More restrictions for "experimental"
Old March 21st 10, 03:14 PM posted to rec.aviation.soaring
Andy[_1_]
Default More restrictions for "experimental"
Two local pilots had FAA ramp inspections last Friday and one other,
after declining to be inspected, had a discussion with an inspector.
It appears that the local FSDO is taking the position that NO flight
may be made in a glider with an experimental (racing and exhibition)
certificate, even within 300 miles of home base, unless the specific
date of the flight is notified to the FSDO. That notification may
either be in the program letter by including every date on which a
flight may be made, or by notifying the FSDO prior to each flight by
FAX or email.
For a first hand report see:
http://www.asa-soaring.org/forum/top...er+inspections
Andy (GY)
Old March 21st 10, 03:52 PM posted to rec.aviation.soaring
jcarlyle
It would be interesting to know what's in back of this activity in AZ.
It's now clear that each FSDO makes up its own mind about how to
approach its duties.
I had interactions with my local PA FSDO last year, and there was no
indication that my FSDO was thinking like the one in AZ. The gentleman
(really, truly) specifically said to me that there was no problem
flying my experimental ship at any time within 300 nm of the airport,
and that I could fly anywhere outside the circle provided that I faxed
him a letter with my intentions before doing so. The only thing he
asked me of me was to provide the annual letter sometime in January,
so it wouldn't be forgetten.
The onsite inspection I went through was also easy - not like these AZ
ramp checks are described at all. Although I had my aircraft paperwork
and logs with me, the main thing he seemed to be concerned about was
making sure that the serial number on the data plate matched the
serial number on the paperwork. I'd characterize the encounter as
courteous, professional and painless.
Is it possible that someone has been playing fast and loose with an
experimental ship in AZ, flaunting the regulations?
-John
FAX or email.
http://www.asa-soaring.org/forum/top...9&forum_id=4&T...
Andy (GY)
Old March 21st 10, 03:59 PM posted to rec.aviation.soaring
Greg Arnold
FAX or email.
Would Bob Thompson satisfy the racing requirement if he posts all his
flights to OLC?
Andy (GY)
Old March 21st 10, 04:32 PM posted to rec.aviation.soaring
BT[_3_]
I read the posting on asa-soaring, it appears that the AZ FSDO reps have
their own interpretation of the requirement.
"Most" of the newer generation Operating Limitations allow "practice
flights" in preparation for contest.
Also the Operating Limitations should allow flying for "FAI Badge
Achievements".. not just contest flying.
Talk to Cindy... this needs to get upchanneled through SSA and FAA quickly.
BT
"Andy" wrote in message
FAX or email.
Andy (GY)
Old March 21st 10, 11:24 PM posted to rec.aviation.soaring
Frank Whiteley
date of the flight is notified to the FSDO. *That notification may
FAX or email.
http://www.asa-soaring.org/forum/top...9&forum_id=4&T....
Andy (GY)
FAA Order 8130.2F(chg5). Makes for interesting reading. Download a
copy from the FAA web site.
*Regarding pre-moratorium experimental certificates of airworthiness
and notifying the FSDO.
Section 10 Para 155e
e. Effectivity. Aircraft that received original airworthiness
certification before July 9, 1993, are
NOT affected by this order unless the original airworthiness
certification purpose changes, for example,
from R&D to exhibition. Those aircraft, except for purpose changes,
will not be affected until the FAA
works with the public to determine the best strategy to certificate
all experimental exhibition and/or air
racing aircraft in accordance with the new policy. The policy
established in this order will not be used
in these cases unless specifically requested by the applicant.
*Anyone seen an NPRM?
*If post-moratorium, fun flying was never a legitimate purpose.
Para 158
158. GROUPS OF AIRCRAFT. Aircraft eligible for experimental
airworthiness certification for
exhibition or air racing range from unpowered gliders to high-
performance jet aircraft. In order to
properly certificate this wide range of aircraft, and in response to
the many public comments received,
the FAA has divided these aircraft into four groups. This was done in
order to establish standardized
operating limitations, proficiency areas, and inspection requirements
appropriate to each aircraft.
Minimum operating limitations for each group are provided in paragraph
161 of this order. The FAA
will make a determination of which group the aircraft will operate in
based on the following:
a. Group I, Performance Competition Aircraft.
(1) Description of Aircraft. Specialty aircraft are of limited
availability and possess design
characteristics that make the aircraft suitable for competition. The
operational parameters are designed
for only one purpose, for example, maneuverability, flight duration,
or speed, and as such would only be
used in performance-based competition events and would not be used for
personal business or transport
activity.
(2) Type of Aircraft. Aerobatic aircraft or powered/unpowered gliders.
Aircraft that would
operate under this group include the Rolladen-Schneider LS-4b,
Schleicher ASW-24, Pitts Special,
Sukhoi SU-26, Sukhoi SU-29, etc.
(3) Proficiency Area. All proficiency flights will be conducted in
airspace within an
operational radius of 300 nautical miles from the airport where the
aircraft is based.
