Fed: Planes flying in "commercial" airspace must get GPS
Old May 29th 10, 10:17 AM posted to rec.aviation.piloting
Mxsmanic
Default Fed: Planes flying in "commercial" airspace must get GPS
See
http://www.usatoday.com/travel/fligh...rol28_ST_N.htm
I assume by "commercial" airspace they mean areas like Class A-B or A-C.
And by "GPS" they appear to mean not just GPS but ADS-B.
The article doesn't say which private aircraft will be expected to install
this equipment, but the deadline is 2020.
I hope the government will not use this as an excuse to decommission VORs.
VORs are the only back-up for a satellite system that is easily jammed or
spoofed (unless you have an INS, but there aren't too many small single-engine
aircraft so equipped).
Old May 29th 10, 11:17 AM posted to rec.aviation.piloting
VOR-DME[_3_]
If your ‘aviation interest’ is insufficient to inspire you to monitor more
authoritative sources than USA Today, your reporting is condemned to be as
spotty and non precise as theirs.
The mandate just issued is for ADS-B OUT by 2020 in all aircraft operating in
airspace where a transponder is required today. You may not know exactly what
that means (and in fairness, many pilots may be rusty on this as well), but
they will simply look it up, which is what you should do as well if you’re
willing to go beyond USA Today. This requirement, by the way, is the first
implementation mandate for the system you dismissed as fiction only a few days
ago.
As for VOR’s, the FAA NextGen roadmap clearly indicates a decommissioning of
this system. They do not appear to share your concern that the satellite
system is 'easily jammed' and they are unlikely to consult with you before
decommissioning the VOR’s.
says...
See
single-engine
Old May 29th 10, 12:02 PM posted to rec.aviation.piloting
Mark
On May 29, 5:17*am, Mxsmanic wrote:
See
I hope the government will not use this as an excuse to decommission VORs..
I carry my waterproof, handheld Lowrance as a
backup. Good for the boat or plane and works
perfectly with independent battery. However, I
haven't taken it underwater and hope not to.
Decommissioning a redundancy system has to
be weighed against the benefit/loss of doing so.
Mark
Mark
Old May 29th 10, 03:03 PM posted to rec.aviation.piloting
Why do you care? It doesn't affect MSFS.
BTW, you really demonstrate how clueless you are for real world
flying.
If the satellite system is jammed it's just not ONLY going to affect
small engine airplanes. I use the very same satellites in my Garmin
430 and 296 as the airliners do.
Old May 29th 10, 03:22 PM posted to rec.aviation.piloting
Mxsmanic
VOR-DME writes:
The FAA may come to regret their unwillingness to consider the security
issues.
It's odd that people are so willing to overlook security in their rush to
adopt new technology, and then they claim that they never knew the risks when
bad things start to happen. It's always Someone Else's fault.
Old May 29th 10, 03:33 PM posted to rec.aviation.piloting
VOR-DME[_3_]
In fairness to MX I think he meant that in the event of GPS unavailability,
airliners would be able to resort to their INS navigators, which small planes
do not have. I am not sure though that airliners will continue to be equipped
with INS systems after NextGen implementation, and even if they are this is
not good enough, as it cannot reliably provide better than RNP 1.0 and has no
approach capability. Many were hoping that LORAN-C would be retained and even
developed as a backup, but that was dashed recently when the system was
definitively abandoned. VOR’s are costly to maintain, and the FAA wants to
move away from them as quickly as possible (going back to my statement that
Victor airways are obsolescent and pilots so equipped should be filing \G as
much as possible already).
It could be that the best backup for GPS will be other satellite-based
structures, GONASS or soon to be GALILEO.
In article
says...
Old May 29th 10, 03:41 PM posted to rec.aviation.piloting
Mxsmanic
VOR-DME writes:
do not have.
Yes.
That is one of my concerns also.
Thanks to the same reckless policies that may decommission VORs and ultimately
ILS.
Safety is expensive. If you don't care about safety, you can save a lot of
money.
VORs can be used for RNAV, too. Flight management systems already do this,
since they use a blend of navigational aids in order to provide a more
reliable and precise position for the aircraft.
They all have common failure modes and vulnerabilities. A solar flare could
knock them all out at once. The only way around this is to have alternate
methods for navigation, such as VORs.
Old May 29th 10, 06:11 PM posted to rec.aviation.piloting
Mxsmanic wrote:
VOR-DME writes:
do not have.
Yes.
ILS.
money.
You have no clue what the jamming susceptibility of modern GPS is or what
features exist (current and planned) to thwart it.
In reality, jamming effects a small area and is a real concern only to the
military which would expect jamming in the area of enemy targets.
A solar flare large enough to "knock them all out at once" would also take
out a lot of other stuff making the lack of GPS a minor issue.
Jim Pennino
Remove .spam.sux to reply.
(USA) US/Mexico "airspace" (boundary) files available Tuno Soaring 4 March 27th 10 07:17 PM
some planes [11 of 11] "old-air-planes-crashed-underwater-photos-pictures.jpg" yEnc (1/1) No Name Aviation Photos 0 August 9th 09 09:36 PM
On Sharing airspace with "non-rated UAV "pilots" vaughn Piloting 15 March 15th 09 04:08 PM
"Fly Baby, you violated Class B Airspace" Ron Wanttaja Piloting 27 September 5th 07 08:30 PM
Aviation Conspiracy: Connecticut To Get "Creamed" By Airspace Redesign Change? Free Speaker General Aviation 0 August 8th 06 02:42 PM
