Hello All,
I have a 1969 Cherokee 140b that is going thru the annual inspection with a new A&P this year. The airplane suffered damage the left wing when it hit a deer on takeoff in 1972. It was repaired and has flown ever since. The problem is the new A&P insists that the wings must be removed and inspected by him or he won't sign off on the inspection. He plans on charging me at least $1500 per wing. He says it will take about 32 hours per wing for labor. I think he is just running up the bill. Is this necessary at all? Should take that long to inspect? I'd appreciate any wisdom you guys might share. Thanks |
On Jun 24, 10:46*am, Bruce wrote:
Hello All, I have a 1969 Cherokee 140b that is going thru the annual inspection with a new A&P this year. The airplane suffered damage the left wing when it hit a deer on takeoff in 1972. It was repaired and has flown ever since. The problem is the new A&P insists that the wings must be removed and inspected by him or he won't sign off on the inspection. He plans on charging me at least $1500 per wing. He says it will take about 32 hours per wing for labor. I think he is just running up the bill. Is this necessary at all? Should take that long to inspect? I'd appreciate any wisdom you guys might share. Thanks If it was declared airworthy after repairs from the accident and annotated as such on the airframe logs, then I would be looking for another A&P unless (big one at this) there is a recurring AD requiring some type of inspection. I can't imagine this though myself but take this thought with a grain of salt since I used to own a Sundowner and I am not an A&P. |
On Jun 24, 11:46*am, Bruce wrote:
The airplane suffered damage to the left wing when it hit a deer on takeoff in 1972. It was repaired and has flown ever since. I find it implausable that you hit a flying deer. Let me guess, it was Christmas eve. --- Mark |
On Thu, 24 Jun 2010 08:46:07 -0700 (PDT), Bruce
wrote: Hello All, I have a 1969 Cherokee 140b that is going thru the annual inspection with a new A&P this year. The airplane suffered damage the left wing when it hit a deer on takeoff in 1972. It was repaired and has flown ever since. The problem is the new A&P insists that the wings must be removed and inspected by him or he won't sign off on the inspection. He plans on charging me at least $1500 per wing. He says it will take about 32 hours per wing for labor. I think he is just running up the bill. Is this necessary at all? Should take that long to inspect? I'd appreciate any wisdom you guys might share. Thanks 1. A&Ps don't do annuals. IAs do. 2. Who signed off the repair on the damage? Did the signer have A&P after their name? 3. Is there any indication in the repair documentation that repetitive inspections should be required. 4. Is there any indication of the repair not working, like buckled skin, cracks in the skin, puffed up paint around rivet heads? 5. Is there a reason that BOTH wings need to come off? Was there any damage to the starboard wing? If the IA can't give you a reason why (s)he wants to remove the wings if the above 5 check out OK, I'd start looking for another IA. Googling the FAA database sorted by zip code ought to be a good place to start. Jim A&P, IA, CFI (A&G) |
On 6/24/2010 10:46 AM, Bruce wrote:
Hello All, I have a 1969 Cherokee 140b that is going thru the annual inspection with a new A&P this year. The airplane suffered damage the left wing when it hit a deer on takeoff in 1972. It was repaired and has flown ever since. The problem is the new A&P insists that the wings must be removed and inspected by him or he won't sign off on the inspection. He plans on charging me at least $1500 per wing. He says it will take about 32 hours per wing for labor. I think he is just running up the bill. Is this necessary at all? Should take that long to inspect? I'd appreciate any wisdom you guys might share. Thanks Did you inquire about costs before the Annual? If the A&P gave you a cost excluding unexpected findings, then you still have the option of asking for the standard annual to be completed at the agreed price, and having another A&P execute the extra work. It is reasonable for an A&P to not want to sign off an annual if he does not like what he sees. It is your option (ALWAYS) to choose who executes work on your aircraft. It can be awkward if there is only one A&P with AI on a given field, so that can feel like being held to ransom, no doubt. You caqn probably find someone to travel in to inspect, at a pinch. Good luck! Brian W |
On 6/25/2010 5:52 PM, RST Engineering wrote:
On Thu, 24 Jun 2010 08:46:07 -0700 (PDT), wrote: Hello All, I have a 1969 Cherokee 140b that is going thru the annual inspection with a new A&P this year. The airplane suffered damage the left wing when it hit a deer on takeoff in 1972. It was repaired and has flown ever since. The problem is the new A&P insists that the wings must be removed and inspected by him or he won't sign off on the inspection. He plans on charging me at least $1500 per wing. He says it will take about 32 hours per wing for labor. I think he is just running up the bill. Is this necessary at all? Should take that long to inspect? I'd appreciate any wisdom you guys might share. Thanks 1. A&Ps don't do annuals. IAs do. IAs sign off annuals. Owners or A&Ps can contribute to the annual, though one or two FAA inspectors seem to hold a different opinion. 2. Who signed off the repair on the damage? Did the signer have A&P after their name? 3. Is there any indication in the repair documentation that repetitive inspections should be required. 4. Is there any indication of the repair not working, like buckled skin, cracks in the skin, puffed up paint around rivet heads? 5. Is there a reason that BOTH wings need to come off? Was there any damage to the starboard wing? If the IA can't give you a reason why (s)he wants to remove the wings if the above 5 check out OK, I'd start looking for another IA. Googling the FAA database sorted by zip code ought to be a good place to start. Jim A&P, IA, CFI (A&G) |
| Thread Tools | |
| Display Modes | |
| US Air Force Museum Batch 2 [17/64] - Lockheed VC-140B Jetstar DSC_0142.jpg (1/1) | Indrek | Aviation Photos | 0 | April 25th 10 02:47 AM |
| US Air Force Museum Batch 2 [16/64] - Lockheed VC-140B DSC_0138.jpg (1/1) | Indrek | Aviation Photos | 0 | April 25th 10 02:47 AM |
| Piper Cherokee wing root seals - just an fyi | Bob Noel | Owning | 1 | May 7th 06 02:12 PM |
