On Mar 15, 6:24*am, Tony wrote:
On Mar 15, 7:21*am, "Paul Remde" wrote: Hi Tony, Cool! *Thanks for sharing! I've never been involved in a wing recovering. *It looks a lot like covering a remote control glider wing - which I have done - many years ago. *In the video it appears that you are using an iron to attach the fabric to the wood. *What is the iron heating up that causes the fabric to stick to the wood? *What is the adhesive? *Just curious. Thanks, Paul Remde Paul - yes the iron is heating the adhesive which had been brushed on the wing. *The Stewart Systems EkoBond glue is heat activated. *I found this very convenient. We started each day by brushing the glue on the wing where we wanted to attach the fabric, then letting it dry. *This allowed us to put the fabric blanket on the wing and adjust its position without it sticking to everything and smearing glue all over the place. *Then with the iron we re-activated the glue and viola the fabric was stuck. *Final step is to brush the glue through the fabric to complete the bond and wipe off the excess. Tony, Do you also snug the fabric with heat? I got to play with a line of products at Oshkosh in '97 that appear to be similar to what you're using. Very much like covering a model wing with 'modern' materials. Heat adhesive, heat shrink. Neat stuff. Thanks for posting the video! |
On Mar 16, 9:40*am, Grider Pirate wrote:
On Mar 15, 6:24*am, Tony wrote: On Mar 15, 7:21*am, "Paul Remde" wrote: Hi Tony, Cool! *Thanks for sharing! I've never been involved in a wing recovering. *It looks a lot like covering a remote control glider wing - which I have done - many years ago. *In the video it appears that you are using an iron to attach the fabric to the wood. *What is the iron heating up that causes the fabric to stick to the wood? *What is the adhesive? *Just curious. Thanks, Paul Remde Paul - yes the iron is heating the adhesive which had been brushed on the wing. *The Stewart Systems EkoBond glue is heat activated. *I found this very convenient. We started each day by brushing the glue on the wing where we wanted to attach the fabric, then letting it dry. *This allowed us to put the fabric blanket on the wing and adjust its position without it sticking to everything and smearing glue all over the place. *Then with the iron we re-activated the glue and viola the fabric was stuck. *Final step is to brush the glue through the fabric to complete the bond and wipe off the excess. Tony, * Do you also snug the fabric with heat? *I got to play with a line of products at Oshkosh in '97 that appear to be similar to what you're using. *Very much like covering a model wing with 'modern' materials. Heat adhesive, heat shrink. Neat stuff. Thanks for posting the video!- Hide quoted text - - Show quoted text - yes, all Dacron (Ceconite) fabric used on aircraft these days shrinks with heat. we did two shrinks with my cheapo wal mart iron. One at 250ish degrees and the second at 300ish degrees. You may have seen a demo of the AFS system, which is the same as Stewarts. Stewart bought AFS in the early 2000's I think. |
Anyone doing a recovering project? | Lou | Owning | 9 | October 18th 08 02:22 AM |
Anyone doing a recovering project? | Lou | Home Built | 12 | October 18th 08 02:22 AM |
Recovering fuselage | Ed Haywood | Restoration | 3 | April 30th 04 04:26 AM |
Recovering fuselage | Ed Haywood | Home Built | 1 | March 12th 04 03:45 AM |
