Dick Johnson's wing flattening jig?
Old August 21st 10, 10:55 PM posted to rec.aviation.soaring
ryanglover1969[_2_]
Default Dick Johnson's wing flattening jig?
On Aug 21, 1:12*pm, JJ Sinclair wrote:
As a matter of fact I purchased the Wng Flattener from Dick just
before his untimley death. It is necessary to flatten both the top and
bottom of both wings to get maximum perormance increase. You must
carefully remove all wax and contaminates before placing your wings
into the molds. Then plug it into 220 (3-phase) current and select 75
amps to start with. If after an hour the wings arent flat then turn
the selector up to max (100 amps) and wait another hour. I charge
$1000 per side, so both sides of both wings will run you $4000 with a
10% discount for FNG's
Dick also sold me the rights to his Wing Stretcher which will run you
$1000 per meter. Expencive, but one customer is ecstatic over his 30
meter Libelle!
JJ
Very interesting indeed!
Dick Johnson's wing flattening jig? ryanglover1969[_2_] Soaring 17 August 23rd 10 03:07 PM
Dick Johnson Clint Soaring 4 June 6th 09 10:40 PM
Dick Johnson is gone. Burt Compton - Marfa Soaring 23 July 27th 08 05:38 PM
Dick Johnson's FTE of the Discus-2 Flavio Formosa Soaring 1 January 18th 07 03:18 PM
Richard Johnson's Report on the Sparrowhawk skysailor Soaring 10 February 21st 05 09:47 AM
