DIY Two-Stroke Engine
Old March 21st 10, 03:00 AM posted to rec.crafts.metalworking,rec.aviation.homebuilt,rec.aviation.ultralight
bizguy
Default DIY Two-Stroke Engine
This thread is going all over the place - so here goes.
Consider building a Kemp G2 replica. If you can do that there might
even be others that would want to buy them.
2 cyl - 4 cycle low end HP.
  #52
Old March 21st 10, 09:51 PM posted to rec.crafts.metalworking,rec.aviation.homebuilt,rec.aviation.ultralight
bizguy
Consider building a Kemp G2 replica. *If you can do that there might
http://bourkeengine.net/home.htm
http://www.rogerrichard.com/14507.html
Another very interesting project worthy of following.
  #53
Old March 27th 10, 09:32 AM posted to rec.crafts.metalworking,rec.aviation.homebuilt,rec.aviation.ultralight,rec.models.scale,uk.rec.models.engineering
wesley marceaux[_2_]
your too late,, Mr. Chotia made an engine for the weedhopper that is exactly
what you described..you can go to the weedhopper site and buy one for under
a hundred bucks...........try,,,,you'll be surprised
"durabol" wrote in message
For the last few years I have toyed with the idea of building a
homemade two-stroke engine for UL use. What keyed my interest was
reading about homemade model aircraft engines and reading and watching
a re-enactment of the Wright brother's first flight with a replica
engine (not a two-stroke engine).
Has anyone made a 2-stroke engine from scratch? One may need to cast
aluminium, may need a lathe and milling machine with boring head and
hone or perhaps the boring and honing of the cylinder and bearing
journals could be farmed out. A commercial carburetor and piston could
be used. Two-stroke engines seem simple enough that home construction
may be possible, if not practical.
A direct drive engine will be that much heavier when you take into
account the weight of the drive reduction system. I have calculated
the weight of an 80x80mm bore and stroke 2 cylinder opposed engine and
it was a bit under 40lbs which should give about 1hp/lbs. I used 10mm
cylinder and crankcase wall thickness and a 1.25" dia crank.
I have got some idea of port-time-area from the freeware computer
program called "BiMotion". I'm not sure how good the data is for
lowish speed engines but I guess it is a start. I have also worked up
a spreadsheet for similar information.
I don't think a reed valve system is needed for this engine since it
is only going to operate at a fairly narrow rpm range and the port
timing isn't critical. Piston ported valves offer similar performance
to other induction types but only over a narrow rpm range which is
what I have planned for the engine. I plan to build an engine with a
restrictive exhaust to ensure no fuel escapes. I have heard that
piston ported engines can spit some fuel out of the carb at idle but
this doesn't seem like a major problem. Rotary valves via crank shaft
induction (disk or drum valves as well) is an interesting idea but I
don't think I need the critical timing they provide.
I was planning on using the largest two-stroke piston (not a diesel
piston) I could find and using the largest stoke that was reasonable,
something like 90x105mm
Brock
  #54
Old March 27th 10, 08:18 PM posted to rec.crafts.metalworking,rec.aviation.homebuilt,rec.aviation.ultralight,rec.models.scale,uk.rec.models.engineering
cavelamb[_2_]
I was surprised - to see that the site hasn't been updated since 2005...
I didn't see anything about an engine for under $100 either.
  #55
Old March 30th 10, 07:59 PM posted to rec.crafts.metalworking,rec.aviation.homebuilt,rec.aviation.ultralight
Fred the Red Shirt
I would indeed be very much surprised to find such an engine
available
for that price, unless it is a very simple model engine, as opposed to
one that might be used on a weedhopper.
There are least three (3) weedhopper Yahoo groups:
http://groups.yahoo.com/group/weedhopper/
http://groups.yahoo.com/group/WUPA/
http://groups.yahoo.com/group/Weedhopper-Ultralights/
The third appears to have fallen victim to spam, but there
may be something of interest in the earliest postings.
FF
  #56
Old April 5th 10, 05:11 PM posted to rec.crafts.metalworking,rec.aviation.homebuilt,rec.aviation.ultralight,rec.models.scale,uk.rec.models.engineering
Fred the Red Shirt
Perhaps he was looking at a weedwhacker website...
Ff
2-stroke diesel is the (near) future? Max Kallio Home Built 134 July 18th 05 12:39 AM
Small 4 stroke engine? Ron Wanttaja Home Built 35 July 2nd 05 07:25 PM
How about 2-stroke diesel for helicopters Max Kallio Rotorcraft 3 March 31st 05 04:46 PM
BSFC vs gas mileage, 2 stroke vs 4 stroke Jay Home Built 10 August 24th 04 02:26 PM
McCullough Two-Stroke Relaibility Gordon Arnaut Home Built 0 June 15th 04 10:26 PM
