Hercules Engines
Old January 23rd 04, 03:33 AM
Tarver Engineering
"Gord Beaman" wrote in message
"Tarver Engineering" wrote:
"Jonathan Stone" wrote in message
Tarver Engineering wrote:
No, no, no. The Hercules engine is (as is well-known) a 14-cylinder
sleeve-valve radial.
(Lets see what Tarver makes of that.)
That is a lot of sparkplugs.
Hell John, not near as many as in a C-124...there's 216 in
that!...
My father spent the first few years of WWII changing spark plugs.
  #182
Old January 23rd 04, 05:27 AM
Ralph Nesbitt
"Scet" wrote in message
"Tarver Engineering" wrote in message
snip
Sorry Jim, but it does work.
Sorry Scat, but it does work and is how the J-52, J57 and J-75 engines
were
instrumented.
What is it you do, little troll?
I said it works Tarver, can't you read?
Scet
Hopefully all can agree, "Tarver/Splappy" is a "Piece of Work At Best".
Ralph Nesbitt
Professional FD/CFR/ARFF Type
  #185
Old January 23rd 04, 12:04 PM
Scet
Wrong John, average on a T56
Are you narrowing your completely wrong statements about thermocouples
down
to one engine now, Scet?
I suppose you do need to make some mad attempt to save some face.
Let us try again:
A URL can be made by anyone and has no guarantee of accuracy of any kind.
That's because T56 engines are fitted to hercs..........
Scet
  #186
Old January 23rd 04, 05:39 PM
John R Weiss
"Tarver Engineering" wrote...
I guess a URL is just like one of Tarver's claims, then!
  #187
Old January 23rd 04, 06:15 PM
Tarver Engineering
So?
None of that changes your ignorant rants in this thread.
Baker was here posting about there being no E4A and posting the military
URL, but he was found out to be wrong, when one of the crew members listed
the E4A serial numbers.
It is easier for you to think of "average" than the engine term "total", but
the exact same data is in both forms. Actually deviding is a bad idea.
  #188
Old January 23rd 04, 06:16 PM
Tarver Engineering
"John R Weiss" wrote in message
news:q%cQb.106228$5V2.470908@attbi_s53...
kind.
I saw you were making a fool of yourself at rai, Weiss. Stick a little
closer to ram and your incompetence as a civil airplane operator won't show.
  #189
Old January 23rd 04, 06:18 PM
Jim Yanik wrote:
You certainly couldn't parallel two different voltage sources IF
they were 'hard' because huge currents would flow. So on a T-56
engine they do indeed parallel many thermocouples. (I forget how
many now, but there's a bunch) Half are used for the FCU and half
for the Temperature Datum System.
Did you know that the major failure mode for a theromocouple is a short?
Yes John...
Consider, Gord, that making your little friends look less foolish is only
making you look foolish.
Yes John...
Even if you were to make an "average", you would need a "total" first.
Yes John...
Yes John.. (oops)
-Gord.
  #190
Old January 23rd 04, 06:24 PM
news
Jim Yanik wrote:
I fail to see how the separate thermocouples outputs will be
"averaged",because any individual TC cannot rise in output,as all the
others parallelled will prevent any rise in voltage.Or current would flow
from a higher V to a lower one,just as if you wired batteries of
different
voltages together,you end up with circulating currents until all cells
are
of equal voltage..
Seems to me that parallelling them is only for the possibility of an
individual thermocouple to be burned out or open.
Jim, as I mentioned before they do average. If you connected say
flashlight batteries of slightly different voltages in parallel
then quite high currents would flow because their internal
resistance is low but thermocouples have comparatively high
resistance therefore limiting the current that will flow.
Which makes a higher voltage.
Quit while you are ahead, Gord, Danno has been hitting the bong.
Yes John...
-Gord.
Book Review: Converting Auto Engines for Experimental Aircraft , Finch Paul Home Built 0 October 18th 04 10:14 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 April 5th 04 03:04 PM
Hercules Engines Tarver Engineering Home Built 0 January 19th 04 11:05 PM
Accident Statistics: Certified vs. Non-Certified Engines Ron Wanttaja Home Built 23 January 18th 04 05:36 PM
