121.5 ELTs banned
Old June 22nd 10, 12:09 PM posted to rec.aviation.soaring
T8
Default 121.5 ELTs banned
On Jun 21, 7:01*pm, brian whatcott wrote:
Since satellite cover has been withdrawn for 121.5
(High false alert rate, poor localization)
406.0 and 406.1 ELTs will be needed, following a recent FCC determination..
Brian W
So does that mean that we'll all have to disable the 121.5 MHz output
on our 406(.1) ELTs?
Our tax dollars busily at work, again.
121.5 is still used (exclusively, unless there are recent developments
I'm unaware of) for DF equipment by CAP. Don't suppose they were
consulted.
-Evan Ludeman / T8
Old June 22nd 10, 02:08 PM posted to rec.aviation.soaring
Peter Hermann[_3_]
Scott wrote:
to UHF, it will solve that problem. Until then, you'll either have to
interesting solution.
remains the question whether UHF has better
physical characteristics of range and quality.
....and what about affordability.
Old June 22nd 10, 02:37 PM posted to rec.aviation.soaring
5Z
On Jun 22, 12:48*am, Peter Hermann wrote:
How to test proper functioning of 406 MHz with 118 - 136 MHz radios?
The 406 ELT's still transmit on 121.5 as well. So the FCC wants to
get rid of 121.5 ONLY units.
-Tom
Old June 22nd 10, 03:32 PM posted to rec.aviation.soaring
jb92563
Brian W
Since the bereaucrats love so many rules, why not make another and let
Gliders and ballons use PLB's like SPOT since in our sport we often
have support crews that will monitor our progress in any case, making
SPOT a very convenient tool for us and our crews.
Ray.
Old June 22nd 10, 04:43 PM posted to rec.aviation.soaring
Darryl Ramm
Brian W
Ray.
First a SPOT is *not* a PLB. A PLB is a specific device regulated by
the FCC that transmits on 406 MHz to COAPAS-SARSAT (and also a 121.5
homing becon). It is essentially a lower power, smaller, manually
activated 406 MHz ELT.
SPOT is a private service run by Globalstar. The (multi-)government
service is COSPAS-SARSAT and that provides pretty impressive emergency
notification service for marine (EPIRB), Aviation (ELT) and private
(PLB) use. It makes no sense for he government to promote SPOT over
SARSAT-COSPAS.
There is no federal requirement for a glider to carry an ELT. There is
an apparently well intended but badly outdated SSA contest rule that
allows a CD to require gliders to carry an ELT. The issue I have with
that is a 406 MHz PLB is likely a much better SAR alerting device than
an old 121.5 MHz ELT even if you could properly mount one in the
glider. ELTs in light aircraft have an abysmal activation failure
record, and I suspect that will be much worse in gliders with many of
them improperly mounted and the lower impact energy of many glider
crashes. SPOT tracking is great, a 10 minute position report gives you
a simple area of uncertainty roughly about the same as an old SARSAT
121.5 MHz Doppler fix, but because you can usually use the glider path
to predict the flight direction it's actually better than that. At
least it's a good start for a search operation. If the pilot can
activate "911" on their SPOT and it gets a view of the Globalstar
satellites and a GPS fix then their final position is know as well. I
prefer the redundancy of havign both SPOT and a PLB and the technical
advantages of a PLB for that ultimate distress situation, but if I am
in distress can I'll be activating 911 on my SPOT and activating my
PLB. At a minimum the old SSA contest rule for ELTs could be modified
to allow a CD if they choose to require SPOT and/or "406 MHZ PLB or
ELT carriage".
Darryl
Old June 22nd 10, 04:54 PM posted to rec.aviation.soaring
Darryl Ramm
Brian W
I can see the 406 units providing better localization, but how do they
lower the high false alert rate? *I assume they still use a "G Switch"
to activate?
I would think that localization could be good on the 121.5 units if they
would be made to accept GPS data and transmit lat/long data when they go
off...
The 406 MHZ ELT or PLB may not have a GPS or may not be ale to get a
GPS fix, the position of the device is then determined by doppler
triangulation from the orbiting (non-geostationary) COASPAS-SARSAT
satellites. The higher frequency and higher spectral purity specs of
the 406 MHz transmitters enable better Doppler triangulation. A
relatively accurate Doppler fix takes several passes of these
satellites. The reception of the alert and the unique ELT or PLB
digital ID is immediate (via geostationary satellites). You get all
this by throwing away the crappy old 121.5 Mhz ELTs and replacing them
with a modern device.
If a 406 MHz PLB or ELT has a GPS unit (many low-cost PLBs do now)
then it transmits its GPS position if it has a fix and that is
immediately received by the geostationary COSPAS-SARASAT satellites.
The old 121.5Mhz devices are analog, 406 Mhz has many advantages over
121.5 MHz. The solution is to throw out the old junk and move to 406
MHz. 121.5MHz PLBs belong in a landfill, and the FCC is on the right
path here.
Darryl
Old June 22nd 10, 05:04 PM posted to rec.aviation.soaring
Darryl Ramm
The 406 ELT's still transmit on 121.5 as well. *So the FCC wants to
-Tom
And the self-test on the modern digital 406 MHz PLBs is relatively
sophisticated compared to older analog 121.5 Mhz units. You can also
listen to the 121.5 Mhz homing beacon part as Tom mentioned to make
sure that is working. But since they have a unique ID and often
tranmsit a quick GPS fix expect a visit from CAP or others if you
screw up the allowed testing.
