Peschges VP 6 --V
Old August 19th 10, 08:44 PM posted to rec.aviation.soaring
soarski[_2_]
Default Peschges VP 6 --V
Hello
I am still using a VP 6 but it seems to have lost it's separate GPS
receiver which is a dinosaur anyway.
The set seems to still work alright only it does not get any Satelites
to play with etc.
I was wondering whether any body has tried to drive it with a
Volkslogger? The VP 6 supplies its receiver with
12 V I guess, so the VL would have to get its 4.5 volts from somewhere
else, one would make a special cable.
There is also the question about the GPS protokol?
Possibly there is a GPS receiver 12V that one could adapt. I do not
want to go to the Euro market.
Another way would be to find a VP 8 that someone has lying around
collecting dust. That one would hook right in.
Anyone?
Dieter
Old August 19th 10, 08:59 PM posted to rec.aviation.soaring
Tim Mara
VolksLogger running 4.5V??
most of your GPS receivers run from the gliders 12V (14V) systems
tim
Please visit the Wings & Wheels website at www.wingsandwheels.com
"soarski" wrote in message
Hello
to play with etc.
Anyone?
Dieter
__________ Information from ESET NOD32 Antivirus, version of virus
signature database 5380 (20100819) __________
The message was checked by ESET NOD32 Antivirus.
http://www.eset.com
__________ Information from ESET NOD32 Antivirus, version of virus signature database 5380 (20100819) __________
http://www.eset.com
jcarlyle
The Volkslogger manual states the power requirement is 9.5 VDC up to
24 VDC. The protocol is standard NMEA, using a 3 wire serial
connection at 4800 baud. The pin-out for either the round or the RJ-45
connectors used on the Volksloggers is he
http://www.cumulus-soaring.com/garre...kverbinder.pdf
If you're handy with a soldering iron and can get your hands on a
Volkslogger, you should be flying in about 30 minutes.
-John
On Aug 19, 3:44 pm, soarski wrote:
Hello
to play with etc.
Anyone?
Dieter
Old August 19th 10, 10:09 PM posted to rec.aviation.soaring
Walter[_2_]
Hi Dieter,
if you understand German, you will find all informatopn the
http://www.segelflug.de/cgi-bin/wwwt...vc=1#Post69501
and the
If not I will try to translate it.
VL with 4800 baud should work.
Walter
Hello
to play with etc.
Anyone?
Dieter
Peschges VP4 to sell? Peter Hermann Soaring 0 March 27th 08 10:05 AM
manual for VP4 H Peschges [email protected] Soaring 0 August 25th 07 08:36 AM
peschges vp 3 Kevin Burns Soaring 0 June 17th 07 11:20 PM
Peschges VP9 Istvan Csonka Soaring 1 January 5th 05 08:53 AM
Peschges VP3 Problems Nick Gilbert Soaring 7 December 2nd 03 04:12 AM
