#131
On Aug 11, 12:19*pm, Greg Arnold wrote:
On 8/11/2010 12:15 PM, Ramy wrote: Maybe I got lost in details, but I don't see much difference (except the thermaling specific algorithms) between our needs and GA needs, at least the slower "low end" GA which does not already use more sofisticated traffic alert equipment than PCAS. If it is the best solution for us, why isn't it for them? If they buy PCAS, why wouldn't they buy PowerFlarm? PowerFlarm may have fancy software to try to take into account that gliders often do not fly straight. *However, PowerFlarm certainly can handle the simpler situation where planes do fly straight, and so I would think Ramy is right -- PowerFlarm would be very useful to GA. A couple of points, some restated.. The PowerFLARM does no support popular portable or fixed dispays used in the GA market. That may be an issue for some pilots. That is also something FLARM could address in future (with software and/or hardware changes). To have the flarm protocol be useful you have to have significant adoption. And I just do not see why or how that would happen in the GA market. I could see examples offered before of pockets of possible interest (news/rescue helicopters, fire bombers/spotters, logging helicopters). To have the ADS-B part work you need an ADS-B transmitter. For the low- end part of the GA market in the USA most likely to adopt ADS-B data- out (voluntarily or to meet mandate requirements) typically have Mode C transponders today. For those lower-end aircraft I expect UAT devices as presumably they appear (and gain TSO approval) to be appealing. It is not clear there will be a separate UAT transmitter market. I expect to see transceivers and receivers. For more modern aircraft with Mode S transponders I expect is more likely for pilots to upgrade their Mode S to 1090ES data out and at the low-end of that group the PowerFLARM as an add-on receiver could be interesting if the issue of display compatibility does not matter. But in that market of more modern GA aircraft you rapidly run into cockpits where owners/pilots are more likely to want to deploy something that integrates with their current display and other toys even if not IFR certified. More complex cockpits also raise some interesting questions of device compatibility (ability to correctly set the capability code bits for ADS-B) that seem to be an open question and it is not clear that all these GA modern glass panel systems will necessarily be compatible with portable ADS-B receivers (this is mostly a USA issue). ADS-B is a slow painful process so we need to really see what happens. If a PowerFLARM was priced close to an Zaon MRX then I'd say its a no-brainer for any low-end GA pilot to adopt it. The PCAS feature in the PowerFLARM is a nice feature that other 1090ES receivers are not providing but I'm sure that will sway much of the GA market, esp. compared to display compatibility etc. The USA market, with its dual-link and UAT options is a bit different than Europe. Europe has mandatory Mode S transponders and is going 1090ES data-out only. And I expect the PowerFLARM to be relatively more appealing to lower-end GA pilots there than in the USA. I am not saying a GA pilot cannot or should not use a PowerFLARM I am trying to point out that as the product looks today it may be a significantly less compelling product in the USA GA market than some glider pilots seem to be assuming. If Flarm/Butterfly want to target the USA GA market there are some obvious things they could do in future. It is a however a very compelling product for many of us now... Darryl |
#132
What do you guys suspect the threat display would look like on the
Powerflarm for a non-flarm threat? A ring all the way around to show range and an altitude differential? As opposed to the small triangles showing location, direction and altitude differential? Just curious. Anyone know? |
#133
On Aug 11, 12:05*pm, Darryl Ramm wrote:
It can't apply to PCAS (Mode C/S) because the PowerFLARM has no idea of the direction of the threat, Is that somewhere in the specs and I missed it. There is no reason a passive tranponder detection system cannot be directional. It does require a directional antenna system though. (ref Zaon XRX). If position was only resolved to one of 4 quadrants though the alerting could not be as good as for FLARM targets, but it could be much better than the ZAON MRX that many of us are used to. Maybe an 8 sector directional antenna is being dreamed of. It could also be much better than the MRX if a specific target (such as the tug) could be tagged as "no threat". Even better if the "no threat tag" was automatically cleared if there was a significant change in relative altitude or direction of the tagged target. Maybe they are aware of the fact that gliders may use a unique squawk that distinguishes them from VFR aircraft and will provide different threat alerting. Until there are some hard specs and real hardware with integrated and functional software, PowerFLARM could just be a marketeers dream. Somebody please say you have actually seen one working and shoot me down. Andy |
#134
From the LX website regarding the Powerflarm. See the first paragraph
