Dick Johnson's wing flattening jig?
Old August 22nd 10, 04:09 PM posted to rec.aviation.soaring
Brad[_2_]
Default Dick Johnson's wing flattening jig?
On Aug 22, 7:43*am, JJ Sinclair wrote:
JJ- You're not spillin' the beans on th Mark IV version with the 4th
order reflex compensation are you? I thought we agreed to keep it to
ourselves till 2015.
Are you selling out on me?
UH
At the time of his death, Dick Johnson was also working on a ground-
loop prevent'er and I have his concept drawings. The heart of the
system is a gyro that instantly detects lateral motion while on the
ground. The unit is armed via an oleo-strut micro switch and directs
high pressure air to the opposite wing (ground-loop detected to left =
air directed to right wing). A 2 inch plastic sleeve is mounted inside
both wings with a 10 pound sliding slug that will instantly fly from
the root rib to the wing tip just as soon as the gyro detects a ground-
loop developing. I believe the concept to be sound and I am presently
working on a method of stopping the slug when it reaches the wing tip.
Stat tuned,
JJ
JJ,
Be careful, Homeland Security and the TSA might want to know more
about that Sliding Slug, AKA a projectile-aircraft mounted-airborne
delivery system!
Brad
Old August 22nd 10, 04:31 PM posted to rec.aviation.soaring
Grider Pirate
UH
Stat tuned,
JJ
JJ,
delivery system!
Brad- Hide quoted text -
- Show quoted text -
Lighten up Brad. The PAMADS is an entirely different project. What
you NEED to worry about is the stuff they're NOT talking about.
Old August 22nd 10, 05:11 PM posted to rec.aviation.soaring
UH
Stat tuned,
JJ
I still think the servo version we were talking about solves this
problem. The motion control program will provide the required decel
rate and permit accel motion and displacement to properly respond to
rate of lateral motion.
Did you review the patent disclosure I sent on this?
Should not have made public till disclosure is signed and prelim
application has been filed.
UH
Old August 22nd 10, 05:15 PM posted to rec.aviation.soaring
Brad[_2_]
UH
working on a method of stopping the slug when it reaches the wing tip..
Stat tuned,
JJ
JJ,
delivery system!
Lighten up *Brad. *The PAMADS is an entirely different project. What
hmmmm......................what I hope is in the works and is top
secret is the TTCTCT.......which is code for.........tube trailer
conversion to Cobra top.................I'll pay top dollar for that
one, on the down low tho folks.............
Brad
Old August 22nd 10, 11:04 PM
Walt Connelly Walt Connelly is offline
Senior Member
First recorded activity by AviationBanter: Aug 2010
UH
Stat tuned,
JJ
Can any of you tell me if the square of the hypotenuse is really equal to the sum of the square of the two adjacent sides or is it just really, really close?
Walt
Old August 23rd 10, 06:01 AM posted to rec.aviation.soaring
Bob Kuykendall
On Aug 22, 3:04*pm, Walt Connelly
to the sum of the *square of the two adjacent sides or is it just
I so rarely meet right angles that are truly 90.00 degrees, so I
usually use the more general form of c^2=a^2+b^2-2ab*cosC.
Old August 23rd 10, 12:05 PM
Senior Member
I thank you for reminding me of those college math courses with a foreign born prof who had such an accent that I questioned if he was speaking English.
Just wondering if the Dick Johnson wing flattener could be modified to be an SGS 1-34 nose uncrusher, tail straightener, wing undenter and canopy unshatterer?
Walt
Walt
Old August 23rd 10, 03:07 PM posted to rec.aviation.soaring
On Aug 23, 7:05*am, Walt Connelly Walt.Connelly.
really, really close?-
speaking English.
be an SGS 1-34 nose uncrusher, tail straightener, wing undenter *and
canopy unshatterer?
Walt
Walt
Walt Connelly
Possibly useful for first 3 but not much use for last.
Pie R round--cornbread square
UH
Dick Johnson Clint Soaring 4 June 6th 09 10:40 PM
Dick Johnson is gone. Burt Compton - Marfa Soaring 23 July 27th 08 05:38 PM
Dick Johnson's FTE of the Discus-2 Flavio Formosa Soaring 1 January 18th 07 03:18 PM
Richard Johnson's Report on the Sparrowhawk skysailor Soaring 10 February 21st 05 09:47 AM
Dick Tracy C J Campbell Piloting 3 December 24th 04 02:18 AM
