On Jun 21, 7:01*pm, brian whatcott wrote:
Since satellite cover has been withdrawn for 121.5 (High false alert rate, poor localization) 406.0 and 406.1 ELTs will be needed, following a recent FCC determination.. Brian W So does that mean that we'll all have to disable the 121.5 MHz output on our 406(.1) ELTs? Our tax dollars busily at work, again. 121.5 is still used (exclusively, unless there are recent developments I'm unaware of) for DF equipment by CAP. Don't suppose they were consulted. -Evan Ludeman / T8 |
Scott wrote:
to UHF, it will solve that problem. Until then, you'll either have to interesting solution. remains the question whether UHF has better physical characteristics of range and quality. ....and what about affordability. |
On Jun 22, 12:48*am, Peter Hermann wrote:
How to test proper functioning of 406 MHz with 118 - 136 MHz radios? The 406 ELT's still transmit on 121.5 as well. So the FCC wants to get rid of 121.5 ONLY units. -Tom |
On Jun 21, 4:01*pm, brian whatcott wrote:
Since satellite cover has been withdrawn for 121.5 (High false alert rate, poor localization) 406.0 and 406.1 ELTs will be needed, following a recent FCC determination.. Brian W Since the bereaucrats love so many rules, why not make another and let Gliders and ballons use PLB's like SPOT since in our sport we often have support crews that will monitor our progress in any case, making SPOT a very convenient tool for us and our crews. Ray. |
On Jun 22, 7:32*am, jb92563 wrote:
On Jun 21, 4:01*pm, brian whatcott wrote: Since satellite cover has been withdrawn for 121.5 (High false alert rate, poor localization) 406.0 and 406.1 ELTs will be needed, following a recent FCC determination. Brian W Since the bereaucrats love so many rules, why not make another and let Gliders and ballons use PLB's like SPOT since in our sport we often have support crews that will monitor our progress in any case, making SPOT a very convenient tool for us and our crews. Ray. First a SPOT is *not* a PLB. A PLB is a specific device regulated by the FCC that transmits on 406 MHz to COAPAS-SARSAT (and also a 121.5 homing becon). It is essentially a lower power, smaller, manually activated 406 MHz ELT. SPOT is a private service run by Globalstar. The (multi-)government service is COSPAS-SARSAT and that provides pretty impressive emergency notification service for marine (EPIRB), Aviation (ELT) and private (PLB) use. It makes no sense for he government to promote SPOT over SARSAT-COSPAS. There is no federal requirement for a glider to carry an ELT. There is an apparently well intended but badly outdated SSA contest rule that allows a CD to require gliders to carry an ELT. The issue I have with that is a 406 MHz PLB is likely a much better SAR alerting device than an old 121.5 MHz ELT even if you could properly mount one in the glider. ELTs in light aircraft have an abysmal activation failure record, and I suspect that will be much worse in gliders with many of them improperly mounted and the lower impact energy of many glider crashes. SPOT tracking is great, a 10 minute position report gives you a simple area of uncertainty roughly about the same as an old SARSAT 121.5 MHz Doppler fix, but because you can usually use the glider path to predict the flight direction it's actually better than that. At least it's a good start for a search operation. If the pilot can activate "911" on their SPOT and it gets a view of the Globalstar satellites and a GPS fix then their final position is know as well. I prefer the redundancy of havign both SPOT and a PLB and the technical advantages of a PLB for that ultimate distress situation, but if I am in distress can I'll be activating 911 on my SPOT and activating my PLB. At a minimum the old SSA contest rule for ELTs could be modified to allow a CD if they choose to require SPOT and/or "406 MHZ PLB or ELT carriage". Darryl |
On Jun 22, 3:41*am, Scott wrote:
brian whatcott wrote: Since satellite cover has been withdrawn for 121.5 (High false alert rate, poor localization) 406.0 and 406.1 ELTs will be needed, following a recent FCC determination. Brian W I can see the 406 units providing better localization, but how do they lower the high false alert rate? *I assume they still use a "G Switch" to activate? I would think that localization could be good on the 121.5 units if they would be made to accept GPS data and transmit lat/long data when they go off... The 406 MHZ ELT or PLB may not have a GPS or may not be ale to get a GPS fix, the position of the device is then determined by doppler triangulation from the orbiting (non-geostationary) COASPAS-SARSAT satellites. The higher frequency and