#11
I've tried to put most useful info on this page along with offering trying
to offer only the best and most suitable types available please see http://www.wingsandwheels.com/page25.htm thanks tim Please visit the Wings & Wheels website at www.wingsandwheels.com "Grider Pirate" wrote in message ... VSLA? A123? Cycling chargers?? I think this subject should have it's own thread. Unlike transponders, we almost all need them. __________ Information from ESET NOD32 Antivirus, version of virus signature database 5394 (20100824) __________ The message was checked by ESET NOD32 Antivirus. http://www.eset.com __________ Information from ESET NOD32 Antivirus, version of virus signature database 5394 (20100824) __________ The message was checked by ESET NOD32 Antivirus. http://www.eset.com |
On Aug 24, 7:03*am, Grider Pirate wrote:
VSLA? A123? Cycling chargers?? *I think this subject should have it's own thread. *Unlike transponders, we almost all need them. Some comments below, in general and picking up a few things in other posts/threads and reposting some things I've said elsewhere recently. Most "smart" chargers are really pretty dumb and have no way of setting the bulk charge rate to match different size batteries. So you purchase those chargers sized for the size battery you are charging. A bulk charge amp rating in the range C/10 to C/5 is about right (where C is the battery capacity in Ah.). At the simplest level too low a bulk charge rate will take too long to charge and too high a rate may not be good for the battery. But it is actually more complex than that. Good VRLA battery chargers use a constant current bulk charge mode, switch to "absorption mode" (constant high voltage or a type of current limited high voltage mode) and finally finish off with a lower float voltage. The trip point between switching from bulk charge to absorption mode is usually when the battery voltage crosses a voltage threshold, switching from absorption to float mode is usually done when the current flowing into the battery decreases below a certain value. Typical VRLA smart chargers, use a value that is appropriate for the size battery they are designed to charge. Any absorption mode current limits are also matched to the size battery the charger is designed to charge. If you charge a larger battery than intended the charger may never switch into float mode and if you charge a smaller battery the charger may switch into float mode way too early. Leave that battery on charge overnight and it might be possible that you get less charge into the battery than a properly designed charger (yes a "bigger" charger may actually not charge as well as a properly sized "smaller" charger). So it is really a good idea to aim for the C/10 to C/5 range, and even better to read the manufacturer literature on what exact Ah capacity the charger is designed to charge. VRLA batteries have intrinsically low-self discharge rates. Quite different to flooded lead-acid car batteries. So it is just not necessary to leave them on chargers for long periods of time. e.g. over winter VRLA batteries will do fine if you fully charge them and then leave them in a cool place and recharge again before the new season starts. I tend to ignore as unproven or irrelevant marketing hype many of the fancier claims or features that some charger manufacturers make. The Detran Battery Minder brand makes a few of those claims but the battery chargers themselves are very good. They are a good choice, as are the Xentronix HPX series I personally use. As mentioned in other threads fancy RC model DC-DC chargers can be very handy for charging batteries where you don't have AC power. These units typically do not have a float stage, not a problem when you are doing a quick charge of your 7Ah VRLA battery at the model field but some folks do want to use the same charger at home with a DC power supply from the mains. In which case you don't want to leave the battery on the charger for long periods of time. The risk with overcharging, charging when too hot, or leaving on a non- float charger for long times is that VRLA batteries have a very small amount of electrolyte wetting the fiberglass mats between the plates and this will evaporate that electrolyte from the batteries -- they are not really "sealed" batteries, they have small neoprene valves designed to hold a very slight overpressure. RC model chargers often allow you to set the number of cells/nominal pack voltage and the bulk charge current but as Eric Greenwell has pointed out in another thread some commonly used ones may not get charge voltage and transition points exactly where they should be. I would be very cautious about using RC model chargers in club situations etc. they have to many settings that people can mess up. Besides RC model chargers another option is to look at DC-DC chargers designed for charging wheelchair VRLA batteries. There