Volkslogger help
Old April 1st 10, 12:08 AM posted to rec.aviation.soaring
laura betzoldt
Default Volkslogger help
Volkslogger shuts down after about 15 min into flight, can turn off
and on ILEC sn-10 and volks will start working again. Can’t down
flight from Volks to PDA with see you mobile. I get ERROR OCCURRIED
COMMUNICATION WITH/DEVICE EXTERNAL CODE (-10) on Connect Me.
Just had Volks calibrated??
Any
ideas
Glen
Old April 1st 10, 12:39 AM posted to rec.aviation.soaring
Paul Remde
Hi Glen,
The error mentioned below may be simply that the communication port on the
PDA is already in use by another application. Try doing a soft reset to the
PDA immediately before running ConnectMe.
If the VL is powered by the SN10 (which is likely), then when you power-down
the SN10 you also power-down the VL - so it is rebooted.
What logging interval is set on the VL?
Is the VL memory cleared immediately before flight?
Those are the only things that come to mind.
Best Regards,
Paul Remde
Cumulus Soaring, Inc.
"Laura betzoldt" wrote in message
Any
ideas
Glen
Old April 1st 10, 01:14 AM posted to rec.aviation.soaring
laura betzoldt
On Mar 31, 7:39*pm, "Paul Remde" wrote:
Hi Glen,
PDA is already in use by another application. *Try doing a soft reset to the
What logging interval is set on the VL? NOT SURE
Is the VL memory cleared immediately before flight? YES
Best Regards,
Paul Remde
and on *ILEC sn-10 and volks will start working again. *Can t down
flight from Volks to PDA with see you mobile. I get *ERROR OCCURRIED
COMMUNICATION WITH/DEVICE * * EXTERNAL CODE (-10) * on Connect Me.
* Any
ideas
* * Glen
Volkslogger help need Nick Kennedy Soaring 8 March 17th 09 04:48 PM
Looking for a Volkslogger Ron Gleason Soaring 1 December 14th 06 04:09 AM
Volkslogger + Mac Wouter Wessels Soaring 14 April 14th 05 10:05 PM
Looking for a Volkslogger Del Ogren Soaring 0 August 20th 04 03:00 AM
Volkslogger Going fer it Soaring 1 February 17th 04 04:43 AM
