Discus 2a cockpit size
Old March 17th 10, 06:18 PM posted to rec.aviation.soaring
EdByars
Default Discus 2a cockpit size
Steve: I flew a Discus A for 4 or 5 seasons...several hundred
hours....many 4+ hr. flights in big crowded contests and one 1000K
flight of ~10 hrs. Then I was 6'-1/2". 175 lbs, average build. I used
a Softie 'Chute with one inch of Temper-Foam on seat pan for cushion.
Tight fit but comfortable and no problems. Rear vision okay, no lack
of visibility in crowded gaggles.
The very best advise is to sit in one with the right 'chute and
cushion and see how you fit with the canopy closed.
Good luck,
Ed Byars
Old March 18th 10, 03:37 AM posted to rec.aviation.soaring
g l i d e r s t u d
I am 6ft 145lbs, and had a Discus 2a, no problem. The Ventus A was
tighter with a CG hook.
My brother is 6'4" and 210+lbs and flies his Discus A. Flies with a
softie wedge packed parachute.
LS6"C" (17.6) Cockpit Size Mike Williams Soaring 6 February 15th 15 11:52 PM
Discus 2a cockpit size Stephen[_3_] Soaring 7 March 17th 10 05:57 PM
Cockpit size of Libelle? Kevin Morris Soaring 4 July 15th 04 11:32 PM
Discus 2b cockpit comfort? Jeremy Zawodny Soaring 11 January 12th 04 08:03 PM
[LBA] Schempp-Hirth - Discus bT - Discus Frederic FUCHS Soaring 0 September 17th 03 08:42 AM
