On Topic
Old May 13th 10, 07:02 PM posted to rec.aviation.piloting
Peter Dohm
Default On Topic
"Capt. Geoffrey Thorpe" The Sea Hawk @See My Sig.com wrote in message
"Peter Dohm" wrote in message
With the quest for efficiency, in recent years, most of the newer
tri-gear designs have featured free castering nose wheels. That has
certainly reduced the aerodynamic drag of the nose wheel;
Moving it to the back and reducing the size by a factor of 4 would do even
more...
Not quite as much as I had personally supposed, but still a usefull amount.
All the same, I'm learning to love the tailwheels.
  #34
Old May 13th 10, 07:16 PM posted to rec.aviation.piloting
Peter Dohm
Default On Topic
"Jim Logajan" wrote in message
even more...
Vans RV-6, 7, 8, and 9 experimentals can be built with tricycle gear and
conventional gear.
Without cheating and looking at the advertised performance difference
between the two gear choices at identical power settings, what would
either
of you guess the percentage difference in speed might be?
Well, it's more than a year too late for me to avoid cheating in that way.
However, the advertised difference is around 2 knots; which is about 1/2 or
what I would have guessed before I looked.
But, that reduced difference in cruise performand was gained at the expense
of nowe wheel steering. So what we are really comparing on the RV-6, 7, 8,
and 9 models is a fully faired and free castering nosewheel versus an
unfaired and fully steerable tailwheel. So the ground handling advantage
does not automatically go to the nosewheel version.
On a more apples for apples comparison, when the lowly and "draggy" Cessna
150 and 152 are converted from a steerable oleo strut type nosewheel to a
steerable tailwheel, they are reputed to gain at least 8 knots.
Those are the reasons that I find myself willing to advocate for the
tailwheel.
Peter
  #35
Old May 13th 10, 07:24 PM posted to rec.aviation.piloting
Peter Dohm
Default On Topic
"brian whatcott" wrote in message
even more...
Not to mention...even the venerable C150 disengaged the nosewheel in
flight to free caster.
Brian W
Not the ones that I flew. On the 150 and 152 models with which I was
familiar, the scissor link engaged a cam on the oleo casing when the nose
strut was fully extended--which forced the nosewheel into its straight ahead
position. Since the nosewheel steering force was applied through a pair of
springs, the rudder operated normally with only a little more pressure; but,
due to the limited nosewheel steering force which was available, tight turns
on the ramp did require assistance from the brakes.
Peter
  #36
Old May 13th 10, 08:34 PM posted to rec.aviation.piloting
Jon Woellhaf
Default On Topic
Why can't the tailwheel be faired? Maybe with something flexible, like
silicone rubber.
  #37
Old May 13th 10, 08:53 PM posted to rec.aviation.piloting
Mark
Default On Topic
silicone rubber.
Yes, that or just pay the $43.60.
http://www.vansaircraft.com/cgi-bin/...sc&product=twf
Mark
  #38
Old May 13th 10, 11:59 PM posted to rec.aviation.piloting
Default On Topic
No hopes, dreams, or pre-conceived misconceptions shattered, alas, but
perhaps beaten up a bit, eh? :-)
LOL....
Thanks. I needed that.
Geoff
  #39
Old May 14th 10, 02:15 AM posted to rec.aviation.piloting
Brian Whatcott
Default On Topic
even more...
Brian W
Peter
This is a way more accurate description of the mechanism by which C-150s
have nosewheels that point ahead in flight. I do agree! Does
"Free-castoring" constitute something more effective than this for
flight drag reduction? :-)
Brian W
  #40
Old May 14th 10, 02:16 AM posted to rec.aviation.piloting
Brian Whatcott
Default On Topic
silicone rubber.
Some vintage tailwheels WERE faired or retracted.
Brian W
Off-topic Q D Ramapriya Piloting 17 July 23rd 09 04:30 AM
Off-topic, but in need of help Alan Erskine Aviation Photos 20 January 5th 07 06:21 AM
Almost on topic... Richard Lamb Home Built 22 January 30th 06 06:55 PM
off topic, just a little--maybe? L.D. Home Built 5 August 27th 05 04:56 PM
off topic Randall Robertson Simulators 0 January 2nd 04 01:29 PM
