Hi, do any gliders have full-span flaperons that also act as airbrakes
(say at 70-90 degree), or do you lose all aileron authority when the flaperons are that deflected? |
Bert,
All the sailplanes, I am aware of, that use flaps for glide-slope control also have ailerons. (PIK-20B, 1-35, Concept 20, the entire Schreder series, etc.) None of the mentioned models' wing control surfaces are full-span flaperons. Wayne http://www.soaridaho.com/Schreder "Bret" wrote in message ... Hi, do any gliders have full-span flaperons that also act as airbrakes (say at 70-90 degree), or do you lose all aileron authority when the flaperons are that deflected? |
On Mar 6, 8:12*pm, Bret wrote:
Hi, do any gliders have full-span flaperons that also act as airbrakes (say at 70-90 degree), or do you lose all aileron authority when the flaperons are that deflected? Kestrel 19 has full span flaperons. The inboard section, in climb and cruise settings, deflects half the range of the outboard sections. A second, panel mounted, landing flap handle, allows half or full landing flap deflections of the inboard sections, to a maximum of 35 degrees. This generates high drag and lift for glide path control when landing. Half landing flap may be used when ground launching and will add 200ft or more to the launch height. Derek Piggott has described it as a rather complex cockpit as gliders go, as there are also air brakes and a tail chute. Frank Whiteley |
On Mar 6, 10:12*pm, Bret wrote:
Hi, do any gliders have full-span flaperons that also act as airbrakes (say at 70-90 degree), or do you lose all aileron authority when the flaperons are that deflected? I agree with Wayne's reply. I can understand the simplicity: No spoilers/air-brakes to build into the wing. No internal linkage to build into the wing (just control the flaperons at the root). But I think your concern about roll control is valid. I once built an R/C model with the setup you describe. Landing was very tricky, too tricky, especially with any crosswind. Regards, -Doug |
On Sat, 06 Mar 2010 19:12:52 -0800, Bret wrote:
Hi, do any gliders have full-span flaperons that also act as airbrakes (say at 70-90 degree), or do you lose all aileron authority when the flaperons are that deflected? Yes. Of course - there's total flow separation on the back of flaps in landing position, so ailerons would have very little effect if they matched the flap position. Take a look at an ASW-20. During normal flight (flaps between -9 and +8 degrees) the flaps and ailerons neutral points move together (in roll flaps move half the deflection of the ailerons). In landing flap (around +40 degrees) the ailerons move to -8 degrees to maintain good roll authority. This is known in RC circles as Crow Mode and the aerodynamic wing twist induces is a very effective drag generator. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
"Martin Gregorie" wrote in message ... On Sat, 06 Mar 2010 19:12:52 -0800, Bret wrote: Hi, do any gliders have full-span flaperons that also act as airbrakes (say at 70-90 degree), or do you lose all aileron authority when the flaperons are that deflected? Yes. Of course - there's total flow separation on the back of flaps in landing position, so ailerons would have very little effect if they matched the flap position. Take a look at an ASW-20. During normal flight (flaps between -9 and +8 degrees) the flaps and ailerons neutral points move together (in roll flaps move half the deflection of the ailerons). In landing flap (around +40 degrees) the ailerons move to -8 degrees to maintain good roll authority. This is known in RC circles as Crow Mode and the aerodynamic wing twist induces is a very effective drag generator. The HP-18 has a system similar to the ASW-20. Many HP-16 and RS-15 builders have also incorporated the flaps/aileron interlink mechanism. Wayne http://www.soaridaho.com/Schreder |
Or consider the ASW-12. No spoilers/airbrakes and the flaps did not
move much (i.e. flaps were little or no help for glide path control). Later versions had a tail chute. Now *there's* a real man's glider! Kudos to anyone who dared to fly it. Regards, -Doug |
Wayne Paul wrote:
Bert, All the sailplanes, I am aware of, that use flaps for glide-slope control also have ailerons. (PIK-20B, 1-35, Concept 20, the entire Schreder series, etc.) None of the mentioned models' wing control surfaces are full-span flaperons. Wayne http://www.soaridaho.com/Schreder "Bret" wrote in message ... Hi, do any gliders have full-span flaperons that also act as airbrakes (say at 70-90 degree), or do you lose all aileron authority when the flaperons are that deflected? Kestrel 19m (Slingsby T59D) has full span flaperons with the same mixer capability of the ASW20 - the correct procedure is to put the flaps into negative territory, then apply the landing flap lever. That way you have wonderful roll authority, ailerons slightly drooped and ~35 degrees of landing flap. Flaps and ailerons are separate - The mixer applies proportional flap deflection to the ailerons - so - If you do it wrong the ailerons go to almost full down deflection and you only (effectively) have upward movement on one to cause roll. Makes turns onto finals interesting with those long heavy wings. I don't know of any sailplane design that uses full span single surface flaperons. --- news://freenews.netfront.net/ - complaints: --- |
