On Mar 5, 10:04*pm, Hagbard Celine wrote:
" No "havoc" is created by two transponders sqawking 1200 near each other." Tell that to the Dutch who fly in the Schiphol area... Shiphol had a problem with the back-end processing and display of Mode S derived traffic data on their display screens. In hindsight this seems an awfully obvious thing they missed with Mode S transponder mandates. Some summary to the problem is at http://eurocontrol.int/msa/public/st...Procedure.html Transponders provide visibility for gliders to both ATC and airliner/ fast jets TCAS and are therefore a critical item anywhere we are mixing those types of aircraft. And I fail to see how a particular display capacity/planning problem at Shiphol is that relevant to any general idea of carriage of transponders. Darryl |
On Mar 5, 3:57*pm, JS wrote:
Forgive me. Most of my flying is in MOAs, so I treat it all as such. * This briefing was for flights in the R-2508 Complex, the collection of Restricted and Military airspace surrounding Edwards Air Force Base and China Lake Naval Air Station. It makes up a good percentage of the southern California task area, regularly used by gliders from Nevada and California. The complex extends from surface to unlimited. * Thinking of the alternative, I don't mind hearing ATC warning someone that there's a glider maneuvering at their altitude, 12:00, 5 miles. Had assumed that other than current draw there wasn't a down side to a certified transponder installation, but an alarm going off at ATC for no apparent reason is something to be aware of. Your mileage may vary. Jim * If you're unfamiliar with the R2508 Complex, and care to have a look...http://www.edwards.af.mil/r-2508.asp Jim I'm still completely missing the point of your post. If two gliders are squakwing 1200 they will set of a relatively low- intensity traffic warning. The controllers should be used to this happening a lot with GA and (for your area) glider traffic. If both aircraft are squawking 1200 the controllers likely can't even talk to the pilots involved. Is anybody suggesting they would rather not have transponders that enable them to "see" gliders and therefore be able to route military traffic around them? If either aircraft is squawking something other than 1200 then it is on a flight plan or flight following and the controller should want to know about the alert. If they don't I'd really like to know why. If a glider contacts approach and requests flight following or similar and they are flying in formation or close to other gliders it is common sense for them to alert the controller there are other gliders in the close proximity (whether they are transponder equipped or not). You should talk to the controllers about the procedures they want you to use in those circumstances. If you are in close truly close formation (which might happen in some buddy flying) ATC may prefer you to deactivate the transponder on all but one aircraft in the formation. This helps avoid false alerts and avoids the Mode-C synchronous garbing issue that Eric alluded to. The procedure is described in the AIM. This is not something that glider flights, even buddy fights, would normally do. But again if there are false alert issues with your local control facility talk to them about when, if ever, they would want you to use this. Darryl |
On Mar 6, 11:47 am, Darryl Ramm wrote:
If you are in close truly close formation (which might happen in some buddy flying) ATC may prefer you to deactivate the transponder on all but one aircraft in the formation. Correct, that is what was suggested by ATC... Especially if a glider has been issued a discrete code. If the glider is on the discrete code during tow, turn the transponder in the towplane to Standby until the glider releases. All but one glider in the thermal or group flight turns their transponder to SBY. (Think of what these standby transponders do for PCAS use.) The point of my initial post is that there is a lot more to using a transponder in an aircraft that is routinely maneuvered close to other aircraft than first meets the eye! And keep looking out the window. Jim |
On Mar 6, 4:32*pm, JS wrote:
On Mar 6, 11:47 am, Darryl Ramm wrote: If you are in close truly close formation (which might happen in some buddy flying) ATC may prefer you to deactivate the transponder on all but one aircraft in the formation. * Correct, that is what was suggested by ATC... Especially if a glider has been issued a discrete code. If the glider is on the discrete code during tow, turn the transponder in the towplane to Standby until the glider releases. All but one glider in the thermal or group flight turns their transponder to SBY. (Think of what these standby transponders do for PCAS use.) Jim Sorry but I'm not following the last part of the comment either about "standby transponders" or at least I am not follwoing if you are thinking this is a problem or not. Once off tow both transponders would be on and the PCAS system should operate normally. While on tow a PCAS unit like the Zaon MRX in the glider squawking standby might think the towplane's transponder is its own and supress the tow plane as a threat. I'd argue that is not a problem and actually what you want--you want the PCAS to suppress the alert and while on tow you know where the tow plane is (I hope!). And that allows any other threats coming close to be warned about. Experience from people who fly with a PCAS in their glider without a transponder (or transponder in standby) with a tow plane with a transponder would be interesting. I think it is absolutely the wrong advice to say that gliders should be turning off and on their transponders without coordinating this with ATC. That seriously cannot be what ATC wants? For