but I was unable to find a supplier or cost. You would have to buy it's charger, also, so the total cost for this "aviation" battery might be breathtaking. Let us know if you do find a supplier. It still might be a good option for some people, even if it is costly. If you use a Trig TT21, the power drain should be low enough that a 4 to 5 ah battery would be adequate - not ideal, but adequate for 8-10 hour flights in cold weather. That size is small and light enough, almost everyone should be able to mount a battery just for the transponder, if needed. Pilot reports on the Trig power consumption, anyone? On Page 15 of the article, I detail why I do not recommend Li batteries for gliders. Here's what I say: " IF you can find a 12 to 14 volt, commercially produced lithium battery pack, AND rated for operation to 18,000’ (or your highest operating altitude) AND with a matching charger, THEN you might consider using it. I couldn’t find any that met all these conditions (Dec. 2007), the best matches I could find cost several hundred dollars, and they wouldn’t fit a standard glider battery mounting." If you use a battery ONLY for the Trig TT21, you don't need to have a 12 volt battery. It could be up to 30 volts. That relaxed voltage specification might make it easier to find a suitable nimh or Li battery. Still, the standard lead acid battery works well, it's cheap, it's easy to charge, and it's safe. The weight isn't really an issue in most cases, given the 500+ pound weight of a glider. -- Eric Greenwell - Washington State, USA (netto to net to email me) - "Transponders in Sailplanes - Jan/2010" also ADS-B, PCAS, Flarm tinyurl.com/yg76qo9 - "A Guide to Self-launching Sailplane Operation Mar/2004" Much of what you need to know tinyurl.com/yfs7tnz  |
In response to the questions about batteries and couple outdated remarks
	Paul Remde caught, there is a new update "B" available from: * http://tinyurl.com/ylbu7a9 *Besides the updates, it now uses vertical lines to the left of any paragraph with significant changes to make it easier to spot them. It will also be on the soaringsafety.org website as soon as they can update it (might be a few days) Eric Greenwell wrote: This article, originally in Soaring (Feb 2002) was updated recently to include information on the Trig TT21 transponder. -- Eric Greenwell - Washington State, USA (netto to net to email me) - "Transponders in Sailplanes 2010B" also ADS-B, PCAS, Flarm *http://tinyurl.com/ylbu7a9* - "A Guide to Self-launching Sailplane Operation Mar/2004" Much of what you need to know tinyurl.com/yfs7tnz  |
			#24
On 2/12/2010 12:18 PM, Frank Whiteley wrote:
	On Feb 12, 8:10 am, wrote: Somehow we all need to get transponders in our gliders. Bob Lobby for stimulus money. We don't need money. What is needed is for the FAA to permit the commercialization of MITRE's low cost ADS-B transceiver. We are making SLOW progress on that front. The FAA & SSA are going to do a demonstration project this summer in the DC area. If we can get ADS-B transceivers to be available at the same price point as FLARM in Europe, we will see a similar explosion in deployment rates, which will make soaring (and GA) a much safer environment. -- Mike Schumann  |
| New Trig TT22 Transponder | Paul Remde | Soaring | 1 | January 14th 10 08:27 PM |
| TRIG TT21NOW IN STOCK | Tim Mara[_2_] | Soaring | 5 | September 29th 09 11:29 PM |
| Trig TT21 Transponder receives FAA TSO approval | Paul Remde | Soaring | 12 | September 19th 09 03:47 PM |
| Trig TT21 Transponder Thoughts? | jcarlyle | Soaring | 16 | June 23rd 09 05:38 PM |
| Seeking KT-79 transponder install/operational info | [email protected] | Owning | 7 | July 26th 06 02:11 PM |
