#21
On May 3, 11:37*am, Kimmy Boyer wrote:
Here we have two utter morons in a debate...over who is the bigger moron. Neither is a moron. Both have perspectives drawn from their specific field of experience. While simulation *is not "flying", wouldn't interest me or most people in this forum, it is recognized by the FAA such that the establishment of certificated training centers are to be developed under 14 CFR part 142 for the advancement of this technology, so, apparently it's relevant, but only to a degree. That being said, here in _recreational_ aviation piloting the emphesis most surely would be on real life factors of unpredictability and how we react to and manage them. The best answer as to creating an optimum flight plan is readily available within the annals of aviation study literature. wow isn't RAP great. Evidently. You posted. --- Mark |
#24
Mxsmanic wrote:
writes: Like a lot of what you post, there is nothing "wrong" with following V66, it is just less than optimal. If I were doing it for real and VFR, my route would be KHCD-NYL-KMYF and at an altitude above 3,500, which keeps you out of all the restricted areas. KCHD.KNYL.KMYF is 274.5 nm, whereas KCHD.GBN.V66.BARET is 274.2 nm, so your route is actually longer than mine. Actually, the distances are 273.8 and 273.4 respectfully. Additionally, your route doesn't use any VORs, so you either must trust your GPS completely or look for KNYL on the ground as you pass over it. And KNYL is partially in the Dome MOA (ceiling 6000), whereas my route doesn't touch any MOAs and only grazes R-2311 if you are flying quite low. Wrong, I said NYL, which is a VOR, and said nothing about GPS. I'm afraid I don't see anything optimal about this. Which is not surprising, since the V66 route was designed by specialists. Actually, if you want to fly V66 until BARET, the route is KCHD-GBN-MOHAK-BZA-IPL-BARET-KMYF Going over GBN is not necessary. Your route takes you eight nautical miles north of GBN. Which is not the same as going over GBN. That's if I were using VOR navigation. Your route does not include any VORs. Wrong, NYL is a VOR. If I were using GPS, I would set a waypoint roughly between BZA and NYL. Enroute I would enquire as to the status of R-2307 and R-2306E and alter course to go direct to KMYF if possible. To go direct, you'll need authorizations for R-2308B, R-2308A, R-2306A, R-2507S, R-2512, and R-2510A, responsibility for which is partly Los Angeles Center and partly Yuma Range Control. In exchange for these six different authorizations, you'll gain a total of 4.4 nautical miles as compared with your route over NYL (less for the standard V66 route), which is a gain of 1.6%. Big woof. I never said anything about going direct as the real world likelyhood of all those areas being cold is about the same as hitting Lotto. What I said was, if I were using GPS I would plan a waypoint roughly between BZA and NYL. That would avoid all restricted areas. Then enroute I would check if it were possible to transition any of the restricted areas and change course FROM THAT POINT. I didn't say FROM THAT POINT the first time since any real pilot would know that is implied by "checking enroute". And, looking at it closely, the GPS waypoint would be set just slightly south of where the R-2307 area turns north, thus avoiding all restricted areas for a total distance of about 272 nm. I'm afraid I don't see anything optimal about your route. In fact, it's worse than the normal V66 route. The main reason to avoid V66 is the other traffic on the route. The main reason to use V66 is it keeps a less than accurate pilot well away from the restricted areas. If you have GPS, know how to use it, and are uncertain of the state of all the restricted areas, the GPS route is the shortest possible IF you wind up being unable to transition any of them. If you don't have GPS and are a low time pilot with marginal navigation skills, I would then suggest taking the slighly longer VOR to VOR route. A big part of real flying is planning alternatives and flying in a manner appropriate for your equipment and skill level. -- Jim Pennino Remove .spam.sux to reply. |
#25
#26
#27
Mike Adams writes:
Good grief, this discussion is tiresome. It started off with a reasonable aviation related question, and a reasonable suggestion, then quickly degenerated into a debate about trivia. Do you guys just enjoy argument for argument's sake? What a waste of bandwidth. A lot depends on who makes the suggestion. The same suggestion will generate different amounts of sophomoric noise in replies depending on who makes it. |
#28
Mike Adams wrote:
wrote: Wrong, NYL is a VOR. Wrong again. NYL is a Tacan (at least according to Airnav). KNYL is the Yuma airport. BZA is the nearby VOR on V66. Interesting as Golden Eagle FlightPrep shows it as a VORTAC on their charts. It looks like an email is in order. -- Jim Pennino Remove .spam.sux to reply. |
#29
![]() "Mike Adams" wrote Good grief, this discussion is tiresome. It started off with a reasonable aviation related question, and a reasonable suggestion, then quickly degenerated into a debate about trivia. Do you guys just enjoy argument for argument's sake? What a waste of bandwidth. No discussion that involves MX is reasonable for long. Why do you think my advice is to never involve yourself (or anyone) with a discussion with him for any reason. It always ends up being much ado about nothing. Why everyone does not understand this is beyond my comprehension. He would be gone if everyone followed the advice to never respond to his arguments. -- Jim in NC |
#30
Mxsmanic wrote:
Uh-huh. A big part of safe flying is learning the procedures and accepting them, instead of always trying to be Maverick with home-baked shortcuts. A lot of people have worked really hard to build a network of airways with guaranteed navigation performance and safety--why the insistence on rolling your own? Actually Victor airways were developed to separate the bug smashers from everyone else and to keep them from controlled airspace. There is nothing intrinsic about them that provides "guaranteed navigation performance and safety" other than the accuracy of VOR's and with the invention of GPS they are becoming obsolete. -- Jim Pennino Remove .spam.sux to reply. |
KMYF TWR Radio prblms 62204 approx2315z | Doug | Piloting | 5 | June 24th 04 06:53 AM |
