Transponder Clicking (was If all midair collisions were eliminated...)
Old February 24th 10, 02:30 PM posted to rec.aviation.homebuilt
Barnyard BOb
Default Transponder Clicking (was If all midair collisions were eliminated...)
On Mon, 15 Feb 2010 07:27:04 -0800, Ron Wanttaja
Which reminds me: I fly out of a civil field in a notch of the zone
round a military base - where a digital radar upgrade has recently
appeared. I notice that with my mode C active, I seem to be able to
hear an interrogation as a click as well as see a visual interrogation
flash.
These days, I don't get a repetitive once a revolution style
interrogation, but rather a string of clicks when I am inbound (i.e a
threat to military types which do have squitter) in my headset tuned to
the CTAF
The click is most likely your transponder replying to an interrogation
and likely just coupling though the avionics power supplies, but it
might also be RF coupling.
:0)
All the more reason to safeguard your head from "RF COUPLING".
You can thank Julian Huxley (1927) and Wikipedia for the following:
A tin foil hat is a piece of headgear made from one or more sheets of
aluminium foil or similar material. Alternatively it may be a
conventional hat lined with foil. Some people[who?] wear the hats in
the belief that they act to shield the brain from such influences as
electromagnetic fields, or against mind control and/or mind reading;
they also serve to attempt to limit the transmission of voices
directly into the brain.
Scientific basis
The notion that a tin foil hat can significantly reduce the intensity
of incident radio frequency radiation on the wearer's brain has some
scientific validity, as the effect of strong radio waves has been
documented for quite some time.[2] A well-constructed tin foil
enclosure would approximate a Faraday cage, reducing the amount of
(typically harmless) radiofrequency electromagnetic radiation inside.
A common high school physics demonstration involves placing an AM
radio on tin foil, and then covering the radio with a metal bucket.
This leads to a noticeable reduction in signal strength. The
efficiency of such an enclosure in blocking such radiation depends on
the thickness of the tin foil, as dictated by the skin depth, the
distance the radiation can propagate in a particular non-ideal
conductor. For half-millimetre-thick tin foil, radiation above about
20 kHz (i.e., including both AM and FM bands) would be partially
blocked, although tin foil is not sold in this thickness, and numerous
layers of tin foil would be required to sustain this effect
Old February 25th 10, 05:25 AM posted to rec.aviation.homebuilt
Morgans[_2_]
So that has been your problem all along? You have not been wearing your tin
hat, BoB?
It certainly would explain why you are able to correct "certain other"
people's spelling mistakes and such. You have had your brain hooked into
the machine world, and in your case, it must be hooked into a word
processor. ;-))
Jim in NC
Old March 2nd 10, 09:28 PM posted to rec.aviation.homebuilt
Barnyard BOb
On Thu, 25 Feb 2010 00:25:15 -0500, "Morgans"
hat, BoB?
processor. ;-))
No hat and no heart....
That B me, sir! )
~ Barnyard BOb ~
Con-'TIN'-uing towards 56 years of licensed power flight!
If all midair collisions were eliminated... Jim Logajan Piloting 138 February 19th 10 11:20 PM
FAA Soaring Forecasts being eliminated? David Neptune Soaring 6 July 15th 06 05:47 AM
clicking sound after failed start Matt Owning 4 November 2nd 05 12:36 AM
Kids and Aviation records. I thought these were supposed to be eliminated. Roger Halstead Piloting 2 September 27th 04 07:20 PM
When is just clicking PTT an acknowledgement? Ben Jackson Piloting 35 December 21st 03 09:18 AM