Frank Whiteley wrote:
On Mar 6, 8:12 pm, Bret wrote: Hi, do any gliders have full-span flaperons that also act as airbrakes (say at 70-90 degree), or do you lose all aileron authority when the flaperons are that deflected? Kestrel 19 has full span flaperons. The inboard section, in climb and cruise settings, deflects half the range of the outboard sections. A second, panel mounted, landing flap handle, allows half or full landing flap deflections of the inboard sections, to a maximum of 35 degrees. This generates high drag and lift for glide path control when landing. Half landing flap may be used when ground launching and will add 200ft or more to the launch height. Derek Piggott has described it as a rather complex cockpit as gliders go, as there are also air brakes and a tail chute. Frank Whiteley Rather complex? Surely not. You establish a nice steady final approach using thermal flap so you can see the runway over the very high instrument panel. Then you use your left hand to select 55-70kt flap (-2) - flaps forward Then you reverse direction with the same hand and pull the separate landing flap lever backwards to half or full flap. Best be sure you can make the field before you do this as dumping the landing flap will result in a lot of lost height and full landing flap steepens the approach appreciably. Simultaneously you use your other left hand to control the finer approach sink rate with the modest airbrakes. Maybe there is reason in this - you effectively have to allow the airbrakes to retract as you apply landing flap. While doing this you maintain roll and pitch control with your right and on the stick, and adjust the trim using the trigger on the base of the stick with your little finger. Did I mention that you had best have not neglected to lock the undercarriage down with your right hand on downwind. If not you use your other right hand to do it now. In the event that you are too high - or approaching a very short field over obstacles you may want to deploy the parachute. Now there are three identical feeling little handles down there between the stick and the panel. Remember the left most will operate the cable release, no use to you here. The left of centre one will release the parachute in case you no longer want it and the little fairing for the rudder... And the one you want is on the right hand side under your thigh (inevitably) So you can use your other right hand to dig it out and yank HARD. Then nothing happens till you wiggle the rudder, at which point it is best to have already lowered the nose to counter the surreptitious slow down. At this point - if you can see it over your toes it is out of glide range. Then you might want to pull the left hand (but not cable release) handle to jettison the parachute as you cross the fence - in case the parachute hooks on something well anchored (like a fence). In his instance it is useful to have another left hand available as the airbrakes will tend to close without something to hold them open, and the fence at the other end of the field may be looming. In practice it all works quite well, the Kestrel is very stable and tolerates the hand swapping and general fidgeting - but it is a cockpit you need to know before you try to fly it. There are lots of separate controls in close proximity - and the correct combinations are important lest the beastie rise up and bite you. --- news://freenews.netfront.net/ - complaints: --- |
On Mar 7, 12:17*pm, Bruce wrote:
I don't know of any sailplane design that uses full span single surface flaperons. LS6 & 10 have full span flaperons. Actually, built in two pieces and hinged separately (due to a kink in the trailing edge), but linked together and driven by one pushrod per side. No fancy mixer, landing flaps puts the entire training edge down about 15 degrees which adds a useful about of drag while keeping good aileron control. But the 6's landing flap in no way compares to the ASW-20, Ventus B, HP, PIK, etc. Those are FLAPS! Kirk 66 |
| D.C. anti-war rally on C-SPAN today at 8:15 AM on the west coast of US and at 11:15 AM on east coast - President Carter at Brandeis on C-SPAN 2's 'Book TV' today at 12:30 PM (on the west coast and at 3:30 PM on the east coast): | [email protected] | Naval Aviation | 0 | January 27th 07 03:18 PM |
| Airbrakes Pop Out at 115 kts | ContestID67 | Soaring | 13 | May 10th 05 02:50 PM |
| ASW19b best descent rate on approach (full airbrakes) | Robert Sharpe | Soaring | 1 | April 30th 05 12:41 PM |
| Radio protocol regarding full stops on full stop only nights | Ben Hallert | Piloting | 33 | February 9th 05 08:52 PM |
| Flaperons | Lou Parker | Home Built | 26 | November 15th 04 05:40 AM |
