Near mishap today
Old May 7th 10, 12:41 AM posted to rec.aviation.piloting
Mark
Default Near mishap today
Did a simulated power out emergency today, and
killed the throttle near 4500 ft. Established my
best rate of glide (70mph) and as I found my most
viable field to land in, we were going over the
procedures for such an occasion. Eventually I
reached a grassy field that actually looked
decent, surface and all.
As I set up an attitude and realistic entry we
had really lost altitude, and now, I gave it
full throttle. Sputter, sputter. We were dropping.
My CFI's hands were suddenly moving fast as
a blur. It seemed like a long time, and I just
stayed on my landing course fully prepared to
set it in the field, and then Broommm! the engine
revved up and it was climb baby climb!
Now that's one I'm not gonna forget!
Mark
Old May 7th 10, 12:09 PM posted to rec.aviation.piloting
Flaps_50!
killed the throttle near 4500 ft. *Established my
full throttle. *Sputter, sputter. We were dropping.
a blur. *It seemed like a long time, and I just
Did you forget to clear the engine every 1000'?
Cheers
Old May 7th 10, 12:44 PM posted to rec.aviation.piloting
Mark
Cheers- Hide quoted text -
- Show quoted text -
Had carb heat on, as rpms were below the arc.
But no, I wasn't instructed to input throttle during
the descent. Is that what you mean?
thanks,
Mark
Old May 7th 10, 03:06 PM posted to rec.aviation.piloting
Ęslop
"Mark" wrote in message
Your CFI should have been doing that. All of mine did, every time. Prevents
such occurrences.
Old May 7th 10, 04:41 PM posted to rec.aviation.piloting
Mark
such occurrences.
I'm speechless.
We have a choice of appx.7 cfi's to choose from at
this academy. I'll try another. If the head instructor
knew, this one would be fired.
In hindsight, the gravity of what happened yesterday is
serious. I barely had time to pull out. On the way back
up I was compelled to keep scanning that field. It looked
possible but there was something barely visible running
across it. Now I'm thinking it was a ditch.
Mark
Old May 7th 10, 06:00 PM posted to rec.aviation.piloting
a[_3_]
such occurrences.
I'm speechless.
this academy. *I'll try another. If the head instructor
It would be useful to simply ask your CFI what happened. "Hands
flying all over" doesn't cut it, there are only a few things to do.
My guess would have been carb ice: If you were coming down from 4500
to say 1000 at 500 fpm that would be 6 to 8 minutes of throttle closed
gliding. If the RH was high I am not at all sure I'd expect carb heat
to keep ahead of the icing for that length of time, but others more
expert with those airplanes may have a different opinion.
My Mooney has an injected engine, but when coming down from altitude
it is very rarely with a closed throttle, and cowl flaps are in play
too, engines are to be babied and thermal shock is a bad thing. For
that matter, the time the throttle is moved the fastest, and even then
it's not very fast, is when I decide to go around.
Here's a question for the aviators among us. How long do you take to
go from idle to take-off power when you're "position and hold" to
"cleared for immediate"? As I sit here and think about it, I'm
guessing it takes me a slow count to 5 to get to full throttle, and
that is assuming RPMs follow throttle position pretty closely.
Old May 7th 10, 06:32 PM posted to rec.aviation.piloting
Pretty much same here, on the ground, I just don't see the need
jamming the throttle forward. Steady forward pressure is all I do and
it's about 5 seconds when I am at full throttle.
I accelerate the same whether it's position to hold or cleared for
immediate. Only difference is I just get off the brakes faster for
cleared for immediate.
Old May 7th 10, 07:05 PM posted to rec.aviation.piloting
Ari[_2_]
such occurrences.
I'm speechless.
And clueless, you haven't the first idea how to choose a competent
CFI, Mark(ie). /lol/
A fireside chat not with Ari!
http://tr.im/holj
Motto: Live To Spooge It!
Old May 7th 10, 07:07 PM posted to rec.aviation.piloting
Ari[_2_]
such occurrences.
I'm speechless.
It would be useful to know what plane or simulator he was in but the
assclown didn't think that was pertinent info.
*lol*
http://tr.im/holj
Old May 7th 10, 07:15 PM posted to rec.aviation.piloting
Ari[_2_]
In my Velocity, at least that, prolly quicker. In my 42A, a little
longer as it usually is my preference on complex twins.
http://tr.im/holj
Gear Up, pt 7 - su27 mishap 1.jpg (1/1) Mitchell Holman Aviation Photos 4 April 21st 07 10:16 AM
Gear Up, pt 7 - su27 mishap 3.jpg (1/1) Mitchell Holman Aviation Photos 0 April 20th 07 02:21 PM
Gear Up, pt 7 - su27 mishap 2.jpg (1/1) Mitchell Holman Aviation Photos 0 April 20th 07 02:21 PM
AT 6 mishap in dallas.. Dave S Piloting 4 June 24th 05 09:07 PM
Quantico mishap? Paul Michael Brown Naval Aviation 22 October 5th 04 02:47 AM
