SN10 USB connection
Old April 14th 10, 05:08 AM posted to rec.aviation.soaring
Andy[_10_]
Default SN10 USB connection
On Apr 13, 4:56*pm, T8 wrote:
On Apr 13, 6:12*pm, Eric Greenwell wrote:
T8 wrote:
On Apr 13, 2:02 pm, Dave *wrote:
(1) Winscore, or any scoring program, could care less what
kind of media used for the files. The scorer may however
complain if you show up with 5.25" floppy disks.
Winscore doesn't care. *However the operating system does take a while
longer to recognize a USB drive. *Experience shows that SD cards beat
any other option in the scoring shack by a country mile.
-T8
What are scorers using for the OS - Win 98? Me? My XP computers find and
display a USB drive in 5-6 seconds vs 4-5 seconds for an SD card, not
enough time to go that country mile, even with 50 entrants. Does the
problem come from having 50 different USB drives, instead just 5 or 6
different ones?
Eric Greenwell - Washington State, USA (netto to net to email me)
Leo (Buckley) could tell you more, but afaik he doesn't read r.a.s.
On his system -- I've watched this -- SD cards are recognized much
faster than USB drives. *If we all used USB drives with identical
drivers it would probably be a non-issue.
-T8
Could it be that the scorer usually has the SD card reader plugged in
and recognized by the computer and that somehow speeds the mounting of
individual contestants' SD cards whereas the USB drives need to get
recognized independently for each contestant?
9B
Old April 14th 10, 12:00 PM posted to rec.aviation.soaring
T8
-T8
different ones?
-T8
9B
Here's an excerpt from the email Leo sent out to R5 entrants (all 65
of 'em):
"So, my preference for flight logs is the following:
1 – Memory Cards such as “Secure Digital” or “Compact Flash”
2 – USB Thumbdrives. These take longer than memory cards because the
operating system has to find a driver and load it for each Thumbdrive
the first time the computer sees the Thumbdrive. Succeeding reads
take less time but are still slower than memory cards because the
drive has to be installed.
There is one other problem, which is mostly with “Cruzer”
thumbdrives. These seem to have programs on them that automatically
start and run, which totally blocks my computer from reading the
flight log. So, please, NO Cruzers. Instead get an ordinary cheap
small thumbdrive and use it.
3- 3 ½ inch Floppy Disks. Although pretty obsolete, I can still read
them.
4– Direct downloads from Loggers.
A - I have the hardware and software to download the older Cambridge
Model 10, 20, or 25 loggers.
B – I have the hardware and software to download Volksloggers with
the RJ-11 connector.
C – EWA Microrecorders have a USB connection and behave like a
thumbdrive ."
-T8
Old April 14th 10, 01:23 PM posted to rec.aviation.soaring
Dave Nadler
On Apr 13, 8:49*pm, Darryl Ramm wrote:
I have a small converter that looks like a normal USB memory
stick, with a tiny slot in the end for a uSD card (I use this for
turning in FLARM log files). The combo (adapter plus uSD card)
draws 100ma, which is the max our adapter sources.
What it needs all that power for I have no idea...
Your mileage may vary !
Best Regards, Dave
PS: In windows device manager, switch to connection view,
and you can see the USB current for each connected device.
No need for breakout cables...
You don't need to be in connection view do you?
Its the easiest way to find the hub controlling your device,
which is where you need to look at the power.
Anyhow this does not work in a virtual machine like I am running. My
God, people still run Windows on native hardware? I keep mine locked
tightly is a safe container on the shelf and only open it when needed.
Depending on *which* virtualization scheme you are using
and its USB support, it may work. USB doesn't work in free
VirtualBox for example...
Darryl
Old April 14th 10, 01:25 PM posted to rec.aviation.soaring
Dave Nadler
On Apr 13, 11:03*pm, Eric Greenwell wrote:
Dave Nadler wrote:
On Apr 13, 7:40 pm, Darryl *wrote:
I assume Dave's earlier comment about power consumption of USB to SD
card adapters referred to some of the larger desktop style ones, the
typical small SD to USB small adapters like my SanDisk MicroMate or
SimpleTech Bonzai draw very low currents. I don't have my USB breakout
cable handy or I'd measure the currents but I know it is low.
Darryl
draws *100ma, which is the max our adapter sources.
Best Regards, Dave
I opened Device Manager, located my USB memory stick in the USB
controller list, opened Properties, but don't see power or current
listed in any of the tabs. The Generic hub did have a Power tab, but it
showed the requirement for the attached device (auxiliary display), not
actual current. Can you be more specific on which USB to look at, and
where in the Properties?
- "Transponders in Sailplanes - Feb/2010" also ADS-B, PCAS, Flarmhttp://tinyurl.com/yb3xywl
Start with "View by Connection".
Locate the USB hub controlling your device.
Look at properties, power tab...
This shows the max current negotiated (max to be provided
by USB host), not the instantaneous actual current.
Hope that helps,
Best Regards, Dave
ILEC SN10 release 2.35 Dave Nadler Soaring 7 March 27th 10 07:46 PM
SN10 B for sale Dick[_3_] Soaring 1 November 29th 09 06:31 PM
SN10 Remote Repair Mike the Strike Soaring 5 February 19th 08 02:24 PM
Ilec SN10 question John Ferguson Soaring 3 May 29th 07 05:11 AM
SN10 Remote BMacLean Soaring 0 August 24th 03 10:32 PM
