tow rope
Old August 24th 10, 01:38 AM posted to rec.aviation.soaring
tazman
Default tow rope
I'm looking for sources of tow rope in the USA. Can you help?
Thanks,
Doug
Old August 24th 10, 02:54 AM posted to rec.aviation.soaring
ray conlon
Default tow rope
Thanks,
Doug
Try wingsandwheels.com
Old August 24th 10, 03:31 AM posted to rec.aviation.soaring
Craig Reinholt
Default tow rope
I'm partial to fisherman & marine supply stores for rope. They have an
abundance of styles, strengths, and composition. Also, they usually
are reasonably priced.
Old August 24th 10, 03:42 AM posted to rec.aviation.soaring
BTiz
Default tow rope
Thanks,
Doug
We get our rope from the local "rigging" store.
600ft spool of 5/8 3 ply ploy pro makes three 200ft tow ropes, we put
an eye splice in each end and appropriate weak links.
Each spool costs us about $84 and the three ropes last about 9 months,
3 months each rope. We operate off a paved runway, do not drop the
rope on landing, but the end does get dragged across a gravel area
before the pavement on landing. The "whip" end of the rope gets
weaker and we normally trim about 10ft and redo the eye splice.
Normally after 2 trimmings it is time to replace the rope.
Old August 24th 10, 06:07 AM posted to rec.aviation.soaring
brianDG303[_2_]
Default tow rope
Thanks,
Doug
before the pavement on landing. *The "whip" end of the rope gets
We use Samson Polytron Quiksplice:
http://www.cbknot.com/QuikSplicePolytron.htm
about $0.08 from many sources. It's something like spun olefin (Tyvek)
and it is really good stuff. It is a UV resistant abraision resistant
rigging line use in fishnet rigging applications.
Brian
Old August 24th 10, 01:23 PM posted to rec.aviation.soaring
HL Falbaum[_2_]
Default tow rope
"brianDG303" wrote in message
On Aug 23, 6:42 pm, BTiz wrote:
Thanks,
Doug
Brian
I can't tell from the catalogue. Is this a hollow braid rope?
Thanks
Hartley Falbaum
Old August 24th 10, 04:39 PM posted to rec.aviation.soaring
Frank Whiteley
Default tow rope
Thanks,
Doug
Brian
Thanks
Hartley Falbaum
This? 12-strand single braid description, but the image appears to be
double braid.
http://www.samsonrope.com/index.cfm?rope=66
Old August 24th 10, 09:09 PM posted to rec.aviation.soaring
brianDG303[_2_]
Default tow rope
Thanks,
Doug
Brian
Thanks
Hartley Falbaum
This? *12-strand single braid description, but the image appears to be
double braid.
That's the rope we use, in 6mm or 1/4". I'm not sure what hollow braid
is exactly but we use a hollow braid splice to put the rings on, you
loop it back on itself, shove about 18" up into the hollow core
(through the braid) and you are good.
Brian
Old August 25th 10, 01:31 AM posted to rec.aviation.soaring
Tim Mara
Default tow rope
I have nearly every type of tow rope available......literally 100's of
spools in stock
see my website page http://www.wingsandwheels.com/page30.htm
thanks
tim
Please visit the Wings & Wheels website at www.wingsandwheels.com
"tazman" wrote in message
Thanks,
Doug
__________ Information from ESET NOD32 Antivirus, version of virus
signature database 5394 (20100824) __________
The message was checked by ESET NOD32 Antivirus.
http://www.eset.com
__________ Information from ESET NOD32 Antivirus, version of virus signature database 5394 (20100824) __________
http://www.eset.com
Old August 25th 10, 03:30 AM posted to rec.aviation.soaring
BTiz
Default tow rope
Thanks,
Doug
Brian
Thanks
Hartley Falbaum
double braid.
http://www.samsonrope.com/index.cfm?rope=66- Hide quoted text -
- Show quoted text -
We tried the 12strand hollow braid out here in the desert. It did not
last as long as the 3ply twisted poly pro.
Bill
Tow rope reel Don[_4_] Soaring 4 October 31st 08 06:05 PM
Where to buy AmSteel tow rope? [email protected] Soaring 2 April 20th 06 03:45 AM
11 on a Rope Peter Seddon Rotorcraft 0 May 27th 04 12:33 PM
Donuts on a rope Big John Piloting 4 May 2nd 04 05:53 AM
Tow Rope Take-Up Reels Nyal Williams Soaring 1 September 17th 03 05:11 PM
