Navigation strategy on a short flight
Old June 26th 10, 05:59 PM posted to rec.aviation.piloting,rec.aviation.student
Mxsmanic
Default Navigation strategy on a short flight
From Phoenix to Casa Grande in a Cessna 152 in my sim:
The aircraft contains only a single VOR, without DME, and an ADF.
There are a couple of VORs nearby, including PXR at Sky Harbor, and Stanfield
about 8 miles southwest of Casa Grande (connected by V105/J92). There's also a
NDB at Chandler, about 19 miles north.
What is the most elegant way to navigate from KPHX to KCGZ?
I thought it would be good form to follow V105, so after a west departure from
Phoenix, I flew east to join the PXR 163 radial. It was hard to judge my
distance from the VOR, though, as the desert looks pretty monotonous, and
there are numerous small airfields in the area. After flying for a while, I
decided to tune the CHD NDB and try to figure out an intersection that would
place me over the field. Constant adjustment of the ADF card for this purpose
was awkward, though, and did not improve my confidence that I was going the
right way. The 152 is very pokey and I always have the impression that I've
gone further than I actually have.
Finally I got nervous and turned east to pick up the PXR148 radial. I had
flight following and Center knew my destination, and ATC asked me what I was
doing after I made the turn, since apparently I had been headed straight
towards the airport. I explained and when ATC told me where to look for the
airport, I turned that way, and after a minute or two I spotted hangars at
Casa Grande.
This does not seem very elegant to me. What is the best way to navigate this
route under these conditions?
Exclude pilotage, since this was an exercise in navigation by instruments
despite being VFR in VMC. (If I had been using pilotage, I would have simply
followed Interstate 10, which practically leads to the ramp, but I
deliberately avoided looking for the highway.)
I conducted the flight mostly at 3500 feet, although I suppose that's not very
important here.
Old June 26th 10, 10:39 PM posted to rec.aviation.piloting,rec.aviation.student
Mike Ash
Mxsmanic wrote:
Exclude pilotage
You should really put this at the top of your message next time, instead
of after 7 paragraphs of less relevant detail. Given that the two
airports are less than 32nm apart, that there are numerous landmarks
along the way, and that even dead reckoning will do a fine job of
depositing you close enough to your destination, I'm sure that everyone
wading through your seven previous paragraphs was repeatedly thinking,
"LOOK OUT THE WINDOW!" There can be merit in rejecting the obvious
solution, but if you're going to do it, you should do it right at the
start.
Some more concrete advice: pilotage really does work, very well. If you
want to practice other techniques, a stopwatch and a look at your
airspeed indicator will help you avoid that odd problem of always having
the impression that you've gone further than you actually have. Finally,
although there are indeed a lot of small airfields in the area, a quick
glance at the sectional reveals that virtually all of them have runways
pointed in different directions, so a quick way to figure out which one
you're looking at would be to read the gigantic numbers painted on the
threshold and compare with what's on the chart.
Oh, and one more thing: VFR-worthy GPS units are really cheap, and help
with this sort of problem immensely. An imaginary VFR-worthy GPS is
probably *really* cheap, and these days is probably more realistic than
going without one.
If any of this wasn't already blindingly obvious to you, then I suggest
your vast experience with aircraft simulation may have taught you less
about flying than you think it has.
Mike Ash
Radio Free Earth
Broadcasting from our climate-controlled studios deep inside the Moon
Old June 26th 10, 11:52 PM posted to rec.aviation.piloting,rec.aviation.student
Flaps_50!
Casa Grande.
Use your compass / DI and allow for the drift expected from winds at
your altitude.
Cheers
Old June 27th 10, 12:08 AM posted to rec.aviation.piloting,rec.aviation.student
Casa Grande.
important here.
A thorough pilot would fill out a flight planning form, fly a magnetic
heading of 145 degrees corrected for the forcast winds aloft, note the
time of passage and deviation from Gila River Memorial to correct for actual
winds, and do that again at the 1734' hill about 6 miles north of KCGZ.
The pilot then would know at all times where he was and how long to get
to the next waypoint as long as his compass and clock were working and
wouldn't be wandering around looking for radials.
The magnetic compass and the clock are valid navigational instruments.
The most elegent way would be GPS direct.
Jim Pennino
Remove .spam.sux to reply.
Old June 27th 10, 03:29 AM posted to rec.aviation.piloting,rec.aviation.student
YOU GOT NERVOUS????????????
WHY?????????? You are simulating a flight in MSFS!!!!!!!!!
YOU ARE VFR. YOU ANSWERED YOUR OWN QUESTION.
LOOK OUT THE SIMULATED WINDOW!!!!!!!!!!!!!
DOESN'T matter what the exercise was, YOU WERE SIMULATING A VFR FLIGHT
in MSFS. LOOK OUT YOUR SIMULATED WINDOW
Old June 27th 10, 06:08 PM posted to rec.aviation.piloting,rec.aviation.student
Mike Adams[_1_]
Mxsmanic wrote:
What is the best way to navigate this route under these conditions?
If no GPS, no pilotage, and no dead reckoning, I would capture the 148
radial from PXR and fly it outbound until I saw the field.
Old June 27th 10, 07:38 PM posted to rec.aviation.piloting,rec.aviation.student
Mxsmanic
Mike Adams writes:
OK, thanks. I guess I might have been complicating the navigation more than
necessary. Too many IFR flights, perhaps.
Old June 27th 10, 08:52 PM posted to rec.aviation.piloting,rec.aviation.student
Mike Adams writes:
More like too much time playing the Microsoft Flight Simulator game and
zero time doing any actual flying.
Jim Pennino
Navigation flight planning during training Andrew Sarangan Piloting 52 March 21st 07 05:49 PM
The Strategy For Iraq! W. D. Allen Naval Aviation 0 June 23rd 06 09:30 PM
"Strategy and Air Power" - AEI [email protected] Naval Aviation 0 March 4th 05 04:01 PM
New strategy in fighting AL-Queda Leadfoot Naval Aviation 2 September 1st 03 12:40 AM
New strategy in fighting AL-Queda Leadfoot Military Aviation 0 August 29th 03 02:26 AM
