I know that I will get a 'grey' score using the GNII utility and I was
fairly certain that the ConnectMe download did the same thing. I will try doing it both ways next weekend for sure. Bob 7U On Apr 14, 5:33*pm, "Paul Remde" wrote: Hi Bob, I think you are doing something wrong in the flight log download. *A flight log downloaded by ConnectMe is exactly the same as a flight log downloaded by the 300 Utility. *I suspect that you are submitting a flight log generated by the SeeYou Mobile "PDA logger". Best Regards, Paul Remde Cumulus Soaring, Inc. "Bob 7U" wrote in message ... Thanks Paul, thanks Richard, I'm sure you will playing with these units in the days to come and reporting back. ConnectMe *works a charm with the only snag being that it produces a 'Grey' score line on the OLC. Maybe this is something the OLC people can fix or Naviter might look at including the ability to run the Cambridge utility. Bob 7U On Apr 14, 4:48 pm, Richard wrote: On Apr 14, 1:37 pm, "Paul Remde" wrote: Hi Bob, I don't know for certain. The unit is setup to be specific to running Mobile and ConnectMe. I don't see an easy way to access Windows File Explorer to run the Cambridge 300 Utility and I don't know whether File Explorer is even installed in the unit. It is possible to copy files to the Oudie, but I can't see a way to run them. SeeYou ConnectMe will work fine, except that it can't check the flight log security after download. Best Regards, -- Paul Remde Cumulus Soaring, Inc. "Bob 7U" wrote in message .... Hi Paul, Does it run the Cambridge flight download utility? I know it will have ConnectMe but I was curious about running the Cambridge software. Bob 7U On Apr 14, 12:28 pm, "Paul Remde" wrote: Hi, I just received my first batch of Naviter Oudies. They are very nice! There are many small software tweaks that make them easier to use. For example, when selecting the comm port (the default is the internal GPS) the selection list includes text which clarifies how each port is used (COM 1: Internal, COM 4: Serial, etc.).http://www.cumulus-soaring.com/seeyou.htm All 30 of the units received today have already been sold, but many more are on the way to me which should arrive next week. They have not all been sold yet. The supplied serial cable works well with a 302 or GPS-NAV but has nuts on the connector, so a straight through cable is required to connect it to a GPS-NAV. I have them in stock (see link below). The nuts can be removed, but then there is no simple way to secure it to the GPS-NAV. I feel that it is important that a secure connection is made because you wouldn't want it to fall off in flight. The 12V power leads must be powered for the cable to work. It supplies 5V power to the Oudie and also has a built-in RS-232 voltage level converter. I recommend this cable for use with the Cambridge GPS-NAV.http://www.cumulus-soaring.com/cai_prices.htm#HA-349 For the Cambridge 302 and other devices I recommend the Oudie-PS5a-1 cable because they pass 5V power from the 302 to the Oudie. The 302 seems to provide enough power for the Oudie as long as the Oudie is fully charged or nearly so.http://www.cumulus-soaring.com/goddard.htm#Oudie-PS5a-1 Best Regards, Paul Remde Cumulus Soaring, Inc.- Hide quoted text - - Show quoted text - Bob, To run the CAI utility the correct nav path would have to be set and certain .dlls would need to be auto installed. This is something we would probably have to ask SeeYou to do. I have the Ultimate running the CAI Utility, but I have much more access to the operating system and the registry on the Ultimate. Richardwww.craggyaero.com |
Hi Bob,
GN II (and ConnectMe) can download a perfectly secure and legal flight log from a 302. It would be identical to a flight log downloaded by the 300 Utility. I suspect that you are trying to submit a flight log generated by GN II's "PDA logger". Take a look at the file name before you upload the flight log. It should contain the serial number of the 302. Best Regards, Paul Remde Cumulus Soaring, Inc. "Bob 7U" wrote in message ... I know that I will get a 'grey' score using the GNII utility and I was fairly certain that the ConnectMe download did the same thing. I will try doing it both ways next weekend for sure. Bob 7U On Apr 14, 5:33 pm, "Paul Remde" wrote: Hi Bob, I think you are doing something wrong in the flight log download. A flight log downloaded by ConnectMe is exactly the same as a flight log downloaded by the 300 Utility. I suspect that you are submitting a flight log generated by the SeeYou Mobile "PDA logger". Best Regards, Paul Remde Cumulus Soaring, Inc. "Bob 7U" wrote in message ... Thanks Paul, thanks Richard, I'm sure you will playing with these units in the days to come and reporting back. ConnectMe works a charm with the only snag being that it produces a 'Grey' score line on the OLC. Maybe this is something the OLC people can fix or Naviter might look at including the ability to run the Cambridge utility. Bob 7U On Apr 14, 4:48 pm, Richard wrote: On Apr 14, 1:37 pm, "Paul Remde" wrote: Hi Bob, I don't know for certain. The unit is setup to be specific to running Mobile and ConnectMe. I don't see an easy way to access Windows File Explorer to run the Cambridge 300 Utility and I don't know whether File Explorer is even installed in the unit. It is