#181
![]() "Gord Beaman" wrote in message ... "Tarver Engineering" wrote: "Jonathan Stone" wrote in message ... In article , Tarver Engineering wrote: No, no, no. The Hercules engine is (as is well-known) a 14-cylinder sleeve-valve radial. (Lets see what Tarver makes of that.) That is a lot of sparkplugs. Hell John, not near as many as in a C-124...there's 216 in that!... My father spent the first few years of WWII changing spark plugs. |
#182
![]() "Scet" wrote in message ... "Tarver Engineering" wrote in message ... "Scet" wrote in message ... snip Sorry Jim, but it does work. Sorry Scat, but it does work and is how the J-52, J57 and J-75 engines were instrumented. What is it you do, little troll? I said it works Tarver, can't you read? Scet Hopefully all can agree, "Tarver/Splappy" is a "Piece of Work At Best". Ralph Nesbitt Professional FD/CFR/ARFF Type |
#183
#184
![]() "Tarver Engineering" wrote in message ... "B2431" wrote in message ... From: "Tarver Engineering" Date: 1/22/2004 9:30 AM Central Standard Time snip Tarver, at the risk of a barrage of filth from you, can you provide a web site other than yours that shows TIT or EGT thermocouples in series? You are too confused for me to even respond, Dan. Tarver, I didn't think you could. You simply aren't man enough to say "I can't because there is no such thing." Why should I deal with anymore of your senile meanderings? Your favorite archive troll is in ashes and you are a certified idiot, Dan. Dream on, Splaps. |
#185
![]() "Tarver Engineering" wrote in message ... "Scet" wrote in message ... Wrong John, average on a T56 Are you narrowing your completely wrong statements about thermocouples down to one engine now, Scet? I suppose you do need to make some mad attempt to save some face. ![]() Let us try again: A URL can be made by anyone and has no guarantee of accuracy of any kind. That's because T56 engines are fitted to hercs.......... Scet |
#186
"Tarver Engineering" wrote...
A URL can be made by anyone and has no guarantee of accuracy of any kind. I guess a URL is just like one of Tarver's claims, then! |
#187
![]() "Scet" wrote in message ... That's because T56 engines are fitted to hercs.......... So? None of that changes your ignorant rants in this thread. Baker was here posting about there being no E4A and posting the military URL, but he was found out to be wrong, when one of the crew members listed the E4A serial numbers. It is easier for you to think of "average" than the engine term "total", but the exact same data is in both forms. Actually deviding is a bad idea. |
#188
![]() "John R Weiss" wrote in message news:q%cQb.106228$5V2.470908@attbi_s53... "Tarver Engineering" wrote... A URL can be made by anyone and has no guarantee of accuracy of any kind. I guess a URL is just like one of Tarver's claims, then! I saw you were making a fool of yourself at rai, Weiss. Stick a little closer to ram and your incompetence as a civil airplane operator won't show. |
#189
"Gord Beaman" wrote in message .. . Jim Yanik wrote: You certainly couldn't parallel two different voltage sources IF they were 'hard' because huge currents would flow. So on a T-56 engine they do indeed parallel many thermocouples. (I forget how many now, but there's a bunch) Half are used for the FCU and half for the Temperature Datum System. Did you know that the major failure mode for a theromocouple is a short? Yes John... ![]() Consider, Gord, that making your little friends look less foolish is only making you look foolish. Yes John... ![]() Even if you were to make an "average", you would need a "total" first. Yes John... ![]() Yes John.. (oops) -- -Gord. |
#190
"Gord Beaman" wrote in message news ![]() Jim Yanik wrote: I fail to see how the separate thermocouples outputs will be "averaged",because any individual TC cannot rise in output,as all the others parallelled will prevent any rise in voltage.Or current would flow from a higher V to a lower one,just as if you wired batteries of different voltages together,you end up with circulating currents until all cells are of equal voltage.. Seems to me that parallelling them is only for the possibility of an individual thermocouple to be burned out or open. Jim, as I mentioned before they do average. If you connected say flashlight batteries of slightly different voltages in parallel then quite high currents would flow because their internal resistance is low but thermocouples have comparatively high resistance therefore limiting the current that will flow. Which makes a higher voltage. Quit while you are ahead, Gord, Danno has been hitting the bong. Yes John... ![]() -- -Gord. |
Book Review: Converting Auto Engines for Experimental Aircraft , Finch | Paul | Home Built | 0 | October 18th 04 10:14 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | April 5th 04 03:04 PM |
Hercules Engines | Tarver Engineering | Home Built | 0 | January 19th 04 11:05 PM |
Accident Statistics: Certified vs. Non-Certified Engines | Ron Wanttaja | Home Built | 23 | January 18th 04 05:36 PM |
Homebuilt Aircraft Frequently-Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | July 4th 03 04:50 PM |
