The altimeter in my (sim) cockpit has three colored bugs, two in the shape of
arrows, diametrically opposed, in red and green, and one that is yellow and kind of wedge shaped. I can move the bugs but they all move together. What are these bugs for? The documentation doesn't seem to provide any explanation of their purpose. |
In rec.aviation.piloting Mxsmanic wrote:
The altimeter in my (sim) cockpit has three colored bugs, two in the shape of arrows, diametrically opposed, in red and green, and one that is yellow and kind of wedge shaped. I can move the bugs but they all move together. They move independently in real airplanes. What are these bugs for? The documentation doesn't seem to provide any explanation of their purpose. Setting quick glance references usually. -- Jim Pennino Remove .spam.sux to reply. |
On Jun 11, 8:13*pm, Mxsmanic wrote:
What are these bugs for? Reminders.... |
On 6/12/2010 9:54 AM, Mxsmanic wrote:
Here's a picture of the gauge with the mystery bugs: http://www.mxsmanic.com/gauge.jpg Available from Sporty's: http://sportys.com/PilotShop/product/12626 Peel and Stick Bugs These reminder bugs, available exclusively from Sporty's, are the best insurance against error for any pilot. A quick and accurate visual reference helps maintain critical air speed or altitude. Fast and simple to install–just peel off the paper backing and press it inside the bezel. Indicators consist of a thin track that installs inside the bezel. Altitude Bugs Altitude Alert Indicator marks critical altitude levels so they can be maintained by quick visual reference. In the track are three tabs that move simultaneously: green tab points to 500' above DH or MDA, yellow tab points from 200' to 100' above minimums and red tab is placed at DH or MDA. An added safety margin for approaches, it will also help sharpen your skills. Altitude Alert Indicator 2 7/8" dia. |
Jim writes:
Altitude Bugs Altitude Alert Indicator marks critical altitude levels so they can be maintained by quick visual reference. In the track are three tabs that move simultaneously: green tab points to 500' above DH or MDA, yellow tab points from 200' to 100' above minimums and red tab is placed at DH or MDA. An added safety margin for approaches, it will also help sharpen your skills. Altitude Alert Indicator 2 7/8" dia. Mystery solved! Thanks! Odd that Reality XP includes this since it apparently isn't part of the instrument itself. In any case, I found out how to turn it off. |
Mxsmanic writes:
Odd that Reality XP includes this since it apparently isn't part of the instrument itself. Actually, I've learned from the Reality XP forum that this was a special for Dreamfleet's Piper Dakota instrument panel, and once it was in, they decided to leave it as an option for the instrument in case anyone else wanted it. Once again, a Reality XP instrument turns out to behave just like the real thing. |
On Jun 12, 11:29*am, Jim wrote:
On 6/12/2010 9:54 AM, Mxsmanic wrote: Here's a picture of the gauge with the mystery bugs: http://www.mxsmanic.com/gauge.jpg Available from Sporty's:http://sportys.com/PilotShop/product/12626 Peel and Stick Bugs These reminder bugs, available exclusively from Sporty's, are the best insurance against error for any pilot. A quick and accurate visual reference helps maintain critical air speed or altitude. Fast and simple to install–just peel off the paper backing and press it inside the bezel. Indicators consist of a thin track that installs inside the bezel. Altitude Bugs Altitude Alert Indicator marks critical altitude levels so they can be maintained by quick visual reference. In the track are three tabs that move simultaneously: green tab points to 500' above DH or MDA, yellow tab points from 200' to 100' above minimums and red tab is placed at DH or MDA. An added safety margin for approaches, it will also help sharpen your skills. Altitude Alert Indicator 2 7/8" dia. I carry a couple of different training aids from Sporty's, namely their failed instrument covers. They cost about $4 each.The gadget described here is $45 or $50! The failed instrument cover simply fits a blank disk onto the face of a 2 7/8 instrument that had decided to go belly up. Scanning instruments in the clouds and looking at an artificial horizon that suggests you're maybe 30 degrees banked because its gyro lost its drive or a DG that has Alzheimers for similar reasons bothers me: it's easier to just cover the instrument face and fly partial panel. Who forgets their DH when sliding down a glide slope? For that matter, how often do you get to DH without seeing the runway environment? The only time I flew a weather driven missed approach in the last decade was going into an uncontrolled airport on a non precision approach. |
WTB: used 57mm Altimeter OR swap for 80mm Altimeter | joesimmers | Soaring | 0 | November 3rd 09 11:59 AM |
mystery of the colored flashing lights | lelson@bigfoot.com | Instrument Flight Rules | 11 | April 1st 07 09:21 PM |
Alternatively colored 2007 SSA Convention Schedule | Jeremy Zawodny | Soaring | 4 | December 29th 06 07:37 AM |
WAS: Red Oxide .NOW: Red colored ZC? | Michael Horowitz | Home Built | 9 | November 29th 05 09:41 AM |
colored airways? | Chris Hoffmann | Piloting | 13 | November 25th 03 12:08 PM |