(4) Inspection Requirements. These aircraft must be inspected each
year in accordance with
an inspection plan that contains the scope and detail of appendix D to
part 43..
*Regarding program letters and specificity of same
Para 159b
b. Records Inspection. In addition to the record inspection
requirements of paragraph 88a of this
order, the FAA must—
(1) Obtain from the applicant a program letter in accordance with §
21.193(a), setting forth the
purpose(s) for which the aircraft will be used. The program letter
must be specific as to the intended use
under the purpose requested, including names, dates, and locations of
airshows, air races, or exhibition
activities that will be attended. In the case of a movie or television
production, the date(s)
and location(s) of these productions must be provided. The applicant’s
program letter should state a
reasonable schedule of events to be attended, but should not list
events that would obviously be
impossible to attend, for example, listing all airshows scheduled in
the United States for the upcoming
year. Applicants should be advised that the program letter is subject
to review by the FAA and that the
owner/operator must notify the local FSDO by letter or fax of any
amendments to the proposed schedule
prior to that flight.
NOTE: Applicants that do not submit a specific program letter do not
meet
the intent of § 21.193 and must not be issued a special airworthiness
certificate.
*The order doesn't appear to allow e-mail changes, though my FSDO is
open to it by signed PDF amendment attached to e-mail with read
receipt option enabled. Appears other FSDO's are also open to
something similar.
*Regarding airworthiness
Para160c.
c. An FAA inspector may elect to process the aircraft on a one-time
certification basis, for
example, via the issuance of only one special airworthiness
certificate of unlimited duration. In these
instances, when issuing the special airworthiness certificate for the
purpose(s) of exhibition and/or air
racing, the operating limitations will be prescribed in two phases in
the same document.
*Someone recently mentioned their FSDO would issue a new Airworthiness
Certificate and Operating Limitations. Only the Operating Limitations
need amendment or restating, the airworthiness certificate doesn't
expire.
*Interesting that para161, by virtual of 91.319(b) allows the FSDO to
apply the factory test flights against the Phase I test requirements.
Good to know and a very reasonable policy, but needs to be annotated
in the aircraft log books. Some DARs need to understand this.
*Regarding proficiency flights and what's stated in operating
limitations
Para161b
(31) All proficiency/practice flights must be conducted within the
geographical area described
in the applicant’s program letter and any amendments to that letter,
but no portion of that area will be
more than 300 nautical miles from the aircraft’s home base airport. An
exception is permitted for
proficiency flying outside of the area stated above for organized
formation flying, training, or pilot
checkout in conjunction with a specific event listed in the
applicant’s program letter (or amendments).
The program letter should indicate the location and dates for this
proficiency flying.
(Applicability: Group I; group III under 800 horsepower)
(35) Proficiency flights are authorized without geographical
restrictions when conducted in
preparation for participation in sanctioned meets and pursuant to
qualify for Federal Aeronautique
International (FAI) or Soaring Society of America (SSA) awards. These
flights may only take place as
defined in the applicant’s program letter, and prior to the specific
FAI or SSA event. The pilot in
command must submit a description of the intended route and/or
geographical area intended to be flown
to the local FSDO.
(Applicability: Group I, gliders only)
(37) The owner/operator of this aircraft must submit an annual program
letter update to the
local FSDO that lists airshows, fly-ins, etc., that will be attended
during the next year, commencing at
the time this aircraft is released into phase II operation. This list
of events may be amended, as
applicable, by letter or fax to the FSDO prior to the intended
operation amendments. A copy of the
highlighted aeronautical chart, when applicable, must be carried
aboard this aircraft and be available to
the pilot.
(Applicability: All)
(38) This aircraft is authorized for flights or static display at
airshows, air races, and in motion
pictures conducted under a waiver issued in accordance with § 91.903.
Section 91.903: Policy and procedures.
(a) The Administrator may issue a certificate of waiver authorizing
the operation of aircraft in deviation from any rule listed in this
subpart if the Administrator finds that the proposed operation can be
safely conducted under the terms of that certificate of waiver.
(b) An application for a certificate of waiver under this part is made
on a form and in a manner prescribed by the Administrator and may be
submitted to any FAA office.
(c) A certificate of waiver is effective as specified in that
[Doc. No. 18334, 54 FR 34325, Aug. 18, 1989]
*Perhaps gliders need some sort of waiver in general.
*I would recommend active participation in the IGC(FAI)/OLC contest,
every flight. As SSA state governor, I recognize OLC participation
annually in addition to other achievements. http://www.coloradosoaring.org/awards.htm
State and national records are honored at the national level and world
records at the FAI level. Badges are recognized awards at the SSA and
FAI levels. I'm told one of the characters on the ASA discussion has
been chided by other hang glider types about his unwillingness or
inability to upload OLC flights. Re-read 161b(35) again. Some awards
require declarations. According to my state record keeper, there have
been some changes regarding declarations for badges and records that
will result in rejections this year unless you are up on them. Now
some of you have been warned, no whining later. New forms on the SSA
web site. Toss the stale forms at the glider port.