higher spectral purity specs of the 406 MHz transmitters enable better Doppler triangulation. A relatively accurate Doppler fix takes several passes of these satellites. The reception of the alert and the unique ELT or PLB digital ID is immediate (via geostationary satellites). You get all this by throwing away the crappy old 121.5 Mhz ELTs and replacing them with a modern device. If a 406 MHz PLB or ELT has a GPS unit (many low-cost PLBs do now) then it transmits its GPS position if it has a fix and that is immediately received by the geostationary COSPAS-SARASAT satellites. The old 121.5Mhz devices are analog, 406 Mhz has many advantages over 121.5 MHz. The solution is to throw out the old junk and move to 406 MHz. 121.5MHz PLBs belong in a landfill, and the FCC is on the right path here. Darryl |
On Jun 22, 6:37*am, 5Z wrote:
On Jun 22, 12:48*am, Peter Hermann wrote: How to test proper functioning of 406 MHz with 118 - 136 MHz radios? The 406 ELT's still transmit on 121.5 as well. *So the FCC wants to get rid of 121.5 ONLY units. -Tom And the self-test on the modern digital 406 MHz PLBs is relatively sophisticated compared to older analog 121.5 Mhz units. You can also listen to the 121.5 Mhz homing beacon part as Tom mentioned to make sure that is working. But since they have a unique ID and often tranmsit a quick GPS fix expect a visit from CAP or others if you screw up the allowed testing. Darryl |
On Jun 22, 3:47*am, Scott wrote:
5Z wrote: Just saw this in my inbox: http://www.avweb.com/avwebflash/news..._202760-1.html The Federal Communications Commission took the general aviation world by surprise when it said in a recent report ...... "Were we to permit continued marketing and use of 121.5 MHz ELTs ... it would engender the risk that aircraft owners and operators would mistakenly rely on those ELTs for the relay of distress alerts," the FCC says. AOPA said today it is opposed to the rule change. OK, maybe the satellites don't monitor the 121.5 units anymore, but haven't commercial airliners been required to monitor 121.5 at all times? *I would think there are enough flight routes in the USA that almost all areas would be in range of an overflying jetliner to pick up the signal... You can Google for past discussions on r.a.s. where 121.5 MHz monitoring has been discussed ad nauseum. Basically many airlines, corporate flight departments, military (where equipped) and other aircraft do guard 121.5 Mhz. An aircraft monitoring 121.5 MHz may hear an 121.5 Mhz ELT - but if that ELT is 121.5 MHz only it has no way to work out where the ELT is located. You then have to launch a SAR operation to try to triangulate that signal. We need to stop putting that silly workload on SAR organizations and replace 121.5MHz ELTs with 406 MHz ELTs and PLBs. Probably worth to keep reminding people that since a 406 MHZ ELT and 406 MHZ PLBs also transmit a 121.5 MHZ homing beacon if you think a fellow pilot may be in distress you can listen for that sweep tone sound on 121.5 Mhz. In the USA the PLB will also have a morse code "P" (dit dah dah dit) added to the signal -- the FCC wanted that because they thought there would be lots of false PLB activations, that seems to have turned out not to be the case. At least that will let you know id somebody has activated an ELT or PLB (the morse code "P" will let you know for sure it is a PLB). Assuming the pilot is smart and has a 406 MHZ PLB or ELT then their position has already/is being worked out by COSPAS-SARSAT and your job is to contact the county sheriff or similar authorities and let them know a pilot is in distress and has activated their ELT or PLB. Darryl |
On Jun 22, 3:51*am, Scott wrote:
Darryl Ramm wrote: I'd much rather have a manually activated PLB instead of an ELT -- and personally I use a SPOT tacker in tracking mode to provide a rough last-known position that does not rely in impact activation or being physically able to active a PLB. Darryl Are these 406 units ONLY activated manually? *If so, what if a guy is too busy flying the plane and forgets to activate the 406 unit? *If that's the only way to set one off, the rescue rate may be less than the 121.5 units... A 406 MHz ELT is impact activated. This requires the unit to be properly mounted, the crash to have sufficient energy to trigger the ELT and you also need apparently a lot of luck since correct activation rates are pretty low (~20%?) in GA aircraft. And false alarms (especially on older 121.5 Mhz ELTs) are high. But stats are hard to get, and we need to be careful about comparing different generation ELTs. I expect worse in many glider installs. With a PLB post crash and/or