Tupolev 1935
Old January 20th 04, 02:19 PM
andreas g
Default Tupolev 1935
I am looking for the name of an Tupolev aircraft, build around 1935,
three seat, engine M-58 with 850hp, recon, lowwing, which i found in B Arct
book 'All the worlds
aircraft 58'. A prototyp of ANT-51?
Any clue?
andreas
Old January 22nd 04, 07:42 AM
JasiekS
Użytkownik "andreas g" napisał w wiadomości
Arct
Any clue?
andreas
You are probably speaking about ANT-40.1 with Wright-Cyclone radial
engines - the first prototype of the later SB bomber. On the page
http://www.ctrl-c.liu.se/misc/ram/index.html you can find index of early
Russian (tsar epoch) and Soviet aircraft. The site seems to be updated for
the last time in July of 1999. There is no mention about M-58 engine so I
suspected a typo (there was ANT-35 from 1936 powered by M-85 engine, a
licence built Gnome-Rhone Mistral-Major 14Krsd). Other source ('Handbuch der
Luftfahrt Jahrgang 1939' by W. von Lanfsdorff, J.F. Lehmans Verlag) has a
short entry on 'MJ-13 (A.N.T. 40) 1934' where I found that M-58 were
watercooled 12-cyllinder V-motors which resembles rather Hispano-Suiza
12Yrds of the second prototype ANT-40.2. The site is relying mainly on a
two-volume book by V.B. Shavrov 'History of aircraft construction in the
USSR', ISBN 5-217-02528-X. I don't know who is right. I assume that Shavrov
is more credible in this area.
ANT-51 (the later Su-2 or BB-1) was designed by P.O. Sukhoy under general
supervision of A.N. Tupolev. The works started in 1937 and aircraft was
fitted with M-62 (later with M-87A) engines.
Regards
JasiekS
Warsaw, Poland
PS. Was it the book by Bohdan Arct? Do you read in Polish?
Old January 23rd 04, 10:53 AM
andreas g
"JasiekS" schrieb im Newsbeitrag
Arct
Any clue?
andreas
der
Shavrov
Regards
JasiekS
Warsaw, Poland
Pozdrawiam z Monachium,
yes i have a copy of Arct book from '64 ant there is an entry
Tupolev R-7 1935
Samolot liniowy, trzy- lub czteromiejscowy
dolnopłat, silnik M-58 o mocy 850 KM, pod-
wozie chowane w locie, konstrukcja metalowa,
kabiny zakryte. Uzbrojenie 1 działko 25 mm
oraz 3 kaemy, udźwig bomb 400 kG. Pręd-
kość maksymalna 380 km/h, pułap praktycz-
ny 8600 m, zasięg 1000 km.
translated , three / four seater, observer, lowwing ,one M-58 850hp,
undercarriege turned in, metal construction, cabin enclosed,1 25mm gun and 3
mg
400kg bombs, max speed 380km/h, ceiling 8600m, range 1000km.
so the point is , false or fiction?
by the way, RAM webpage is very impressive, but sometimes their are
different stories, from different sources.
and a search on his webpage did not find any m-58 engine at all.
I also tried to get a copy of Shavrov book but no chance.
Nemecek and Nowarra also didn't helped me out.
By the way, as i looking for a cheap domain in poland, can you help me out?
I found a german provider offering for 7euro a year, sql,perl,50mb but a .de
domain.
andreas
Hughes racer record 352mph 1935 Chris W Home Built 6 August 10th 03 09:57 PM
War books from Germany FYI Only ArtKramr Military Aviation 0 July 31st 03 02:54 AM
Copyright Š2004-2025 AviationBanter.
