Legal vs. practical cloud cover for VFR
Old February 26th 10, 01:00 PM posted to rec.aviation.student,rec.aviation.piloting
Mxsmanic
Default Legal vs. practical cloud cover for VFR
At what point does VFR become too troublesome to be practical, in terms of
cloud cover? VFR only requires that one stay a certain distance away from
clouds, but it doesn't impose any limit on the number or proximity of clouds
in the sky (unless they are so close together that one cannot maintain the
required clearance). Nevertheless, it seems to me that at some point the
clouds are so numerous and close together that flying VFR becomes more of an
irritation than a pleasure, with constant dodging of clouds and possibly
changes in altitude. It also seems that this would be a personal limit, since
it's not defined by regulations. So, what are your own limits for how much
cloud cover you'll tolerate before filing IFR or simply not flying VFR?
Old February 26th 10, 04:36 PM posted to rec.aviation.student,rec.aviation.piloting
Curt Johnson[_2_]
If you can't make a 180 and still maintaining clearance, the clouds are
too close together.
Curt
Old February 26th 10, 04:58 PM posted to rec.aviation.student,rec.aviation.piloting
Gene Seibel
cloud cover? *VFR only requires that one stay a certain distance away from
I've flown VFR only for over 30 years, and legal is generally
practical in my experience. Clouds are usually well layered and as
long as legal or personal ceiling and visibilities are met there's not
a problem. There can be a problem if terrain varies much along your
path and ceilings are low. Sometimes that makes it a bit difficult to
determine that it'll be OK along the entire route. One can fly in a
widely scattered layer and dodge clouds, but that's not usually
necessary because you can go above or below the layer.
Gene Seibel
Gene & Sue's Aeroplanes - http://pad39a.com/gene/planes.html
Because we fly, we envy no one.
Old February 27th 10, 02:13 PM posted to rec.aviation.student,rec.aviation.piloting
jan olieslagers[_2_]
Flying is an expensive hobby, to me at least. My flying must be real fun
to be worth its money, and that requires weather well above VFR minima.
Also, you should not consider one single aspect of the weather. The law
has no other option, of course, than defining minima for each weather
element, but I consider weather as a whole when deciding to fly or not.
Still, when I decide NOT to fly, it is mostly because either the
visibility is below legal minimum, or wind and/or turbulence are
stronger than I like.
My 0.02 euro!
Old February 27th 10, 10:24 PM posted to rec.aviation.student,rec.aviation.piloting
Dallas
in the sky
Not quite true.
The cloud ceiling is defined as the lowest cloud layer that is reported as
broken or overcast.
Broken is defined as 5/8 to 7/8 coverage.
So VFR does specify limits of cloud density.
Dallas
Old February 27th 10, 11:23 PM posted to rec.aviation.student,rec.aviation.piloting
Mark Hansen[_2_]
in the sky
Not quite true.
broken or overcast.
Well, that wasn't the point. Even if the sky was 7/8 covered with
clouds, you can legally fly VFR through a hole in the coverage,
provided you don't violate the cloud clearance and visibility minimums
for the area you are flying.
The ceiling doesn't really matter in this regard.
Old February 27th 10, 11:53 PM posted to rec.aviation.student,rec.aviation.piloting
Jim Logajan
terms of cloud cover?
Bows and flows of angel hair
And ice cream castles in the air
And feather canyons everywhere
I've looked at clouds that way
But now they only block visual flight
They rain and snow on everyone
So many things I would have done
But clouds got in my way
I've looked at clouds from both sides now
From up and down and still somehow
It's cloud's illusions I recall
I really don't know clouds at all
Old February 28th 10, 12:39 AM posted to rec.aviation.student,rec.aviation.piloting
Peter Dohm
"Mark Hansen" wrote in message
clouds
in the sky
Not quite true.
as
broken or overcast.
Ah yes, simple enough in an airplane, but very difficult in MSFS.
Peter :-))))
Lover of simple things
Old February 28th 10, 12:45 AM posted to rec.aviation.student,rec.aviation.piloting
Mark Hansen[_2_]
clouds
in the sky
Not quite true.
as
broken or overcast.
Peter :-))))
I think the OP is thinking of the clouds as though they were a bunch
of hot air balloons just floating around the sky which you just
navigate your way around as you fly. Although I agree this *can*
happen, I rarely see it that way in real life (at least at the
altitudes I fly).
Old February 28th 10, 01:25 AM posted to rec.aviation.student,rec.aviation.piloting
Jon Woellhaf
Mark Hansen wrote, "I think the OP is thinking of the clouds as though they
were a bunch of hot air balloons just floating around the sky which you just
navigate your way around as you fly. Although I agree this *can* happen,
I rarely see it that way in real life (at least at the altitudes I fly)."
I've flown (legally, while IFR) through canyons of fluffy white clouds, but
only a couple times. It's an experience I (and my wife, who was with me)
will never forget!
OT Cloud to cloud lightning - video [email protected] Piloting 0 August 4th 08 02:01 AM
OT Cloud to cloud lightning - video [email protected] Instrument Flight Rules 0 August 4th 08 02:01 AM
IFR Practical test requirements kevmor Instrument Flight Rules 13 January 25th 07 08:18 PM
Practical welding? mhorowit Home Built 21 August 23rd 05 05:33 AM
practical best range application? xerj Piloting 15 February 7th 05 12:48 AM
