#21
On Jul 20, 10:09*pm, Bruce wrote:
On 2010/07/20 10:44 PM, bildan wrote: On Jul 20, 1:59 pm, Eric *wrote: On 7/20/2010 12:24 PM, bildan wrote: On Jul 20, 8:35 am, EvValentin808 * *wrote: Can anyone give me a list of forgiving sailplanes out there. I know some like the Schweizers, *Rudolf Kaiser's designs(Schleicher K-series) and the Discus... Any other to list? -- EvValentin808 No doubt this thread will have a long run. My view is that all gliders are 'forgiving' - if flown by a qualified pilot. *OTOH, unqualified pilots can wreck any glider no matter how 'forgiving'. In any event, 'forgiving' handling qualities has little to do with the safety of the pilot. *Any glider, no matter how 'forgiving' can be flown into a very unforgiving Earth. *They will still collide with mountains and other gliders. *Trees and other obstacles can still wreck them. *The number of accidents with poor handling qualities as the primary cause is virtually non-existent. I don't agree at all. A qualified pilot can compensate for "unforgiving" qualities, but that doesn't make the glider "forgiving". Some gliders have very poor glide path control, some spin easily, with little warning, and don't recover quickly. Put the CG too far aft, and most gliders are likely not "forgiving". Right, and the only thing that makes these gliders 'forgiving' is pilot skill. *My experience is the difference between the worst and best handling glider is fairly small. *After all, they have to go through the same certification process. *(Experimental glider excluded, of course.) Even a qualified pilot can be distracted, or tired, or hypoxic, or dehydrated, and the outcome is likely to be much better in a "forgiving" glider than one that isn't. You really think mere benign handling qualities will save this guy? He's likely to fly his 'forgiving' glider into a tree. What's REALLY unforgiving is nature. *Make enough mistakes and 'ol Mother Nature will kill or maim you. *She's merciless. * Her goal is just cleaning the gene pool. I don't think the "Mother Nature" is the main factor in most glider accidents. Look at how many happen near the airport and in good weather. |
Hi Derek
You are correct - I am amplifying the difference. As I said I actually prefer the handling on the Cirrus. BUT - I learned, on the Cirrus, to fly with a very light touch on the stick. There is virtually no force feedback on pitch. Especially in some of the big rough thermals we get here, you tend to get a wing dropping quite easily. As Bob commented - it is a pilot skill thing. I can, and do, fly the Cirrus quite close to the limit and get the best climb rates etc. When I do that I am aware that the departure from controlled flight is quite rapid - and if I am not paying attention I will have a wing drop. Recovery is instant - just unload the wing. Smoothly approached there is a distinct turbulent warning - especially as the wake hits the elevator. So - the Cirrus is a precise aircraft to fly, but can be more work than some others. e.g. you can't take your hand off the stick for more than a second or so (Phugoid is divergent and the elevator is effectively mounted on a gimbal), and will reliably reward ham fisted insensitive control inputs with a spin. The point I was trying to make is that some aircraft require more attention. Which can contribute to impaired capability - which is less safe. For what it is worth. I have serial Std Cirrus number 57. Which is a little different - it was imported by the Schempp agent specifically for the purpose of flying records. So - It has lower washout on the tips, (standard on early models) - the components (wings/fuselage etc) were selected at the factory for being heavy. - It has a tail wheel and is set up with the CG quite far aft. I have to accept that as the heavy fuselage limits the amount of weight I can put in the nose without exceeding max non-lifting weight with me in it. - Said heroic early owners damaged both wingtips, and broke the fuselage (twice) and elevator - so lots of repairs at various stages. Maybe she is not 100% straight. - Currently in the workshop getting the second paddles added to the airbrakes and winglets to improve the low speed behaviour, and a cosmetic make over to make her pretty again. Bruce --- news://freenews.netfront.net/ - complaints: --- |
On Jul 21, 9:56*am, Bruce wrote:
