Stability augmentation promises to give you even less control
Old August 8th 10, 03:17 AM posted to rec.aviation.piloting
Default Stability augmentation promises to give you even less control
Mxsmanic wrote:
writes:
Nope, and that is a really stupid question.
So what's the threshold of trivial?
Yet more really stupid blather.
Jim Pennino
Remove .spam.sux to reply.
  #93
Old August 8th 10, 10:11 PM posted to rec.aviation.piloting
Jim Logajan
"Stephen!" wrote:
Gemini wrote in
There's something about the riding mower that I enjoy. Not
sure what it is. I'd have to agree that mowing is acceptable
when a riding type is used. Especially if its got a big
2 or 3 bag catcher strapped to the back.
Bah... To hell with bags. Full Mulch is the only way to go.
We bought a 3 bag catcher a few years back, and while I find bagging makes
for a nicer result, I bought a mulcher kit for the lawn tractor a couple
months ago. Still haven't used it yet (Oregon has a dry summer climate, so
as the summer wears on mowing isn't needed as much. And when it does need
mowing there is no need to bag or mulch.)
With regard to aviation and this thread:
I will need to increase the size of the blades (currently only 48 inch
width) and engine horsepower (currently just 20 HP) on my lawn tractor to
make it a hovering mower. Instead of a lever to adjust the height of the
mower blades, I'll need some way to adjust the height of the tractor above
ground (maybe replace the mower attachment lever with a collective?)
Haven't figured out how I'll handle slopes. Clearly a stability
augmentation system of some kind will be needed.
I'm pretty sure it'll weigh more than allowed for ultralights, so I may
need to get a helicopter license to legally mow. Will I need to equip it
with two seats to allow CFIs do BFRs? Or can they simply observe from a
safe distance while I show I can safely perform cross-wind mows, collision
avoidance of trees, flowers, and fences; simulated emergencies such as
mowing over things that make it go "kerchunk!"?
  #94
Old August 8th 10, 10:28 PM posted to rec.aviation.piloting
Peter Dohm
"Jim Logajan" wrote in message
"Stephen!" wrote:
Gemini wrote in
I've heard that a/c which are not routinely capable of achieving altitude
above a certain low limit are exempt from requlation by the FAA.
But, that stability augmentation might still be a good idea on the slopes!
Peter ;-))))))))))))
  #95
Old August 8th 10, 10:43 PM posted to rec.aviation.piloting
Dudley Henriques[_2_]
On Aug 8, 5:11*pm, Jim Logajan wrote:
"Stephen!" wrote:
Gemini wrote in
n:
* Bah... *To hell with bags. *Full Mulch is the only way to go.
From my yard work handbook; Rider Mower ABS, GOOD.............Rider
Mower
Stabaug..........Good..............Kerchunk....... .........BAD!! :-))
D
  #96
Old August 8th 10, 11:20 PM posted to rec.aviation.piloting
a[_3_]
"Stephen!" wrote:
Gemini wrote in
n:
Mower
Stabaug..........Good..............Kerchunk....... .........BAD!! *:-))
D
Mr Dudley, should you achieve lift from your mower blades you;d
probably have to be inverted -- remember the blades are designed to
create an updraft around the grass, so you best get a full harness
rather than just a seat belt. I suspected inverted flight close over
the lawn violates a regulation or two as well.
I'm not sure how you'd get enough speed to go inverted -- you may need
a launch ramp and half a snap roll. I'll be looking for this on you
tube,
  #97
Old August 9th 10, 12:05 AM posted to rec.aviation.piloting
"Stephen!" wrote:
Gemini wrote in
n:
Mower
D
tube,
Sounds like a good plan to me. A 1/2 snap sounds like the way to go.
Somehow I get the feeling that I'll have to be inverted in the seat
with the mower right side up however for the blades to work
properly.:-))
DH
  #98
Old August 9th 10, 01:10 AM posted to rec.aviation.piloting
Jim Logajan
Mower
D
Hmmm - does it say how bad? Is it considered Controlled Flight into Terrain
(CFIT) or Controlled Mow into Things (CMIT)? Would it help if I filed a
ASRS after such an incident? It's not like it is intentional or anything.
Sure, I may let the grass get a tad high before mowing it, causing me to
mow under marginal visual mowing conditions, but there are always
extenuating circumstances.
  #99
Old August 9th 10, 01:17 AM posted to rec.aviation.piloting
Mower
D
My lifelong dream is to get one of those mowers that mows
automatically while I sit up on the porch in air conditioned comfort
with a Jack Daniels in one mitt and a remote control joystick for the
mower in the other. :-)
DH
  #100
Old August 9th 10, 02:54 AM posted to rec.aviation.piloting
a[_3_]
Mower
D
DH
With a suitably modified GPS enabled autopilot (some tractors are
large farms actually have these) you could be spared the labor of
working the joystick. Once programmed it would fly (well, taxi) a
suitable pattern, upwind, crosswind, downwind, base, and upwind again
and mow down those blades that intrude into a bug's airspace.
I claim extra credit for aviation content in the above.
Promises to be a good show this year! PLMerite Aviation Photos 0 May 3rd 08 12:43 PM
Stability variation WingFlaps Piloting 2 April 28th 08 03:45 AM
Towing stability studies Dan G Soaring 27 February 21st 08 08:38 PM
Tow vehicle -- electronic stability control Greg Arnold Soaring 4 June 8th 06 12:31 PM
Atmospheric stability and lapse rate Andrew Sarangan Piloting 39 February 11th 05 05:34 AM
