OLC League
Old July 6th 10, 04:47 PM posted to rec.aviation.soaring
Grider Pirate
Default OLC League
One of the members of the LVVSA logs a lot of good flights:
http://www.onlinecontest.org/olc-2.0...t=olc&pi=35239
His doesn't have a CFR, but does have an OLC valid logger. His
flights aren't counted for our club for some reason I can't figure
out. I can't find anything in the rules that would explain why his
flights aren't counted. Any help here?
Old July 6th 10, 05:03 PM posted to rec.aviation.soaring
Darryl Ramm
Default OLC League
On Jul 6, 8:47*am, Grider Pirate wrote:
One of the members of the LVVSA logs a lot of good flights:http://www.onlinecontest.org/olc-2.0....html?sp=2010&...
His doesn't have a CFR, but does have an OLC valid logger. *His
out. *I can't find anything in the rules that would explain why his
flights aren't counted. *Any help here?
Try reading the OLC rules again. You've got to read the whole document
because they bury stuff in different places. e.g. the following is
_not_ in the OLC-League section...
"For the OLC-league and for the FAI-OLC (OLC triangle flights
according FAI rules) only IGC approved recorders are allowed."
Darryl
Old July 6th 10, 05:14 PM posted to rec.aviation.soaring
Grider Pirate
Default OLC League
Darryl
Thanks Darryl,
This is where RTE(ntire)FM applies.
Old July 9th 10, 01:05 AM posted to rec.aviation.soaring
Ramy
Default OLC League
Darryl
Yeah, one of those OLC rules which don't make any sense.
You can't score if you don't have an igc approved recorder, but you
can easily get scored for your tow and even aeroretrieve if you so
desire...
Ramy
Old July 9th 10, 01:32 AM posted to rec.aviation.soaring
Greg Arnold
Default OLC League
Darryl
desire...
Ramy
Also, if you have one of the "legacy" CAI recorders, there is no
security at all once you have converted the CAI file to an IGC file.
New OLC League Rule! Mark628CA Soaring 1 May 19th 10 08:55 PM
OLC League - stuck on round 19? Uncle Fuzzy Soaring 1 September 23rd 09 03:32 AM
SSA-OLC League scoring Mark628CA Soaring 2 May 30th 06 06:19 PM
SSA-OLC League Update Doug Haluza Soaring 1 May 3rd 06 06:08 AM
Rocket Racing League John Ousterhout Home Built 34 October 7th 05 06:30 AM