Hi Derek You are correct - I am amplifying the difference. As I said I actually prefer the handling on the Cirrus. BUT - I learned, on the Cirrus, to fly with a very light touch on the stick. There is virtually no force feedback on pitch. Especially in some of the big rough thermals we get here, you tend to get a wing dropping quite easily. As Bob commented - it is a pilot skill thing. I can, and do, fly the Cirrus quite close to the limit and get the best climb rates etc. When I do that I am aware that the departure from controlled flight is quite rapid - and if I am not paying attention I will have a wing drop. Recovery is instant - just unload the wing. Smoothly approached there is a distinct turbulent warning - especially as the wake hits the elevator. So - the Cirrus is a precise aircraft to fly, but can be more work than some others. e.g. you can't take your hand off the stick for more than a second or so (Phugoid is divergent and the elevator is effectively mounted on a gimbal), and will reliably reward ham fisted insensitive control inputs with a spin. The point I was trying to make is that some aircraft require more attention. Which can contribute to impaired capability - which is less safe. I remember that my briefing for my first flight in a Std Cirrus included the words "If it feels as though the controls are not connected up, don't worry about it". It does indeed have very light stick forces, but this makes it less tiring to fly and you only have to think a turn and it will do it. I can fly my Cirrus all day, but I get tired after flying something with heavier controls, especially big two-seaters, after about 3 or 4 hours. Derek C |
#24
On 2010/07/21 12:57 PM, Derek C wrote:
On Jul 21, 9:56 am, wrote: Hi Derek You are correct - I am amplifying the difference. As I said I actually prefer the handling on the Cirrus. BUT - I learned, on the Cirrus, to fly with a very light touch on the stick. There is virtually no force feedback on pitch. Especially in some of the big rough thermals we get here, you tend to get a wing dropping quite easily. As Bob commented - it is a pilot skill thing. I can, and do, fly the Cirrus quite close to the limit and get the best climb rates etc. When I do that I am aware that the departure from controlled flight is quite rapid - and if I am not paying attention I will have a wing drop. Recovery is instant - just unload the wing. Smoothly approached there is a distinct turbulent warning - especially as the wake hits the elevator. So - the Cirrus is a precise aircraft to fly, but can be more work than some others. e.g. you can't take your hand off the stick for more than a second or so (Phugoid is divergent and the elevator is effectively mounted on a gimbal), and will reliably reward ham fisted insensitive control inputs with a spin. The point I was trying to make is that some aircraft require more attention. Which can contribute to impaired capability - which is less safe. I remember that my briefing for my first flight in a Std Cirrus included the words "If it feels as though the controls are not connected up, don't worry about it". It does indeed have very light stick forces, but this makes it less tiring to fly and you only have to think a turn and it will do it. I can fly my Cirrus all day, but I get tired after flying something with heavier controls, especially big two-seaters, after about 3 or 4 hours. Derek C Indeed - I hate the feeling of holding something embedded in a pot of porridge. I have had the moment half way up the winch launch of feeling there are no controls connected. It happens after a day spent wrestling ancient two seaters around. Then you get in the Cirrus and everything is so light. --- news://freenews.netfront.net/ - complaints: --- |
#25
On Jul 20, 10:35*am, EvValentin808
wrote: Can anyone give me a list of forgiving sailplanes out there. I know some like the Schweizers, *Rudolf Kaiser's designs(Schleicher K-series) and the Discus... Any other to list? -- EvValentin808 Ignore all the nastiness below, and get yourself a late-model LS-4. Earlier models almost as nice but the automatic hookups are more forgiving. You'll love it ! Best Regards, Dave |
#26
I agree with Dave.
Get an LS4. It has such a solid feeling when flying and is very very stable. The airbrake/gear control interlock is a nice feature also. Guy |
#27
I'll chime in for the ASW-19. I'd tried to get a LS-4, but couldn't
find one at the time. The ASW-19 was described to me by a multi-time US champion as 98% of the LS-4 at 75% of the price. The only potential downside is the CG hook for aerotowing, but truthfully, I never had a problem with it. If you can't find a ASW-19 or a LS-4, and you can swing the extra cash, there are a number of LS-8s for sale on Wings & Wheels right now. I can attest that they are nice, easy to fly aircraft, too, plus they have incredible performance for when you start flying contests. -John |
Please ID 3 sailplanes | Every time | Soaring | 4 | August 20th 08 09:34 PM |
don't try to prepare potentially while you're forgiving with a rough string | [email protected] | Piloting | 0 | August 13th 07 04:01 AM |
Repost from Feb. 2002: " forgiving training heli" by Bob Barbanes | [email protected] | Rotorcraft | 2 | January 30th 06 08:23 PM |
New Products for Sailplanes. | [email protected] | Soaring | 6 | July 4th 05 09:27 AM |
50+:1 15m sailplanes | Paul T | Soaring | 92 | January 19th 04 01:59 AM |