Frank Whiteley
Old March 22nd 10, 08:26 AM posted to rec.aviation.soaring
Doug Haluza
snip
to the local FSDO.
snip
every flight. *As SSA state governor, I recognize OLC participation
annually in addition to other achievements. *http://www.coloradosoaring..org/awards.htm
snip
Yes, the SSA does sanction the OLC in the US, and the SSA presents
annual awards nationally, and for each SSA region, for SSA-OLC
Classic, Trangle and League. The SSA state governors are free to make
additional awards in their areas as well. FAI also sanctions the FAI-
OLC League and FAI-OLC triangle portion of the OLC worldwide. One
twist here is that the OLC 'event' runs all year to the second Monday
of October, so this would not conicide with a January 1 annual program
letter period. I would suggest that you could specify in your program
letter which SSA regions you intend to compete in, and this should
meet the specificity requirement. You would have to be registered as
an OLC competitor, have a suitable logger, and upload flight claims on
a regular basis to make this legit. Note that the SSA does not enforce
membership requirements for participation in the OLC, but we only
recognize members for awards, same as the FAI. So you would have to be
an SSA member to be considered a competitor at the SAA-OLC regional or
national level, and/or a member of NAA with a sporting license to
compete in the OLC-i (international) and for NAA national and FAI
world records.
Doug Haluza, CGIG
SSA-OLC Committe Chair
Old March 22nd 10, 10:13 PM posted to rec.aviation.soaring
Andy[_1_]
On Mar 21, 4:24*pm, Frank Whiteley wrote:
FAA Order 8130.2F(chg5). *Makes for interesting reading. *Download a
Para 158
activity.
Aircraft that would
airspace within an
aircraft is based.
part 43..
Para 159b
meet
certificate.
receipt option enabled. *Appears other FSDO's are also open to
something similar.
Para160c.
the same document.
Certificate and Operating Limitations. *Only the Operating Limitations
expire.
in the aircraft log books. *Some DARs need to understand this.
limitations
Para161b
proficiency flying.
to the local FSDO.
the pilot.
records at the FAI level. *Badges are recognized awards at the SSA and
FAI levels. *I'm told one of the characters on the ASA discussion has
inability to upload OLC flights. *Re-read 161b(35) again. *Some awards
require declarations. *According to my state record keeper, there have
will result in rejections this year unless you are up on them. *Now
some of you have been warned, no whining later. *New forms on the SSA
web site. *Toss the stale forms at the glider port.
Frank Whiteley- Hide quoted text -
- Show quoted text -
Ok, I read all that but it is still not clear to me that the order
requires the program letter to define the date of every flight whch is
conducted within 300 miles of the home airport.
Do you think it requires that?
Andy (GY)
Old March 22nd 10, 10:49 PM posted to rec.aviation.soaring
Para 158
activity.
Aircraft that would
airspace within an
aircraft is based.
part 43..
Para 159b
meet
certificate.
something similar.
Para160c.
the same document.
expire.
limitations
Para161b
proficiency flying.
to the local FSDO.
the pilot.
annually in addition to other achievements. *http://www.coloradosoaring.org/awards.htm
Andy (GY)- Hide quoted text -
I just finished talking with my FSDO in Reno. He said we didn't need
to list every flight. If we fly out of the home airport then we need
to revise the Program Letter and state where we plan to fly and the
time frame ie: May through June. The more detail the better but no
requirement to define every flight. Tom VN
Old March 22nd 10, 10:51 PM posted to rec.aviation.soaring
Tuno
I'm curious about the "All proficiency flights will be conducted in
airspace within an operational radius of 300 nautical miles from the
airport where the aircraft is based" part.
What defines the aircraft's base of operations?
Am I limited to one BofO per year? If not, then how many? Perhaps if I
plan on doing a 500 mile straight-out, I can declare a new BofO for
the second half of the flight?
I'm imagining a 21st century flight recorder that wirelessly emails
the FSDO a new BofO declaration when a GPS fix approaches the 300 mile
limit from the last one ...
Old March 22nd 10, 11:59 PM posted to rec.aviation.soaring
glider[_2_]
FAA Inspector at the FSDO Office in Atlanta, Georgia says Program
Letter needs to say "Proficiency and practice". With such words, you
are free and clear to soar when you like. It's still good to state
specific meets and contests but there is no intent to stop people
flying for enjoyment. So says Atlanta.
Perhaps Scottsdale FSDO is on testosterone toot.
GA
FAX or email.
Andy (GY)
"VideO Madness" ( Soldiers...) "GoD Hates FAGS!!! (He sO righteOusly DoES)" Colonel Jake Naval Aviation 0 March 1st 10 12:14 AM
Experimental Certificate Granted UAV If MAC "Extremely Improbable"! Larry Dighera Piloting 71 March 6th 08 11:14 PM
"V-22 Mishap Probe Prompts US Fleet Restrictions" Mike[_7_] Naval Aviation 0 December 10th 07 03:10 PM
Flight Restrictions on non-amateur built experimental aircraft?? Don W Home Built 9 April 20th 07 11:23 PM
