The TR-21 comes with long (1.25 inch) black flathead screws (4-40).
These screws are the countersink type and do not work well with my fiberglass instrument panel. They have a small head. I'm looking for a source for machine screws, 4-40 x 1.25", in a black non-metallic material. Any suggestions would be appreciated. Raul Boerner |
On Mar 24, 3:03*pm, wrote:
The TR-21 comes with long (1.25 inch) black flathead screws (4-40). These screws are the countersink type and do not work well with my fiberglass instrument panel. They have a small head. I'm looking for a source for machine screws, 4-40 x 1.25", in a black non-metallic material. Any suggestions would be appreciated. Raul Boerner "non-metallic material" or non-magnetic? Most mounting hardware is brass or nylon (very low strength)and the heads are painted with black prior to installation. Try fastenal: http://www.fastenal.com/web/products...0181675&ucst=t |
On Mar 24, 2:03*pm, wrote:
The TR-21 comes with long (1.25 inch) black flathead screws (4-40). These screws are the countersink type and do not work well with my fiberglass instrument panel. They have a small head. I'm looking for a source for machine screws, 4-40 x 1.25", in a black non-metallic material. Any suggestions would be appreciated. Raul Boerner Part 2 of this game is guess what a TR-21 is and guess which country you are in. You mean a Trig TT-21 transponder? In the USA lots of places sell different instrument panel screws. Often available in brass or aluminum with a black coating. Aircraft Spruce, I think Cumulus Soaring and I assume many others. You might have a problem with 4-40 but look at those places. Darryl |
On Mar 24, 3:35*pm, Darryl Ramm wrote:
On Mar 24, 2:03*pm, wrote: The TR-21 comes with long (1.25 inch) black flathead screws (4-40). These screws are the countersink type and do not work well with my fiberglass instrument panel. They have a small head. I'm looking for a source for machine screws, 4-40 x 1.25", in a black non-metallic material. Any suggestions would be appreciated. Raul Boerner Part 2 of this game is guess what a TR-21 is and guess which country you are in. You mean a Trig TT-21 transponder? In the USA lots of places sell different instrument panel screws. Often available in brass or aluminum with a black coating. Aircraft Spruce, I think Cumulus Soaring and I assume many others. You might have a problem with 4-40 but look at those places. Darryl Darryl, Indeed, my error. I am installing a Trig TT-21. Another error is that the machine screw is 1.5" long instead of the slightly shorter version posted. The 4-40 in 1.5 iches, panhead and black, is a problem. Raul Boerner |
Hi,
I don't have exactly what you need, but I have recently started stocking up on a variety of "glider panel screws". I stock them both in black oxided stainless steel (nearly non-magnetic) and brass with black oxide. The sizes I stock are listed below. I found it was easy to get black stainless steel screws at McMaster Carr, but black brass was tough. I had to have the screws treated locally in a large batch. The stainless steel screws don't seem to affect compasses - even when a box of screws is near the compass. In stock in both brass with black oxide and stainless steel with black oxide - M3 x 8 mm - pan head - M4 x 10 mm - pan head - M4 x 10 mm - pan head - M4 x 12 mm - pan head I also stock the following screws for use in a variety of U.S. made small instruments: 6-32 x 1/2" black stainless steel. I also stock 8-32 x 1/2" in black brass I also stock 8-32 x 3/4" and 8-32 x 5/8" in flat head black stainless steel and 8-32 x 5/8" in pan head black stainless steel. I think that is most everything. I'll add them all to my web site soon. Note: Winter used to supply aluminum M4 screw that were black, but they can't get them anymore. They now supply black treated brass screws. I have a few of the aluminum ones remaining in stock. Best Regards, Paul Remde Cumulus Soaring, Inc. wrote in message ... On Mar 24, 3:35 pm, Darryl Ramm wrote: On Mar 24, 2:03 pm, wrote: The TR-21 comes with long (1.25 inch) black flathead screws (4-40). These screws are the countersink type and do not work well with my fiberglass instrument panel. They have a small head. I'm looking for a source for machine screws, 4-40 x 1.25", in a black non-metallic material. Any suggestions would be appreciated. Raul Boerner Part 2 of this game is guess what a TR-21 is and guess which country you are in. You mean a Trig TT-21 transponder? In the USA lots of places sell different instrument panel screws. Often available in brass or aluminum with a black coating. Aircraft Spruce, I think Cumulus Soaring and I assume many others. You might have a problem with 4-40 but look at those places. Darryl Darryl, Indeed, my error. I am installing a Trig TT-21. Another error is that the machine screw is 1.5" long instead of the slightly shorter version posted. The 4-40 in 1.5 iches, panhead and black, is a problem. Raul Boerner |
On Mar 24, 9:03*pm, wrote:
The TR-21 comes with long (1.25 inch) black flathead screws (4-40). These screws are the countersink type and do not work well with my fiberglass instrument panel. They have a small head. I'm looking for a source for machine screws, 4-40 x 1.25", in a black non-metallic material. Any suggestions would be appreciated. Raul Boerner 4-40 screws in that length are hard to come by. Your best bet would be to use the screws supplied with the TT21 and use countersink finishing washers. These effectively turn the countersink screw into a pan head screw and are available in various materials and colours. I have seen this done successfully on several panels. Neil |
![]() "Neil" wrote in message ... On Mar 24, 9:03 pm, wrote: The TR-21 comes with long (1.25 inch) black flathead screws (4-40). These screws are the countersink type and do not work well with my fiberglass instrument panel. They have a small head. I'm looking for a source for machine screws, 4-40 x 1.25", in a black non-metallic material. Any suggestions would be appreciated. Raul Boerner 4-40 screws in that length are hard to come by. Your best bet would be to use the screws supplied with the TT21 and use countersink finishing washers. These effectively turn the countersink screw into a pan head screw and are available in various materials and colours. I have seen this done successfully on several panels. Neil Are you *sure* they are 4-40? Considering source of TR21 they may be metric. Hartley Falbaum |
On Mar 25, 5:30*am, "HL Falbaum" wrote:
Are you *sure* they are 4-40? Considering source of TR21 they may be metric. I wondered the same thing too so I checked the TT-21 installation manual. It says 4-40. Andy (GY) |
On Mar 25, 8:52*am, Andy wrote:
On Mar 25, 5:30*am, "HL Falbaum" wrote: Are you *sure* they are 4-40? Considering source of TR21 they may be metric. I wondered the same thing too so I checked the TT-21 installation manual. *It says 4-40. Andy (GY) I've gone to http://www.smallparts.com for hard to find fasteners. |
Interior screws - C172G | news.west.cox.net | Owning | 6 | October 17th 07 10:59 PM |
Stuck panel screws | [email protected] | Owning | 10 | July 7th 06 12:51 AM |
FAA Screws Up Again | BushOKDemocratsSTUPID | Instrument Flight Rules | 2 | March 22nd 06 10:39 PM |
Media screws up again... | Sam | Piloting | 181 | June 17th 04 06:08 PM |
Avsim screws itself | Azhosers | Simulators | 2 | April 5th 04 10:32 PM |
