Parowan midair?
Old June 17th 10, 10:49 PM posted to rec.aviation.soaring
Bob Kuykendall
Default Parowan midair?
On Jun 17, 10:57*am, Greg Arnold wrote:
I don't understand how one glider could take off the wing of another
glider without suffering some damage itself.
I understand how one glider could take break the outboard portion of
another's wing and suffer only cosmetic damage. That's been done a
couple of times.
  #32
Old June 17th 10, 11:07 PM posted to rec.aviation.soaring
Mike the Strike
Some facts that might temper some of the speculation he
The collision happened about 75 miles north of Parowan over
mountainous terrain. This area is very low population and the risk to
people or structures on the ground was minimal. The nearest airport,
Fillmore, has been under construction and its status was unknown to
the pilots. The next nearest airport with a decent runway was Beaver,
which is only 20 miles or so north of Parowan. If I had been flying
south with a damaged but controllable glider, I probably would also
have opted to keep on to Parowan, as the ASH 26 did. (He calculated
that he had lost about 15% of performance and could still thermal
reasonably well.) There were many more people at Parowan (Beaver is
usually deserted) and much more chance of getting rapid assistance in
the event of a landing problem.
The Ventus pilot reported at this morning's meeting that, with the
benefit of hindsight, he probably should have terminated the task and
landed. I've polled a few competition pilots, and they are divided
almost equally between those who would carry on and those who would
land with an apparently undamaged ship.
There is no evidence of careless or reckless flying by either pilot -
it is likely just one of those events where their position and speed
reduced the pilots' visibility until it was too late. Neither pilot
saw the other until just before impact.
The FAA inspected both gliders today. The Ventus had two very small
compression marks in the nose that did not affect structural
integrity. The Ventus was thoroughly gone over by an experienced
glider repair guy, has a clean bill of health and is back in the air
and on course as I write this.
We may be unable to figure out exactly what happened, but a reasonable
guess is that the nose of the Ventus impacted the wing of the ASH 26
somewhere near midspan, pushing it down hard. This increased the
aerodynamic load on the wing to the point where the structure failed
five feet from the tip.
Mike the Strike
(Parowan weatherman)
  #33
Old June 17th 10, 11:23 PM posted to rec.aviation.soaring
flyingmr2
Thanks for the facts Mike. I'm just glad no one got hurt.
John Ackerson
  #34
Old June 17th 10, 11:45 PM posted to rec.aviation.soaring
Bruce Hoult
On Jun 18, 3:04*am, jb92563 wrote:
Sorry for sounding so harsh but winning a contest day is not even
close to winning the respect of your peers.
Do you actually know that they weren't, for example, on the last leg
of the task, with Parowan the closest practical landing point?
  #35
Old June 18th 10, 03:09 AM posted to rec.aviation.soaring
Eric Greenwell
On 6/17/2010 7:29 AM, jcarlyle wrote:
At this point we don't know all the facts regarding this incident.
I do know the pilot in the Ventus, though, and the adjectives
"irresponsible" and "reckless" are not ones that I would associate
with him. Let's consider the fact that the ASH-26 pilot flew 75 miles
with 5 feet of wing missing. That suggests that he felt there wasn't
any closer spot to safely put his aircraft down. And if this is true,
why castigate the Ventus pilot for not immediately landing?
The SSA report said the collision occurred 75 miles north of Parowan,
which would put at least one, maybe two good airports (Milford and
Beaver) in between, and two more even closer but not along the path to
Parowan.
Eric Greenwell - Washington State, USA (netto to net to email me)
  #36
Old June 18th 10, 03:45 AM posted to rec.aviation.soaring
Eric Greenwell
the pilots.
There is no NOTAM for Fillmore, and all the pilots in the contest should
have known that.
Beaver is 23 NM/26 miles from Parowan. From the approxiamate location of
the collision you describe, Richfield is 10 NM; Salina is 23 NM;
Junction is 36; Delta is 33 NM; Beaver is 43 NM; Milford is 44 NM.
These are all paved municipal airports with 4 having 75+ wide runways,
the others 60 feet wide; one is 4500 long (Parowan if 5000') and the
others are greater than 5000'. So, plenty of closer airports with good
runways.
I agree there would be lot more people at Parowan than these other
airports, and perhaps closer to the biggest hospital. Of course, if it's
the hospital you worry about, you should fly past Parowan and land at
Cedar City!
One strategy would be to contact contest ground and have them arrange
for emergency help to be at another airport, or even use 121.5 to
declare an emergency to ensure help arrived at the airport of choice. I
suspect an ambulance could arrive at any of them before it was necessary
to land there.