possible to copy files to the Oudie, but I can't see a way to run them. SeeYou ConnectMe will work fine, except that it can't check the flight log security after download. Best Regards, -- Paul Remde Cumulus Soaring, Inc. "Bob 7U" wrote in message ... Hi Paul, Does it run the Cambridge flight download utility? I know it will have ConnectMe but I was curious about running the Cambridge software. Bob 7U On Apr 14, 12:28 pm, "Paul Remde" wrote: Hi, I just received my first batch of Naviter Oudies. They are very nice! There are many small software tweaks that make them easier to use. For example, when selecting the comm port (the default is the internal GPS) the selection list includes text which clarifies how each port is used (COM 1: Internal, COM 4: Serial, etc.).http://www.cumulus-soaring.com/seeyou.htm All 30 of the units received today have already been sold, but many more are on the way to me which should arrive next week. They have not all been sold yet. The supplied serial cable works well with a 302 or GPS-NAV but has nuts on the connector, so a straight through cable is required to connect it to a GPS-NAV. I have them in stock (see link below). The nuts can be removed, but then there is no simple way to secure it to the GPS-NAV. I feel that it is important that a secure connection is made because you wouldn't want it to fall off in flight. The 12V power leads must be powered for the cable to work. It supplies 5V power to the Oudie and also has a built-in RS-232 voltage level converter. I recommend this cable for use with the Cambridge GPS-NAV.http://www.cumulus-soaring.com/cai_prices.htm#HA-349 For the Cambridge 302 and other devices I recommend the Oudie-PS5a-1 cable because they pass 5V power from the 302 to the Oudie. The 302 seems to provide enough power for the Oudie as long as the Oudie is fully charged or nearly so.http://www.cumulus-soaring.com/goddard.htm#Oudie-PS5a-1 Best Regards, Paul Remde Cumulus Soaring, Inc.- Hide quoted text - - Show quoted text - Bob, To run the CAI utility the correct nav path would have to be set and certain .dlls would need to be auto installed. This is something we would probably have to ask SeeYou to do. I have the Ultimate running the CAI Utility, but I have much more access to the operating system and the registry on the Ultimate. Richardwww.craggyaero.com |
Paul Remde wrote:
Hi, I just received my first batch of Naviter Oudies./snip/ http://www.cumulus-soaring.com/seeyou.htm All 30 of the units received today have already been sold /snip/ Paul Remde Cumulus Soaring, Inc. Paul's note reminded me of the impetus that this newsgroup provided me not so long ago; and (among others) how useful Paul's hints on loading a PDA with effective displays for the cockpit turned out to be. In flying from Oklahoma to the Gulf last weekend, I finally had the opportunity to check out the device that I had loaded. Sure, not bright in sunlight, but usable. And the quasi-Primary Flight Display (or call it a quasi-Attitude Director - ADI) was much less handy than the moving map selection. Seeing a destination airfield on the nose from 40 miles away was reassuring. In my case, when the Corpus Christi ATIS warns arrivals not to mistake the similar looking Naval airfield 4 miles SW for Corpus International - that was visually obvious! The difference that a power feed makes to GPS satellite capture was my biggest surprise. When I added a simple Garmin for course to Airport, distance to run, present track, and ETE, my security felt pretty much iron-clad. Brian W |
On Apr 14, 1:48*pm, Richard wrote:
On Apr 14, 1:37*pm, "Paul Remde" wrote: Hi Bob, I don't know for certain. *The unit is setup to be specific to running Mobile and ConnectMe. *I don't see an easy way to access Windows File Explorer to run the Cambridge 300 Utility and I don't know whether File Explorer is even installed in the unit. *It is possible to copy files to the Oudie, but I can't see a way to run them. SeeYou ConnectMe will work fine, except that it can't check the flight log security after download. Best Regards, -- Paul Remde Cumulus Soaring, Inc. "Bob 7U" wrote in message .... Hi Paul, Does it run the Cambridge flight download utility? I know it will have ConnectMe but I was curious about running the Cambridge software. Bob 7U On Apr 14, 12:28 pm, "Paul Remde" wrote: Hi, I just received my first batch of Naviter Oudies. They are very nice! There are many small software tweaks that make them easier to use. For example, when selecting the comm port (the default is the internal GPS) the selection list includes text which clarifies how each port is used (COM 1: Internal, COM 4: Serial, etc.).http://www.cumulus-soaring.com/seeyou.htm All 30 of the units received today have already been sold, but many more are on the way to me which should arrive next week. They have not all been sold yet. The supplied serial cable works well with a 302 or GPS-NAV but has nuts on the connector, so a straight through cable is required to connect it to a GPS-NAV. I have them in stock (see link below). The nuts can be removed, but then there is no simple way to secure it to the GPS-NAV. I feel that it is important that a secure connection is made because you wouldn't want it to fall off in flight. The 12V power leads must be powered for the cable to work. It supplies 5V power to the Oudie and also has a built-in RS-232 voltage level converter. I recommend this cable for use with the Cambridge GPS-NAV.http://www.cumulus-soaring.com/cai_prices.htm#HA-349 For the Cambridge 302 and other devices I recommend the Oudie-PS5a-1 cable because they pass 5V power from the 302 to the Oudie. The 302 seems to provide enough power for the Oudie as long as the Oudie is fully charged or nearly so.http://www.cumulus-soaring.com/goddard.htm#Oudie-PS5a-1 Best Regards, Paul Remde Cumulus Soaring, Inc.