are several out there, but I have no experience with any of them. Some people have commented on testing batteries not really being worthwhile as batteries tend to die quickly. This may be true in some cases, but likely what people are experiencing is the internal resistance property of lead-acid batteries. As the battery discharges the internal resistance increases significantly as the electrolyte conductivity decreases. This gives lead-acid batteries a relative rapid fall off in voltage under load as the battery depletes. Under normal operation you don't see that sudden fall off, as the battery ages you now see that sudden voltage-fall off behavior shift into sight and the impression is a sudden failure of the battery. Regular (typically annual, but cubs and FBOs may want to do this more frequently) testing of batteries is a good idea. Make some simple spreadsheet calculations and/or some measurements of your glider's actual current load and then look up on the manufacturers discharge curve for that battery how how long the battery should last a that discharge rate. And pad with a good safety margin, allow 20% for aging, and up to 50% for flying on cold wave days. Really cold/extreme duration wave flights need more thought and possibly insulation, heaters or different battery technology. If your 12 AH battery has a 7Ah actual capacity it is going to have a discharge curve close to a new 7AH battery, which is related to what I said before about why the batteries appear to fail quickly. Anyhow some modeling/measurements and measuring the actual capacity of your battery should give you a very good idea where you are in terms of battery health. Unfortunately a common wrongly done test for battery charge state is to just take a battery off charge and measure its open circuit voltage. This often tells you nothing that useful about the battery state of charge. What you are measuring is an effect called surface charge and the actual voltage of the battery may be significantly lower. Measured properly the open circuit voltage is a good estimate the state of charge (that voltage is fundamentally connected to the chemical process giving the battery power) you need to "burn off" the surface charge. For typical batteries we use connect a car or truck tail light bulb across the battery for several minutes then leave the battery sit for 10 minutes or so to let the voltage relax to a steady state and then measure that open circuit voltage. Then look up on a table or chart whan state of charge that voltage implies. There is a chart in my presentation at http://www.darryl-ramm.com/glider-batteries or see the state of charge table at http://www.batteryfaq.org (which shows temperature effects). Batteries that have been off charge for days will naturally have lost their surface charge. Measuring that open circuit voltage tells you about the state of charge, it does not tell you about the battery capacity. A big 120Ah VRLA battery for a large UPS system and a 7Ah VRLA battery in your glider have pretty much the same open circuit voltages when fully charged. To determine the battery capacity you really need to fully charge the battery and then do a discharge test. You can do this by hand with a resistor/light bulb etc. and just measuring the voltage over time or usually much easier to use an automatic tester. A good battery tester like the CBA II from West Mountain radio can monitor charge cycles as well as discharge test the battery. These are ideal for club/FBO purchase. For more technical folks monitoring the charge process along with a separate ammeter in the circuit lets you confirm things like the charger correctly goes into float mode, that the other charge rates look about right. BTW my interest in trying to evangelize battery knowledge in the gliding community was largely driven by lots confusion about battery capacity and proper handling related to powering transponders in gliders. I saw both sides of this issue, some people overestimating problems from adding a transponder with ~0.5 amp load (now 0.3 amp with a Trig TR21) and those with real battery capacty issues with lots of avionics/toys and kind of stuck as to what they should/could do about it. One current issue where I see gliders with power problems seems to be ClearNav and similar installations. At around 0.7 amp at full brightness owners installing a ClearNav or similar products probably need to think about their gliders power budget and battery capacity. Even large PDAs can consume up to 0.5 amp and they often seem to be installed with even less though about power consumption. Darryl |
On Tue, 24 Aug 2010 08:03:48 -0700, Tony wrote:
