Another Blow to Airbus
Old August 16th 10, 03:48 AM posted to rec.aviation.piloting
a[_3_]
Default Another Blow to Airbus
On Aug 14, 6:16*pm, "Flaps_50!" wrote:
On Aug 9, 12:41*am, a wrote:
John Smith wrote
"After being buffeted by the wake from a jet ahead of them, the pilots
made several sharp rudder movements." Note the key word "several".
"Several" sharp rudder movements may break any aircraft at any speed,
especially big ones, as any pilot sould know, especially after the
American Airlines crash from 2001.
True enough, but absent any conflicting factual information, if the
NTSB is indicating the controls are too sensitive and airframe damage
can happen even when special training is given. I'd call it a design
weakness or flaw.
The Airbus is a fly by wire airplane, pilot inputs for all intents are
'suggestions' to the software, and we've read elsewhere of accidents
caused because the software chose to ignore those inputs. A reasonable
person might find, then, that inputs that might damage the airframe
would be moderated by the programming. A jury made up of such
reasonable persons might be inclined to think harshly of Airbus.
If I was the plaintiff in such a lawsuit I'd ask for a change of venue
to, oh, Seattle comes to mind.
Typical litigous mentality. The plane passed certification but any
pilot can break a plane. Control surfaces have the power to break
wings, tailplanes and rudders -fact. I believe NASA had to use a test
plane recently to examine the increase in tail fin load induced by
rapid reversal of rudder input after significant yaw had developed and
the found the structural load could be more twice the design load -if
I remember correctly.
Cheers
Litigation is very much a factor in aviation, as well as in too many
other areas of human activity. I can assure you it is a real world
factor in our management decisions: is it not in yours?
  #52
Old August 16th 10, 03:53 AM posted to rec.aviation.piloting
a[_3_]
On Aug 14, 6:56*pm, "Flaps_50!" wrote:
On Aug 12, 1:42*pm, a wrote:
The good news is, it's rare to the best of my
knowledge that moving the controls to the extremes,. either fast or
slow, will uncover a problem, or that they fail in flight.
Err, I don't think you mean that.
Cheers
I have not done much research on the matter but can not recall a
control surface failure or linkage to a control surface of the sort
that might be be uncovered during run up as leading to an in flight
failure. One can fly a GA airplane into extreme turbulence and have
structural damage, but that possibility would not be uncovered in a
run up either.
So yes, I did mean what I typed. If there are factual examples of in
flight failures of control linkages that might have been uncovered
during run up I'd be happy to learn of them.
  #53
Old August 19th 10, 10:49 AM posted to rec.aviation.piloting
Flaps_50!
Cheers
run up either.
Ok, but that's not what you wrote.
Cheers
To blow or not to blow... Dallas Piloting 50 February 15th 08 12:57 PM
Another blow for Airbus AJ Piloting 1 December 9th 06 08:35 PM
oil blow out IO-360 Robert M. Gary Piloting 18 July 17th 06 04:44 PM
oil blow out IO-360 Robert M. Gary Owning 18 July 17th 06 04:44 PM
Blow-Proofs jls Home Built 0 June 2nd 04 05:02 AM