example in discussions of this with Reno approach, they want this only for close formation flights (i.e not typical glider flights) and only when those flights have contacted Reno approach and advised that it is a flight of multiple aircraft with leader squawking. The advice to turn off transponders when in thermals just seems impractical and dangerous, let alone a violation of FARs. You want people to do this if the other gliders are squawking 1200 or if they are assigned a discrete code? How do you know they are on a discrete code or not? Who decides who turns off a transponder and who turn one on and when. Is this radio chatter going to happen over the approach frequency? If a tow plane contacts approach for flight following then they need to let approach know it is a tow/formation flight with glider squawking standby--so the controller is not surprised when the glider pops up on his radar. Pilots also should not be trying to docuble-guess the decorrelation capability of TCAS interrogators. i.e. Even with just Mode-C equipped threats a TCAS equipped aircraft can see multiple aircraft even if their signals overlap a fair amount. You don't want to be thinking you are turning off your tranpodner might be helping ATC and then make you invisible to TCAS that could otherwise "see" you. Especially since TCAS-II issues vertical resolution advisories there is a risk a TCAS- II could issue an RA that would fly the aircraft straight into you as it tries to avoid a gilder in the thermal that is above or below you with its transponder on. (I'm not talking about the case of a thermal stacked with many tens of gliders with Mode-C transponders, there have been some studies of the problem of transponder synchronous garbling in those cases). BTW if any of those gliders have a Mode-S transponder like the Trig TT-21 then this avoids the Mode-C synchronous garbling issues and TCAS and ATC are capable of unambiguously seeing a relatively large number of individual threats in the same proximity. Bottom line. I would hope people turn on the transponder and leave it on unless they are using flight following for a formation/tow flight and if so then talk to the local ATC facility about how they want to handle the radio procedures. I know there are battery concerns, but turning off for long periods to save battery power is different (but also a violation of FARs), and I'd hope with modern transponders this is really a not a requirement. Darryl |
On Mar 6, 6:31*am, brian whatcott wrote:
BT wrote: * /snip/ * "Transport" military aircraft may or may not have TCAS, it depends on * their vintage, and they do not have an air to air radar to "ping" a * transponder. * " Heavy Bomber" military aircraft may not have TCAS, it depends on their * vintage, and they do not have an air to air radar to "ping" a transponder. * /snip/ * BT "retired military aviator" and one time ATC controller. I know the C-5 has TCAS. It uses squitter mode and interrogates transponders. The KC-135 has TCAS. I am almost certain it too interrogates. * (I should know this, but I did not update the transponder model for the KC-135 simulators, and cannot recall. Military aircraft are subject to continuous performance updates.) Brian W All USAF C5 an KC-10 have TCAS-II/ETCAS (military variant). I occasionally get to share airspace with KC-10s out of Travis AFB and glad they have TCAS-II and I have a transponder (and I'm usually on flight following with Travis approach if close to Travis). I believe all KC-135s got TCAS-II/ETCAS in the Pacer/CRAG upgrade program starting back last decade. Maybe some initially got only TCAS- I. C-130s have TCAS. And so on. I think the general assumption today should be that military transport aircraft have TCAS-II. Outside tactical exercises I expect those TCAS systems to be operating. When operating normally all these system will interrogate mode C and S transponders independent of ground radar or other interrogators. Darryl |
bildan wrote:
On Mar 6, 8:01 am, "Wayne Paul" wrote: I find the assertion that military aircraft do not have transponders humorous. Wasn't it the military that developed the system back in WWII? "Transport" military aircraft may or may not have TCAS, it depends on their vintage, and they do not have an air to air radar to "ping" a transponder. " Heavy Bomber" military aircraft may not have TCAS, it depends on their vintage, and they do not have an air to air radar to "ping" a transponder. BT "retired military aviator" and one time ATC controller. I know the C-5 has TCAS. It uses squitter mode and interrogates transponders. The KC-135 has TCAS. I am almost certain it too interrogates. (I should know this, but I did not update the transponder model for the KC-135 simulators, and cannot recall. Military aircraft are subject to continuous performance updates.) Brian W You're lucky. I was on the heavy cruiser USS St. Paul watching when the missile cruiser USS Canberra blasted an AD5 Skyraider out of the sky with a missile because of an inoperative transponder. The 4-man A5 crew was lost. Back to the basic transponder discussion. It's obvious the US air traffic control system is based on a military command structure. All information is kicked up the chain of command for a decision while the ops people at the bottom wait for an answer. The oxymoron "Military Intelligence" applies. That's not the case in eastern Washington State, which has a lot of C17s running around. The tower at Grant County informs them of potential conflicts in their area, though nowadays, most/all have TCAS and aren't dependent on the tower for timely information. -- Eric Greenwell - Washington State, USA (netto to net to email me) |
I must have been hallucinating during the briefing at Joshua approach.
