#11
On Apr 13, 4:56*pm, T8 wrote:
On Apr 13, 6:12*pm, Eric Greenwell wrote: T8 wrote: On Apr 13, 2:02 pm, Dave *wrote: (1) Winscore, or any scoring program, could care less what kind of media used for the files. The scorer may however complain if you show up with 5.25" floppy disks. Winscore doesn't care. *However the operating system does take a while longer to recognize a USB drive. *Experience shows that SD cards beat any other option in the scoring shack by a country mile. -T8 What are scorers using for the OS - Win 98? Me? My XP computers find and display a USB drive in 5-6 seconds vs 4-5 seconds for an SD card, not enough time to go that country mile, even with 50 entrants. Does the problem come from having 50 different USB drives, instead just 5 or 6 different ones? -- Eric Greenwell - Washington State, USA (netto to net to email me) Leo (Buckley) could tell you more, but afaik he doesn't read r.a.s. On his system -- I've watched this -- SD cards are recognized much faster than USB drives. *If we all used USB drives with identical drivers it would probably be a non-issue. -T8 Could it be that the scorer usually has the SD card reader plugged in and recognized by the computer and that somehow speeds the mounting of individual contestants' SD cards whereas the USB drives need to get recognized independently for each contestant? 9B |
On Apr 14, 12:08*am, Andy wrote:
On Apr 13, 4:56*pm, T8 wrote: On Apr 13, 6:12*pm, Eric Greenwell wrote: T8 wrote: On Apr 13, 2:02 pm, Dave *wrote: (1) Winscore, or any scoring program, could care less what kind of media used for the files. The scorer may however complain if you show up with 5.25" floppy disks. Winscore doesn't care. *However the operating system does take a while longer to recognize a USB drive. *Experience shows that SD cards beat any other option in the scoring shack by a country mile. -T8 What are scorers using for the OS - Win 98? Me? My XP computers find and display a USB drive in 5-6 seconds vs 4-5 seconds for an SD card, not enough time to go that country mile, even with 50 entrants. Does the problem come from having 50 different USB drives, instead just 5 or 6 different ones? -- Eric Greenwell - Washington State, USA (netto to net to email me) Leo (Buckley) could tell you more, but afaik he doesn't read r.a.s. On his system -- I've watched this -- SD cards are recognized much faster than USB drives. *If we all used USB drives with identical drivers it would probably be a non-issue. -T8 Could it be that the scorer usually has the SD card reader plugged in and recognized by the computer and that somehow speeds the mounting of individual contestants' SD cards whereas the USB drives need to get recognized independently for each contestant? 9B Here's an excerpt from the email Leo sent out to R5 entrants (all 65 of 'em): "So, my preference for flight logs is the following: 1 – Memory Cards such as “Secure Digital” or “Compact Flash” 2 – USB Thumbdrives. These take longer than memory cards because the operating system has to find a driver and load it for each Thumbdrive the first time the computer sees the Thumbdrive. Succeeding reads take less time but are still slower than memory cards because the drive has to be installed. There is one other problem, which is mostly with “Cruzer” thumbdrives. These seem to have programs on them that automatically start and run, which totally blocks my computer from reading the flight log. So, please, NO Cruzers. Instead get an ordinary cheap small thumbdrive and use it. 3- 3 ½ inch Floppy Disks. Although pretty obsolete, I can still read them. 4– Direct downloads from Loggers. A - I have the hardware and software to download the older Cambridge Model 10, 20, or 25 loggers. B – I have the hardware and software to download Volksloggers with the RJ-11 connector. C – EWA Microrecorders have a USB connection and behave like a thumbdrive ." -T8 |
On Apr 13, 8:49*pm, Darryl Ramm wrote:
I have a small converter that looks like a normal USB memory stick, with a tiny slot in the end for a uSD card (I use this for turning in FLARM log files). The combo (adapter plus uSD card) draws 100ma, which is the max our adapter sources. What it needs all that power for I have no idea... Your mileage may vary ! Best Regards, Dave PS: In windows device manager, switch to connection view, and you can see the USB current for each connected device. No need for breakout cables... You don't need to be in connection view do you? Its the easiest way to find the hub controlling your device, which is where you need to look at the power. Anyhow this does not work in a virtual machine like I am running. My God, people still run Windows on native hardware? I keep mine locked tightly is a safe container on the shelf and only open it when needed. Depending on *which* virtualization scheme you are using and its USB support, it may work. USB doesn't work in free VirtualBox for example... Darryl |
On Apr 13, 11:03*pm, Eric Greenwell wrote:
Dave Nadler wrote: On Apr 13, 7:40 pm, Darryl *wrote: I assume Dave's earlier comment about power consumption of USB to SD card adapters referred to some of the larger desktop style ones, the typical small SD to USB small adapters like my SanDisk MicroMate or SimpleTech Bonzai draw very low currents. I don't have my USB breakout cable handy or I'd measure the currents but I know it is low. Darryl I have a small converter that looks like a normal USB memory stick, with a tiny slot in the end for a uSD card (I use this for turning in FLARM log files). The combo (adapter plus uSD card) draws *100ma, which is the max our adapter sources. What it needs all that power for I have no idea... Your mileage may vary ! Best Regards, Dave PS: In windows device manager, switch to connection view, and you can see the USB current for each connected device. No need for breakout cables... I opened Device Manager, located my USB memory stick in the USB controller list, opened Properties, but don't see power or current listed in any of the tabs. The Generic hub did have a Power tab, but it showed the requirement for the attached device (auxiliary display), not actual current. Can you be more specific on which USB to look at, and where in the Properties? -- Eric Greenwell - Washington State, USA (netto to net to email me) - "Transponders in Sailplanes - Feb/2010" also ADS-B, PCAS, Flarmhttp://tinyurl.com/yb3xywl Start with "View by Connection". Locate the USB hub controlling your device. Look at properties, power tab... This shows the max current negotiated (max to be provided by USB host), not the instantaneous actual current. Hope that helps, Best Regards, Dave |
ILEC SN10 release 2.35 | Dave Nadler | Soaring | 7 | March 27th 10 07:46 PM |
SN10 B for sale | Dick[_3_] | Soaring | 1 | November 29th 09 06:31 PM |
SN10 Remote Repair | Mike the Strike | Soaring | 5 | February 19th 08 02:24 PM |
Ilec SN10 question | John Ferguson | Soaring | 3 | May 29th 07 05:11 AM |
SN10 Remote | BMacLean | Soaring | 0 | August 24th 03 10:32 PM |
