If all midair collisions were eliminated...
Old February 15th 10, 09:26 AM posted to rec.aviation.homebuilt,rec.aviation.piloting,rec.aviation.soaring
Darryl Ramm
Default If all midair collisions were eliminated...
On Feb 14, 10:12*pm, brian whatcott wrote:
Darryl Ramm wrote:
/snip/
And I forgot to mention Mode S TIS (which is not the same as ADS-B TIS-
B). Which is SSR derived traffic position sent over Mode S to each TIS
capable aircraft. Only available where there is terminal radar with
TIS support. Area radar would update too slowly, so it's limited to
terminal radar coverage and then only if that terminal radar facility
has the extra smarts to do TIS. The TIS ground processor calculates
threats to each aircraft and uplinks that to that aircraft over Mode
S. Obviously the threat aircraft need to have Mode C or S transponders
and be within coverage of that terminal radar. /snip/
Darryl
Which reminds me: I fly out of a civil field in a notch of the zone
round a military base - where a digital radar upgrade has recently
appeared. * * I notice that with my mode C active, I seem to be able to
hear an interrogation as a click as well as see a visual interrogation
flash.
These days, I don't get a repetitive once a revolution style
interrogation, but rather a string of clicks when I am inbound (i.e a
threat to military types which do have squitter) in my headset tuned to
the CTAF
Brian W
The click is most likely your transponder replying to an interrogation
and likely just coupling though the avionics power supplies, but it
might also be RF coupling.
Also just FYI on interrogations, each click you hear is likely not a
single interrogation. For an radar/ATCRBS (I just wanted to throw in
another acronym) interrogator the beam will hit your transponder with
an alternating pattern of Mode A and Mode C interrogations at ~few
hundred Hz as the beam sweeps over your aircraft. The exact number and
pattern depends on the type of radar/ATCRBS system.
There is also a remote possibility that what you hear if it is
synchronous with a radar antenna rotation (not this case it seems) is
RF interference picked up from the high-power primary radar beam.
Which is much more powerful than the ATCRBS/transponder interrogator
and usually on a quite different frequency than the 1030MHz
interrogator - usually a few GHz and up. The 1030Mhz interrogator beam
is such low power it's not going to cause interference directly, only
by triggering your transponder to fire.
If you are hearing clicking of order once per second or so then it is
possibly TCAS (and/or TCAD) related. These do a clever Mode C
interrogation sequence (the "Whisper-Shout" sequence) at about 1 Hz.
Each TCAS equipped aircraft close enough will hit you independently
with interrogations each at about 1Hz (and technically each
interrogation may fire rapidly several times but you would only hear
one click).
Another possibility if this is only correlated to changes in military
ground infrastructure is that the higher frequency interrogations not
correlated with a radar rotation could be from ground based Mode C
interrogators that are part of a multilateration (MLAT) systems for
surface or airborne tracking. Maybe that got deployed with the new
radar (or maybe the new "digital radar" is an MLAT system).
And all of these interrogations help paint the position of transponder
equipped aircraft for those passive PCAS systems.
Darryl
  #102
Old February 15th 10, 11:23 PM posted to rec.aviation.homebuilt,rec.aviation.piloting,rec.aviation.soaring
Alan Baker
Mxsmanic wrote:
Jim Logajan writes:
If all GA midair collisions were eliminated, ~99% of GA aircraft fatalities
would still happen.
If all GA midair collisions were eliminated, 27 people would still be alive,
based on your own cited statistics. Is saving lives not a sufficient
justification for eliminating midair collisions? Is there are threshold of
deaths below which efforts to eliminate midair collisions are not justified?
What cost is there in attempting to eliminate midair collisions that offsets
the loss of life that they entail?
There is the very obvious cost of expending a n dollars to save one life
when spending it elsewhere would save more than one life.
Alan Baker
Vancouver, British Columbia
http://gallery.me.com/alangbaker/100008/DSCF0162/web.jpg
  #103
Old February 15th 10, 11:24 PM posted to rec.aviation.homebuilt,rec.aviation.piloting,rec.aviation.soaring
Alan Baker
Mxsmanic wrote:
Jim Logajan writes:
fatalities
would still happen.
alive,
justified?
offsets
If the US road speed limit were reduced from 70 to 65 mph, perhaps
30,000 lives would be saved annually. Isn't that worthwhile?
We have apparently decided NOT.
Because it's utter bull****.
Alan Baker
  #104
Old February 15th 10, 11:25 PM posted to rec.aviation.homebuilt,rec.aviation.piloting,rec.aviation.soaring
Alan Baker
John Smith wrote:
The total accident deaths per year in the US is only around 38,000.
Only?
One does have to consider how man person-hours are spent driving...
Alan Baker
  #105
Old February 15th 10, 11:45 PM posted to rec.aviation.homebuilt,rec.aviation.piloting,rec.aviation.soaring
John Smith
Am 16.02.10 00:25, schrieb Alan Baker:
Only?
No, one does not have to. 38,000 deaths are an awful lot, period.
  #106
Old February 15th 10, 11:53 PM posted to rec.aviation.homebuilt,rec.aviation.piloting,rec.aviation.soaring
Only?
Yes, one does have to if you want to talk about possible prevention.
If you just want to mourn the dead, then 1 death is too many.
Jim Pennino
Remove .spam.sux to reply.
  #107
Old February 16th 10, 12:10 AM posted to rec.aviation.piloting
John Smith
Only?
Somebody who uses the word "only" when he talks about 38,000 deaths is
an idiot, period. There's nothing to relativise here.
  #110
Old February 16th 10, 01:07 AM posted to rec.aviation.piloting
Only?
Of course there is, that is a death rate of about 0.01%, which is a
trivial rate.
And if you want to talk about possible prevention, you have to talk about
rates.
Jim Pennino
Mid Air Collisions Sukumar Kirloskar Soaring 2 July 3rd 08 02:42 PM
FAA Soaring Forecasts being eliminated? David Neptune Soaring 6 July 15th 06 05:47 AM
Kids and Aviation records. I thought these were supposed to be eliminated. Roger Halstead Piloting 2 September 27th 04 07:20 PM
Mid-Air Collisions JJ Sinclair Soaring 26 April 19th 04 08:52 AM
MID AIR COLLISIONS Vorsanger1 Soaring 2 April 16th 04 04:17 AM
