#171
![]() "Scet" wrote in message ... "Jim Yanik" wrote in message ... There is a lot more info out their........or are you trying to be mates with Tarver? Jim is not trying to be mates with me, Scet. It is only that you are being an idiot. |
#172
![]() "Scet" wrote in message ... Wrong John, average on a T56 Are you narrowing your completely wrong statements about thermocouples down to one engine now, Scet? I suppose you do need to make some mad attempt to save some face. ![]() Let us try again: A URL can be made by anyone and has no guarantee of accuracy of any kind. |
#173
#174
Jim Yanik wrote:
(B2431) wrote in : Jim Yanik wrote: "Well,then it violates basic physics.If you have two voltage sources of slightly different voltages,currents DO flow between them.That's a basic principle. And bimetal TCs are simply millivolt voltage sources." Yes Jim, what you say is true but it's 'allowed' in this (and other) cases because the voltage output, although in the millivolt range, is 'soft'. so the current is extremely low, they merely 'average' themselves. You certainly couldn't parallel two different voltage sources IF they were 'hard' because huge currents would flow. So on a T-56 engine they do indeed parallel many thermocouples. (I forget how many now, but there's a bunch) Half are used for the FCU and half for the Temperature Datum System. -- -Gord. |
#175
![]() "Gord Beaman" wrote in message ... Jim Yanik wrote: You certainly couldn't parallel two different voltage sources IF they were 'hard' because huge currents would flow. So on a T-56 engine they do indeed parallel many thermocouples. (I forget how many now, but there's a bunch) Half are used for the FCU and half for the Temperature Datum System. Did you know that the major failure mode for a theromocouple is a short? Consider, Gord, that making your little friends look less foolish is only making you look foolish. Even if you were to make an "average", you would need a "total" first. |
#176
Jim Yanik wrote:
I fail to see how the separate thermocouples outputs will be "averaged",because any individual TC cannot rise in output,as all the others parallelled will prevent any rise in voltage.Or current would flow from a higher V to a lower one,just as if you wired batteries of different voltages together,you end up with circulating currents until all cells are of equal voltage.. Seems to me that parallelling them is only for the possibility of an individual thermocouple to be burned out or open. Jim, as I mentioned before they do average. If you connected say flashlight batteries of slightly different voltages in parallel then quite high currents would flow because their internal resistance is low but thermocouples have comparatively high resistance therefore limiting the current that will flow. Picture a slightly high voltage TC in parallel with a slightly lower voltage TC. The high one will "pull" the voltage up slightly. Now add another of the same voltage as the high voltage one. This one will "pull" the voltage just slightly higher again now add a lower voltage one, the voltage will drop slightly, as this one pulls it down. The current BETWEEN these TC won't be very much because the resistance is comparatively high...see? Remember that you're right about high current flowing IF the supplies have different voltages AND are HARD supplies (they have low internal resistance) An example of a very hard supply is a 'regulated power supply', you cannot 'pull' them at all, large currents will flow and fuses will pop. They have very low internal resistance. -- -Gord. |
#177
![]() "B2431" wrote in message ... Looks like another peice of equipment Dan is incompetent to operate has been found. |
#178
![]() "Gord Beaman" wrote in message news ![]() Jim Yanik wrote: I fail to see how the separate thermocouples outputs will be "averaged",because any individual TC cannot rise in output,as all the others parallelled will prevent any rise in voltage.Or current would flow from a higher V to a lower one,just as if you wired batteries of different voltages together,you end up with circulating currents until all cells are of equal voltage.. Seems to me that parallelling them is only for the possibility of an individual thermocouple to be burned out or open. Jim, as I mentioned before they do average. If you connected say flashlight batteries of slightly different voltages in parallel then quite high currents would flow because their internal resistance is low but thermocouples have comparatively high resistance therefore limiting the current that will flow. Which makes a higher voltage. Quit while you are ahead, Gord, Danno has been hitting the bong. |
#179
"Tarver Engineering" wrote:
"Jonathan Stone" wrote in message ... In article , Tarver Engineering wrote: No, no, no. The Hercules engine is (as is well-known) a 14-cylinder sleeve-valve radial. (Lets see what Tarver makes of that.) That is a lot of sparkplugs. Hell John, not near as many as in a C-124...there's 216 in that!... -- -Gord. |
#180
Book Review: Converting Auto Engines for Experimental Aircraft , Finch | Paul | Home Built | 0 | October 18th 04 10:14 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | April 5th 04 03:04 PM |
Hercules Engines | Tarver Engineering | Home Built | 0 | January 19th 04 11:05 PM |
Accident Statistics: Certified vs. Non-Certified Engines | Ron Wanttaja | Home Built | 23 | January 18th 04 05:36 PM |
Homebuilt Aircraft Frequently-Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | July 4th 03 04:50 PM |