So, I think we are still left with the question: why did the pilot
choose to fly to Parowan with all these other, closer options? My best
guess is I would have opted for Parowan if the glider seemed stable,
controllable, and "obviously" able to make it to Parowan, but sitting
here, thinking it through, it doesn't seem as good an idea as landing
after arranging for help.
- "Transponders in Sailplanes - Feb/2010" also ADS-B, PCAS, Flarm http://tinyurl.com/yb3xywl
- "A Guide to Self-launching Sailplane Operation Mar/2004" Much of what you need to know tinyurl.com/yfs7tnz
  #37
Old June 18th 10, 05:00 AM posted to rec.aviation.soaring
Mike the Strike
On Jun 17, 7:45*pm, Eric Greenwell wrote:
On 6/17/2010 3:07 PM, Mike the Strike wrote: Some facts that might temper some of the speculation he
mountainous terrain. *This area is very low population and the risk to
people or structures on the ground was minimal. *The nearest airport,
the pilots.
have known that.
* *The next nearest airport with a decent runway was Beaver,
Junction is 36; Delta is 33 NM; Beaver is 43 NM; Milford is 44 NM. *
others are *greater than 5000'. So, plenty of closer airports with good
runways.
* *If I had been flying
have opted to keep on to Parowan, as the ASH 26 did. *(He calculated
reasonably well.) *There were many more people at Parowan (Beaver is
Cedar City!
* One strategy would be to contact contest ground and have them arrange
to land there.
- "Transponders in Sailplanes - Feb/2010" also ADS-B, PCAS, Flarmhttp://tinyurl.com/yb3xywl
The only attractive airfield options other than Parowan were Fillmore
and Beaver. These were in the I-15 corridor west of the mountains
which also has lots of landable fields. Crossing mountains and
deserts to the others makes no sense. Richfield, Salina and Junction
required traversing high remote mountain terrain to areas with poor
cellphone coverage. Delta is in the opposite direction in the middle
of the desert with absolutely no redeeming features and Milford
requires crossing a lower mountain range. Flying south towards home
was the smart option. Once you have Beaver made, it's a short hop to
Parowan - a no-brainer.
As I said, I most likely would have done the same.
Mike
  #38
Old June 18th 10, 01:49 PM posted to rec.aviation.soaring
soarpilot
the pilots.
have known that.
runways.
Cedar City!
to land there.
and Beaver. *These were in the I-15 corridor west of the mountains
which also has lots of landable fields. *Crossing mountains and
deserts to the others makes no sense. *Richfield, Salina and Junction
cellphone coverage. *Delta is in the opposite direction in the middle
requires crossing a lower mountain range. *Flying south towards home
was the smart option. *Once you have Beaver made, it's a short hop to
Mike
Both pilots' duty (as safe pilots) was to land at the closest
available site. Competition or not, if you get right down to the
brass tacks of things, the pilot who continued, if he passed by
available closer sights including RTB, was not demonstrating good
judgement nor safe practice. If the finish was the closest available,
then his flying to the extremes to compete with damage was simply poor
judgment. Competitions do not exempt us from safety and FAA
regulations. It's worth your life???
It is amazing to see how things are rationalized to promote accepting
mistakes as being something else, much less admired. Student pilots
read these posts as well as seasoned aviators. Lead by example, even
in competition. The Holy Grail doesn't exempt us from safe, lawful
flying practices. My two cents.
Tim
  #39
Old June 18th 10, 02:23 PM posted to rec.aviation.soaring
vaughn[_3_]
"soarpilot" wrote in message
available site.
While the safety aspects of this incident are interesting to us all, I
respectfully suggest that this line of discussion be closed down (at least for
now). Do you really want to multiply the problems of the pilots involved?
Vaughn
  #40
Old June 18th 10, 02:52 PM posted to rec.aviation.soaring
Mike Schumann
available site.
Vaughn
This is an opportunity for everyone to learn. This discussion serves a
very useful purpose in that regard.
What would be very helpful would be to actually see the flight traces of
both aircraft so we can understand how the actual midair happened. This
would be just as instructional for the soaring community as this
discussion over what the pilots did after the collision.
Mike Schumann
Midair near Minden Fred Soaring 52 September 1st 06 11:41 AM
Midair near Minden Jim Culp Soaring 0 August 29th 06 05:52 PM
Another midair! tango4 Soaring 3 April 27th 04 06:14 PM
Pix of two midair F-18s Pechs1 Naval Aviation 9 January 8th 04 02:40 PM
Midair in RI Martin Piloting 3 November 18th 03 10:29 PM