Time to give up. Jim |
On Mar 5, 9:41*pm, "BT" wrote:
As Jim said... but not entirely accurate. And a response by another responder, not entirely accurate. "Most" fighter type aircraft can interrogate Mode 3 transponders on their air to air search radars and get a return. "Most" fighter type aircraft do not have TCAS. Modern Aircraft might. "Transport" military aircraft may or may not have TCAS, it depends on their vintage, and they do not have an air to air radar to "ping" a transponder.. " Heavy Bomber" military aircraft may not have TCAS, it depends on their vintage, and they do not have an air to air radar to "ping" a transponder.. If a flight of 4 fighters (or more than one) is transitioning airspace outside of a MOA, ATC will have the wingmen, "Strangle the parrot", so everyone will only see one transponder return, not four and the ATC radar will not "go crazy with alerts". BT "retired military aviator" and one time ATC controller. Well, yes. A-10s, T-38s, T-45s don't have radars so can't interrogate (although the latter two may have TCAS - I would hope they do!). Early F-16s and F-18s didn't have interrogators, but all the later versions do, as do all F-15s, etc. While fighters do not have TCAS, I think a lot of trainers do, for obvious operational safety reasons. Plus, there is Link 16, which lets each fighter in a flight see what the rest is seeing, and what AWACS is seeing - another way to detect other aircraft. But that is just gravy - the important point here is that military aircraft operating in joint use airspace WILL have a transponder on - so flight following should work - talk to center if you are going through a MOA that is hot!! - and if all else fails and you see a problem developing in a MOA between gliders and military aircraft - call on Guard (121.5) and they will likely hear you - beats a midair anyday and you get to talk to your tax money at work, literally. Kirk "retired military aviator" and one time interrogator of civilian transponder traffic in MOAs from the pit of his F-4 (and that was 30 years ago!) |
On Mar 7, 10:57*am, JS wrote:
I must have been hallucinating during the briefing at Joshua approach. Time to give up. Jim Jim, I'd be really interested to hear what what is being said in the Joshua approach briefing. It could be a misunderstanding, or an actual lack of knowledge between agencies and users on each other's capabilities - not the first time that has happened. Has there been a reciprocal briefing of glider operations and capabilities to Center and AF personnel? I know when I've worked with the AF on similar issues in the Luke area (coordinating for regional contest, which would be transiting hot MOAs during the week), there were often misconceptions (!!) that had to be cleared up, on both sides. Cheers, Kirk 66 |
On Mar 6, 8:46*pm, Darryl Ramm wrote:
On Mar 6, 4:32*pm, JS wrote: On Mar 6, 11:47 am, Darryl Ramm wrote: If you are in close truly close formation (which might happen in some buddy flying) ATC may prefer you to deactivate the transponder on all but one aircraft in the formation. * Correct, that is what was suggested by ATC... Especially if a glider has been issued a discrete code. If the glider is on the discrete code during tow, turn the transponder in the towplane to Standby until the glider releases. All but one glider in the thermal or group flight turns their transponder to SBY. (Think of what these standby transponders do for PCAS use.) Jim Sorry but I'm not following the last part of the comment either about "standby transponders" or at least I am not follwoing if you are thinking this is a problem or not. Once off tow both transponders would be on and the PCAS system should operate normally. While on tow a PCAS unit like theZaonMRXin the glider squawking standby might think the towplane's transponder is its own and supress the tow plane as a threat. I'd argue that is not a *problem and actually what you want--you want the PCAS to suppress the alert and while on tow you know where the tow plane is (I hope!). And that allows any other threats coming close to be warned about. Experience from people who fly with a PCAS in their glider without a transponder (or transponder in standby) with a tow