- Hide quoted text - - Show quoted text - Bob, To run the CAI utility the correct nav path would have to be set and certain .dlls would need to be auto installed. *This is something we would probably *have to ask SeeYou *to do. I have the Ultimate running the CAI Utility, but I have much more access to the operating system and the registry on the Ultimate. Richardwww.craggyaero.com- Hide quoted text - - Show quoted text - WinPilot has their version of PNA offered on their website. I see virtually no threads about it? Out of style? Any input????? 6PK |
On Apr 17, 10:42*am, PK wrote:
On Apr 14, 1:48*pm, Richard wrote: On Apr 14, 1:37*pm, "Paul Remde" wrote: Hi Bob, I don't know for certain. *The unit is setup to be specific to running Mobile and ConnectMe. *I don't see an easy way to access Windows File Explorer to run the Cambridge 300 Utility and I don't know whether File Explorer is even installed in the unit. *It is possible to copy files to the Oudie, but I can't see a way to run them. SeeYou ConnectMe will work fine, except that it can't check the flight log security after download. Best Regards, -- Paul Remde Cumulus Soaring, Inc. "Bob 7U" wrote in message .... Hi Paul, Does it run the Cambridge flight download utility? I know it will have ConnectMe but I was curious about running the Cambridge software. Bob 7U On Apr 14, 12:28 pm, "Paul Remde" wrote: Hi, I just received my first batch of Naviter Oudies. They are very nice! There are many small software tweaks that make them easier to use. For example, when selecting the comm port (the default is the internal GPS) the selection list includes text which clarifies how each port is used (COM 1: Internal, COM 4: Serial, etc.).http://www.cumulus-soaring.com/seeyou.htm All 30 of the units received today have already been sold, but many more are on the way to me which should arrive next week. They have not all been sold yet. The supplied serial cable works well with a 302 or GPS-NAV but has nuts on the connector, so a straight through cable is required to connect it to a GPS-NAV. I have them in stock (see link below). The nuts can be removed, but then there is no simple way to secure it to the GPS-NAV. I feel that it is important that a secure connection is made because you wouldn't want it to fall off in flight. The 12V power leads must be powered for the cable to work. It supplies 5V power to the Oudie and also has a built-in RS-232 voltage level converter. I recommend this cable for use with the Cambridge GPS-NAV.http://www.cumulus-soaring.com/cai_prices.htm#HA-349 For the Cambridge 302 and other devices I recommend the Oudie-PS5a-1 cable because they pass 5V power from the 302 to the Oudie. The 302 seems to provide enough power for the Oudie as long as the Oudie is fully charged or nearly so.http://www.cumulus-soaring.com/goddard.htm#Oudie-PS5a-1 Best Regards, Paul Remde Cumulus Soaring, Inc.- Hide quoted text - - Show quoted text - Bob, To run the CAI utility the correct nav path would have to be set and certain .dlls would need to be auto installed. *This is something we would probably *have to ask SeeYou *to do. I have the Ultimate running the CAI Utility, but I have much more access to the operating system and the registry on the Ultimate. Richardwww.craggyaero.com-Hide quoted text - - Show quoted text - WinPilot has their version of PNA offered on their website. I see virtually no threads about it? Out of style? Any input????? 6PK- Hide quoted text - - Show quoted text - PK, I use and sell both SeeYou & WinPilot. They both are great soaring programs and run well on the CE 5.0 platforms. The CE 5.0 operating system that the Oudie and WinPilot PNA use are in my opinion much more stable that the Windows Mobile platforms. The WinPilot PNA is very similiar to the Oudie. These devices are about the same as the PDAs in the sunlight but are larger so easier to see and are much more stable than the PDAs. Both programs also run well on the Craggy Aero Ultimate which runs CE 5.0 and is the best available as far as sunlight readabilty. I have compared to all the current devices offered. The Ultimate is a SeeYou mobile supported device. http://www.craggyaero.com/oudie.htm http://www.craggyaero.com/WinPilot.htm http://www.craggyaero.com/ultimate.htm Richard www.craggyaero.com |
Before Help Arrived | Mitchell Holman | Aviation Photos | 15 | January 18th 09 11:36 AM |
first P-3C CUP Orion arrived at Valkenburg | Marco P.J. Borst | Military Aviation | 1 | May 27th 04 09:42 PM |
first P-3C CUP Orion arrived at Valkenburg | Marco P.J. Borst | Naval Aviation | 1 | May 27th 04 09:42 PM |
(long) WxWorx arrived... | Tom S. | Instrument Flight Rules | 1 | September 10th 03 12:37 AM |
(long) WxWorx arrived... | Tom S. | Piloting | 0 | September 9th 03 04:54 PM |