landing you need to manually activate a PLB. Trying to activate on in the air with their fold out antennas is going to be difficult. If you can move then putting the unit flat on the ground away form obstructions will likely produce a better signal than many of the very bad ELT antenna installs I've seen in gliders. Modern 406 MHz ELTs are required to be activated from a panel switch. Older ELTs (without that switch) if they did not automatically activate on impact may require more effort to get to and activate than manually activating a PLB. If you cannot manually activate the PLB you may be dead. While finding a fatal crash victim, especially with least danger exposure to SAR personal, is important. A SPOT messenger with tracking is a great start for that case. There are SAR experts like Doug Ritter who keep trying to emphasize that since ELT activation is so unreliable that a PLB is actually better than an ELT. Carry a PLB first and maybe have an ELT as backup for that, not the other way around. Darryl |
On Jun 22, 11:43*am, Darryl Ramm wrote:
On Jun 22, 7:32*am, jb92563 wrote: On Jun 21, 4:01*pm, brian whatcott wrote: Since satellite cover has been withdrawn for 121.5 (High false alert rate, poor localization) 406.0 and 406.1 ELTs will be needed, following a recent FCC determination. Brian W Since the bereaucrats love so many rules, why not make another and let Gliders and ballons use PLB's like SPOT since in our sport we often have support crews that will monitor our progress in any case, making SPOT a very convenient tool for us and our crews. Ray. First a SPOT is *not* a PLB. A PLB is a specific device regulated by the FCC that transmits on 406 MHz to COAPAS-SARSAT (and also a 121.5 homing becon). It is essentially a lower power, smaller, manually activated 406 MHz ELT. SPOT is a private service run by Globalstar. The (multi-)government service is COSPAS-SARSAT and that provides pretty impressive emergency notification service for marine (EPIRB), Aviation (ELT) and private (PLB) use. It makes no sense for he government to promote SPOT over SARSAT-COSPAS. There is no federal requirement for a glider to carry an ELT. There is an apparently well intended but badly outdated SSA contest rule that allows a CD to require gliders to carry an ELT. The issue I have with that is a 406 MHz PLB is likely a much better SAR alerting device than an old 121.5 MHz ELT even if you could properly mount one in the glider. ELTs in light aircraft have an abysmal activation failure record, and I suspect that will be much worse in gliders with many of them improperly mounted and the lower impact energy of many glider crashes. SPOT tracking is great, a 10 minute position report gives you a simple area of uncertainty roughly about the same as an old SARSAT 121.5 MHz Doppler fix, but because you can usually use the glider path to predict the flight direction it's actually better than that. At least it's a good start for a search operation. If the pilot can activate "911" on their SPOT and it gets a view of the Globalstar satellites and a GPS fix then their final position is know as well. I prefer the redundancy of havign both SPOT and a PLB and the technical advantages of a PLB for that ultimate distress situation, but if I am in distress can I'll be activating 911 on my SPOT and activating my PLB. At a minimum the old SSA contest rule for ELTs could be modified to allow a CD if they choose to require SPOT and/or "406 MHZ PLB or ELT carriage". Darryl SSA competition rules provide the option for contest organizers to require these types of devices. Currently, if a glider is impact ELT equipped, it will satisfy this requirement. Organizers may also permit SPOT as an alternative to impact activated ELT's , but currently can't require SPOT instead of impact actiaved ELT's. The rules continue to evolve as capabilities change. The Contest Committee is on record as strongly suggesting use of some kind of safety device by all participants. I currently have a 121.5 impact activated ELT, 406 PL, and SPOT. Something should work. UH SSA Competition Rules Committee Chair |
Use of 121.5 ELTs to be illegal in U.S. in about 60 days. | Jim Logajan | Piloting | 15 | July 3rd 10 09:23 PM |
Anybody installing tri-band (406MHz) ELTs? | Michelle P | Instrument Flight Rules | 0 | July 4th 05 09:10 PM |
Anybody installing tri-band (406MHz) ELTs? | Michelle P | General Aviation | 0 | July 4th 05 09:10 PM |
406 ELTs: link featuring many models | [email protected] | Soaring | 0 | February 20th 05 09:36 PM |
Airshows should be banned...Now! | Tetherhorne P. Flutterblast | Military Aviation | 28 | June 15th 04 02:43 AM |