and second bullet point in the summary. Power Flarm is designed to give precise warning of the relative positions of ADS-B transmitting aircraft and of aircraft transmitting Flarm information. Its Mode-C warning gives both distance (accuracy some 100m) and relative altitude (accuracy 25ft/50ft depending on XPDR). It utilizes the same warning technology and motion prediction used in FLARM. This means it calculates hazard-levels as a function of many parameters and not only distance. (Its algorithms continually calculate and forecast possible flight vectors and matches them to probabilities) Warnings are given visually and acoustically depending on the severity of the hazard. The display and user-interface is designed to minimize distraction. In summary it detects: •other ADS-B equipped aircraft without PowerFLARM •other Mode-C/S XPDR equipped aircraft ( range but not direction) •other aircraft with normal FLARM compatible systems And all the time it transmits its own Flarm data making you conspicuous to other Flarm equipped aircraft |
#135
I would think it can still calculate whether a target is converging or
not (range/altitude differential). Wouldn't it need multiple xpndr replies identifying the same target? I would guess such a thing would be pretty difficult in a gaggle though. I have sent an email inquiring about just how the different sources are dealt with in terms of predicting threats. Hopefully they'll respond. |
#136
On Aug 11, 1:32*pm, Andy wrote:
On Aug 11, 12:05*pm, Darryl Ramm wrote: It can't apply to PCAS (Mode C/S) because the PowerFLARM has no idea of the direction of the threat, Is that somewhere in the specs and I missed it. *There is no reason a passive tranponder detection system cannot be directional. *It does require a directional antenna system though. (ref *Zaon XRX). If position was only resolved to one of 4 quadrants though the alerting could not be as good as for FLARM targets, but it could be much better than the ZAON MRX that many of us are used to. *Maybe an 8 sector directional antenna is being dreamed of. *It could also be much better than the MRX if a specific target (such as the tug) could be tagged as "no threat". *Even better if the "no threat tag" was automatically cleared if there was a significant change in relative altitude or direction of the tagged target. Maybe they are aware of the fact that gliders may use a unique squawk that distinguishes them from VFR aircraft and will provide different threat alerting. Until there are some hard specs and real hardware with integrated and functional software, PowerFLARM could just be a marketeers dream. Somebody please say you have actually seen one working and shoot me down. Andy The PowerFLARM definitely does not have a directional 1090MHz antenna. Chasing directional PCAS type things like the XRX is likely a waste of time given ADS-B's arrival. I don't expect to see any other of these directional PCAS systems from any vendors. Darryl |
#137
On Aug 11, 1:58*pm, Westbender wrote:
I would think it can still calculate whether a target is converging or not (range/altitude differential). Wouldn't it need multiple xpndr replies identifying the same target? I would guess such a thing would be pretty difficult in a gaggle though. I have sent an email inquiring about just how the different sources are dealt with in terms of predicting threats. Hopefully they'll respond. Those of us who fly say with a Zaon MRX seem to be pretty impressed with its ability to give you a heads up of traffic but PCAS is inherently so imprecise that to talk about it in the same sentence as the high precision FLARM protocol is kind of a stretch. But I think the idea of including PCAS in the PowerFLARM is very good. In a crowded gaggle of gliders equipped with Mode C transponders your PCAS unit will likely just not work in a useful way. There will be substantial overlap of replies from transponders in the Gaggle, an effect called syncronous garbling. If the gliders in the Gaggle have Mode S transponders and are being interrogated by a Mode S interrogator (like most radar and TCAS units) this effect will be greatly minimized. Good receivers can handle some partial overlap but a crowded gaggle of Mode C transponders is going to throw your PCAS for a real loop. It is this sort of reason that I know PCAS cannot reliably work and why I expect the PowerFLARM to have a way to just turn down the PCAS alert. Its just such an obvious thing, and given how smart the Flarm guys seem to be not something I am worried about. In many remote areas (like where many glider contests are held?) the interrogation rates may be low (typical SSR radar interrogate in a burst ever 5 or 12 second rotation). You may get more rapid interrogations for overflying aircraft TCAS etc. All it might take for a threat aircraft is a slight change in relative antenna orientation and the threat may appear closer. Think of two gliders thermalling in different thermals near each other--with the received power of their transponder signals jumping all over the place. This is just not a foundation on which you can do much more than beep when another threat appears to be with several miles and some altitude window. The transmitted encoder altitude is really the only thing you know reliably, and even that can have issues with Mode A and Mode C signal aliasing (I'm surprised most PCAS units work as well as they do). Alright now I'm really beyond fed up listening to myself. Darryl |