plane with a transponder would be interesting. I think it is absolutely the wrong advice to say that gliders should be turning off and on their transponders without coordinating this with ATC. That seriously cannot be what ATC wants? For example in discussions of this with Reno approach, they want this only for close formation flights (i.e not typical glider flights) and only when those flights have contacted Reno approach and advised that it is a flight of multiple aircraft with leader squawking. The advice to turn off transponders when in thermals just seems impractical and dangerous, let alone a violation of FARs. You want people to do this if the other gliders are squawking 1200 or if they are assigned a discrete code? How do you know they are on a discrete code or not? Who decides who turns off a transponder and who turn one on and when. Is this radio chatter going to happen over the approach frequency? If a tow plane contacts approach for flight following then they need to let approach know it is a tow/formation flight with glider squawking standby--so the controller is not surprised when the glider pops up on his radar. Pilots also should not be trying to docuble-guess the decorrelation capability of TCAS interrogators. i.e. Even with just Mode-C equipped threats a TCAS equipped aircraft can see multiple aircraft even if their signals overlap a fair amount. You don't want to be thinking you are turning off your tranpodner might be helping ATC and then make you invisible to TCAS that could otherwise "see" you. Especially since TCAS-II issues vertical resolution advisories there is a risk a TCAS- II could issue an RA that would fly the aircraft straight into you as it tries to avoid a gilder in the thermal that is above or below you with its transponder on. (I'm not talking about the case of a thermal stacked with many tens of gliders with Mode-C transponders, there have been some studies of the problem of transponder synchronous garbling in those cases). BTW if any of those gliders have a Mode-S transponder like the Trig TT-21 then this avoids the Mode-C synchronous garbling issues and TCAS and ATC are capable of unambiguously seeing a relatively large number of individual threats in the same proximity. Bottom line. I would hope people turn on the transponder and leave it on unless they are using flight following for a formation/tow flight and if so then talk to the local ATC facility about how they want to handle the radio procedures. I know there are battery concerns, but turning off for long periods to save battery power is different (but also a violation of FARs), and I'd hope with modern transponders this is really a not a requirement. Darryl I have been only loosly following this thread. I'm pretty confused at this point, but now have specific questions. We have a ZAON PCAS in our club glider. We are now installing a transponder too. I understand that the PCAS will know that the glider's own transponder is not a threat so it will filter it out. If we tow behind a towplane which also has a transponder, what will happen? Will the PCAS see the tow plane as a threat, and display that? But another airplane might be on a collision course... but the PCAS will not see that because it sees the towplane as the closest threat? OR..........will the PCAS think that the towplane transponder is actually the glider's transponder since it stays at the same relative altitiude and position? Will it filter out both the glider's transponder and the tow planes' transponder? Should we put the glider's transponder to "stand by" during tow? If we do, will the PCAS then think the tow plane's transponder is really the glider's transponder and filter it out, allowing the PCAS to see other targets? Should we just say "screw it" and ignore the PCAS entirely during tow? Cookie |
transponders in EU | Sandro | Soaring | 2 | February 2nd 07 01:02 PM |
Saw an Interesting thing this weekend at the airport | Kevin Kubiak | Piloting | 12 | December 8th 05 11:19 PM |
Mode S transponders | Wallis | Home Built | 4 | March 10th 05 10:33 AM |
Transponders | [email protected] | Home Built | 2 | March 2nd 05 02:39 AM |
Transponders | Mil80C | Soaring | 64 | February 12th 04 05:46 PM |