Darryl
Old June 22nd 10, 05:23 PM posted to rec.aviation.soaring
Darryl Ramm
On Jun 22, 3:47*am, Scott wrote:
5Z wrote:
Just saw this in my inbox:
http://www.avweb.com/avwebflash/news..._202760-1.html
The Federal Communications Commission took the general aviation world
by surprise when it said in a recent report ...... "Were we to
permit continued marketing and use of 121.5 MHz ELTs ... it would
engender the risk that aircraft owners and operators would mistakenly
rely on those ELTs for the relay of distress alerts," the FCC says.
AOPA said today it is opposed to the rule change.
OK, maybe the satellites don't monitor the 121.5 units anymore, but
haven't commercial airliners been required to monitor 121.5 at all
times? *I would think there are enough flight routes in the USA that
almost all areas would be in range of an overflying jetliner to pick up
the signal...
You can Google for past discussions on r.a.s. where 121.5 MHz
monitoring has been discussed ad nauseum. Basically many airlines,
corporate flight departments, military (where equipped) and other
aircraft do guard 121.5 Mhz.
An aircraft monitoring 121.5 MHz may hear an 121.5 Mhz ELT - but if
that ELT is 121.5 MHz only it has no way to work out where the ELT is
located. You then have to launch a SAR operation to try to triangulate
that signal. We need to stop putting that silly workload on SAR
organizations and replace 121.5MHz ELTs with 406 MHz ELTs and PLBs.
Probably worth to keep reminding people that since a 406 MHZ ELT and
406 MHZ PLBs also transmit a 121.5 MHZ homing beacon if you think a
fellow pilot may be in distress you can listen for that sweep tone
sound on 121.5 Mhz. In the USA the PLB will also have a morse code
"P" (dit dah dah dit) added to the signal -- the FCC wanted that
because they thought there would be lots of false PLB activations,
that seems to have turned out not to be the case. At least that will
let you know id somebody has activated an ELT or PLB (the morse code
"P" will let you know for sure it is a PLB). Assuming the pilot is
smart and has a 406 MHZ PLB or ELT then their position has already/is
being worked out by COSPAS-SARSAT and your job is to contact the
county sheriff or similar authorities and let them know a pilot is in
distress and has activated their ELT or PLB.
Darryl
Old June 22nd 10, 05:36 PM posted to rec.aviation.soaring
Darryl Ramm
On Jun 22, 3:51*am, Scott wrote:
Darryl Ramm wrote:
I'd much rather have a manually activated PLB instead of an ELT -- and
personally I use a SPOT tacker in tracking mode to provide a rough
last-known position that does not rely in impact activation or being
physically able to active a PLB.
Darryl
Are these 406 units ONLY activated manually? *If so, what if a guy is
too busy flying the plane and forgets to activate the 406 unit? *If
that's the only way to set one off, the rescue rate may be less than the
121.5 units...
A 406 MHz ELT is impact activated. This requires the unit to be
properly mounted, the crash to have sufficient energy to trigger the
ELT and you also need apparently a lot of luck since correct
activation rates are pretty low (~20%?) in GA aircraft. And false
alarms (especially on older 121.5 Mhz ELTs) are high. But stats are
hard to get, and we need to be careful about comparing different
generation ELTs. I expect worse in many glider installs.
With a PLB post crash and/or landing you need to manually activate a
PLB. Trying to activate on in the air with their fold out antennas is
going to be difficult. If you can move then putting the unit flat on
the ground away form obstructions will likely produce a better signal
than many of the very bad ELT antenna installs I've seen in gliders.
Modern 406 MHz ELTs are required to be activated from a panel switch.
Older ELTs (without that switch) if they did not automatically
activate on impact may require more effort to get to and activate than
manually activating a PLB. If you cannot manually activate the PLB you
may be dead. While finding a fatal crash victim, especially with least
danger exposure to SAR personal, is important. A SPOT messenger with
tracking is a great start for that case.
There are SAR experts like Doug Ritter who keep trying to emphasize
that since ELT activation is so unreliable that a PLB is actually
better than an ELT. Carry a PLB first and maybe have an ELT as backup
for that, not the other way around.
Darryl
Old June 22nd 10, 09:13 PM posted to rec.aviation.soaring
Brian W
Ray.
SARSAT-COSPAS.
ELT carriage".
Darryl
SSA competition rules provide the option for contest organizers to
require these types of devices. Currently, if a glider is impact ELT
equipped, it will satisfy this requirement. Organizers may also permit
SPOT as an alternative to impact activated ELT's , but currently can't
require SPOT instead of impact actiaved ELT's. The rules continue to
evolve as capabilities change.
The Contest Committee is on record as strongly suggesting use of some
kind of safety device by all participants.
I currently have a 121.5 impact activated ELT, 406 PL, and SPOT.
Something should work.
UH
SSA Competition Rules Committee Chair
Use of 121.5 ELTs to be illegal in U.S. in about 60 days. Jim Logajan Piloting 15 July 3rd 10 09:23 PM
Anybody installing tri-band (406MHz) ELTs? Michelle P Instrument Flight Rules 0 July 4th 05 09:10 PM
Anybody installing tri-band (406MHz) ELTs? Michelle P General Aviation 0 July 4th 05 09:10 PM
406 ELTs: link featuring many models [email protected] Soaring 0 February 20th 05 09:36 PM
Airshows should be banned...Now! Tetherhorne P. Flutterblast Military Aviation 28 June 15th 04 02:43 AM