#138
On Aug 11, 4:51*pm, Darryl Ramm wrote:
On Aug 11, 1:58*pm, Westbender wrote: I would think it can still calculate whether a target is converging or not (range/altitude differential). Wouldn't it need multiple xpndr replies identifying the same target? I would guess such a thing would be pretty difficult in a gaggle though. I have sent an email inquiring about just how the different sources are dealt with in terms of predicting threats. Hopefully they'll respond. Those of us who fly say with a Zaon MRX seem to be pretty impressed with its ability to give you a heads up of traffic but PCAS is inherently so imprecise that to talk about it in the same sentence as the high precision FLARM protocol is kind of a stretch. But I think the idea of including PCAS in the PowerFLARM is very good. In a crowded gaggle of gliders equipped with Mode C transponders your PCAS unit will likely just not work in a useful way. There will be substantial overlap of replies from transponders in the Gaggle, an effect called syncronous garbling. If the gliders in the Gaggle have Mode S transponders and are being interrogated by a Mode S interrogator (like most radar and TCAS units) this effect will be greatly minimized. Good receivers can handle some partial overlap but a crowded gaggle of Mode C transponders is going to throw your PCAS for a real loop. It is this sort of reason that I know PCAS cannot reliably work and why I expect the PowerFLARM to have a way to just turn down the PCAS alert. Its just such an obvious thing, and given how smart the Flarm guys seem to be not something I am worried about. In many remote areas (like where many glider contests are held?) the interrogation rates may be low (typical SSR radar interrogate in a burst ever 5 or 12 second rotation). You may get more rapid interrogations for overflying aircraft TCAS etc. All it might take for a threat aircraft is a slight change in relative antenna orientation and the threat may appear closer. Think of two gliders thermalling in different thermals near each other--with the received power of their transponder signals jumping all over the place. This is just not a foundation on which you can do much more than beep when another threat appears to be with several miles and some altitude window. The transmitted encoder altitude is really the only thing you know reliably, and even that can have issues with Mode A and Mode C signal aliasing (I'm surprised most PCAS units work as well as they do). Alright now I'm really beyond fed up listening to myself. Darryl Thanks Darryl, I really appreciate the info. |
#139
On 8/11/2010 12:19 PM, Greg Arnold wrote:
On 8/11/2010 12:15 PM, Ramy wrote: Maybe I got lost in details, but I don't see much difference (except the thermaling specific algorithms) between our needs and GA needs, at least the slower "low end" GA which does not already use more sofisticated traffic alert equipment than PCAS. If it is the best solution for us, why isn't it for them? If they buy PCAS, why wouldn't they buy PowerFlarm? PowerFlarm may have fancy software to try to take into account that gliders often do not fly straight. However, PowerFlarm certainly can handle the simpler situation where planes do fly straight, and so I would think Ramy is right -- PowerFlarm would be very useful to GA. Do we have any idea of the percentage of GA using a PCAS like the MRX? I'm of the impression it's a small percentage, smaller than the percentage of gliders equipped with PCAS. I suspect a lot of power pilots think they have the collision situation covered with their transponder and Flight Following. A few that fly where there are a lot of gliders, like the Reno area, might be interested in a Flarm unit. -- Eric Greenwell - Washington State, USA (netto to net to email me) - "Transponders in Sailplanes - Feb/2010" also ADS-B, PCAS, Flarm http://tinyurl.com/yb3xywl - "A Guide to Self-launching Sailplane Operation Mar/2004" Much of what you need to know tinyurl.com/yfs7tnz |
#140
On 8/11/2010 11:28 AM, Andrzej Kobus wrote:
Let's take a real life example. Last year I flew in Sports Nationals in Elmira. I had PCAS with me. The first day after I released and started climbing with a bunch of other gliders many of them equipped with transponders I had to switch my PCAS off because of the quantity of warnings. It was useless in that scenario. Did you turn off the power, or just press the "mute" button? I've muted mine when circling with another transponder-equipped glider so the audio didn't annoy me, but the display continued to show the altitude difference. That seemed useful to me. -- Eric Greenwell - Washington State, USA (netto to net to email me) - "Transponders in Sailplanes - Feb/2010" also ADS-B, PCAS, Flarm http://tinyurl.com/yb3xywl - "A Guide to Self-launching Sailplane Operation Mar/2004" Much of what you need to know tinyurl.com/yfs7tnz |
| IGC FLARM DLL | [email protected] | Soaring | 1 | March 25th 08 12:27 PM |
| WinPilot ADV & PRO 9.0b Flarm | Richard[_1_] | Soaring | 15 | February 6th 08 10:49 PM |
| FLARM | Robert Hart | Soaring | 50 | March 17th 06 12:20 AM |
| Flarm | Mal | Soaring | 4 | October 19th 05 09:44 AM |
| FLARM | John Galloway | Soaring | 9 | November 27th 04 08:16 AM |
