Substandard Italian workmanship renders first 787s unsafe
Old June 25th 10, 10:10 PM posted to rec.aviation.piloting,rec.travel.air
Mxsmanic
Default Substandard Italian workmanship renders first 787s unsafe
Boeing has discovered that the Italian firm to which it subcontracted
construction of tail assemblies isn't doing the work correctly, putting the 23
aircraft it has already built at risk:
http://travel.usatoday.com/flights/p...-found/97983/1
No surprise here. When you allow Third World companies to built vital parts to
your airplane, you should take for granted that there will be potentially
dangerous defects. That's the consequence of trying to be politically correct.
Old June 25th 10, 10:30 PM posted to rec.aviation.piloting,rec.travel.air
Italy isn't concidered a third world country by anyone but you.
Jim Pennino
Remove .spam.sux to reply.
Old June 25th 10, 11:02 PM posted to rec.aviation.piloting,rec.travel.air
JohnT[_3_]
"Mxsmanic" wrote in message
the 23
parts to
correct.
Lots of people would consider that Italian technology is at least as good as
anything emanating from Chicago.
JohnT
Old June 25th 10, 11:08 PM posted to rec.aviation.piloting,rec.travel.air
Sancho Panza
"JohnT" wrote in message
the 23
parts to
correct.
as anything emanating from Chicago.
And that is in which world?
Old June 25th 10, 11:19 PM posted to rec.aviation.piloting,rec.travel.air
Mxsmanic
JohnT writes:
Then Boeing must have picked the wrong Italian partner. And this appears to be
an issue with workmanship, not technology or design. The tails were simply not
put together correctly, implying unqualified, careless, or lazy workers.
If I recall correctly, this isn't the first time I've read about an Italian
company screwing things up.
There are a number of classic stereotypes concerning European cultures, and
unfortunately many of them have a strong basis in fact.
I wonder why Boeing put anything in Italy. It's not like the Italians have any
strong airlines that would be buying dozens of 787s, and if all Boeing cared
about was price, they could find cheaper suppliers in other countries.
Flaps_50!
http://travel.usatoday.com/flights/p...halts-787-test...
Where in the article does it say the Italian parts are substandard? As
I read it it's an assembly problem (shimming and bolt torque) which
takes place in the US...
Cheers
Old June 25th 10, 11:21 PM posted to rec.aviation.piloting,rec.travel.air
Mxsmanic
Flaps_50! writes:
Yes. The defects are in the assembly, not the hardware itself (as I understood
the article). Thus, unqualified or careless workers, inadequate QC, etc.,
which, unfortunately, is exactly what I'd expect from an average Italian
supplier.
Old June 25th 10, 11:44 PM posted to rec.aviation.piloting,rec.travel.air
a[_3_]
On Jun 25, 6:21*pm, Mxsmanic wrote:
Flaps_50! writes:
supplier.
The article says nothing about defects in the unit assembled in Italy.
It does say the issue is associated with how it had been attached,
torqued, and shimmed to the correct position when it had been attached
to the 'next assembly up'.
Old June 26th 10, 01:07 AM posted to rec.aviation.piloting,rec.travel.air
george
When I saw the header I had to look and once again mixedup is scamming
the group with his hatred of aviation and those associated with it..
Old June 26th 10, 01:48 AM posted to rec.aviation.piloting,rec.travel.air
Mxsmanic
a writes:
Incorrect assembly is a defect.
"Aircraft Unsafe, Do Not Fly" T8 Soaring 2 April 13th 10 08:24 PM
Relief Tube Housing - Unsafe Tim Taylor Soaring 12 June 18th 09 09:30 PM
renders [email protected] Restoration 0 April 25th 04 03:35 AM
Your Italian Consultant, your italian business opportunity Techenquire.com Products 2 January 12th 04 08:08 AM
Your Italian Consultant, your italian business opportunity Techenquire.com Aviation Marketplace 0 January 5th 04 02:10 PM