I went to the local Interstate Battery store. Picked up a 12V Sealed Lead Acid battery, 7 amp hour I think but maybe 10. Either way plenty of juice to run my Microair radio and Cambridge FR. I also bought a charger from them with a float mode. Usually I plug it in before I go to bed the night before a flight and take it off in the morning and its charged up real good. SLAs in good condition have a very low self-discharge rate, so IMO its better for the battery to put it on charge as soon as you get home and then put it back in your flight kit when the charger says its done or next morning if red light is still on when you go to bed. Example of holding charge: yesterday when I ran the discharge rate test Eric asked about I used one of my flight batteries to power the charger while it discharged my other flight battery. Pulled 22 mAh out of the test target and (probably) less from the other one. After the test both went back on the multi-stage SLA chargers and both were showing green lights in under 30 minutes. Both batteries are 3 years old and were last charged overnight 14 days ago directly after I last used them, so can have lost very little charge since then. Yeah, I know: its been GREAT summer weather over here! -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
On Aug 24, 11:14*am, T8 wrote:
One other thing... DO include a fuse or circuit breaker at the battery and do make certain that the connections between the CB and the battery are absolutely as reliable as you can make them (as mentioned on another thread, problems here aren't covered by your CB). *I recommend a 5 amp push to reset CB, provided that you have some placeer Moxex-type connectors to mount it correctly, teflon insulated aircraft wire of 18ga and Molex or equivalent industrial quality crimp on connectors which are *far* better than consumer grade stuff at your hardware store. *This is a great area to solicit some help if you aren't completely confident in your ability. That's my public service announcement for the day :-). -T8 For any battery connections I highly recommend Anderson Powerpole connectors: http://www.andersonpower.com/product...onnectors.html. They are hermaphorditic (sexless) and are being used as a defacto standard in the Amateur Radio community for battery connections. This article: http://www.westmountainradio.com/supportrr.htm gives details on their application. There was a recent article in one of the ham magazines discussing their advantages over Molex-type connectors. The use of 30-amp size connectors has been suggested as standard due to their rugged construction and low contact resistance. Don. |
On Tue, 24 Aug 2010 16:49:51 -0700, Darryl Ramm wrote:
On Aug 24, 7:03Â*am, Grider Pirate wrote: VSLA? A123? Cycling chargers?? Â*I think this subject should have it's own thread. Â*Unlike transponders, we almost all need them. Some comments below, in general and picking up a few things in other posts/threads and reposting some things I've said elsewhere recently. An excellent summary, especially of the low-tech ways of testing SLAs. I would, however, take issue over there being many RC chargers without a float mode. I've not yet seen a multi-chemistry charger that didn't have some sort of float mode for all chemistries: its essential for Li-poly and for high-rate charging of NiCd/NiMH and anyway these charger/cyclers are all microprocessor based, so leaving it off is inexcusably cheap design. Did you mean that some just omit peak detection for lead-acid batteries? The only place I've been happy to use untimed chargers is with low capacity NiCds. My favoured approach there is to use a "1% charge rate", i.e. charge at 0.01C, and leave the battery permanently on charge unless I'm flying the model its installed in. NiCds are frequently used as low- maintenance emergency batteries and these are invariably left on charge at the 1% rate for years at a time so they like this treatment. Its really convenient: put the model box back on its rack after a contest or trimming session, open the lid, connect the charger and forget about it until next time you go flying. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
On Aug 24, 6:07*pm, Martin Gregorie
wrote: On Tue, 24 Aug 2010 16:49:51 -0700, Darryl Ramm wrote: On Aug 24, 7:03*am, Grider Pirate wrote: VSLA? A123? Cycling chargers?? *I think this subject should have it's own thread. *Unlike transponders, we almost all need them. Some comments below, in general and picking up a few things in other posts/threads and reposting some things I've said elsewhere recently. An excellent summary, especially of the low-tech ways of testing SLAs. I would, however, take issue over there being many RC chargers without a float mode. I've not yet seen a multi-chemistry charger that didn't have some sort of float mode for all chemistries: its essential for Li-poly and for high-rate charging of NiCd/NiMH and anyway these charger/cyclers are all microprocessor based, so leaving it off is inexcusably cheap design. Did you mean that some just omit peak detection for lead-acid batteries? Its not "omitting" peak-detection, peak detection does not work with lead-acid batteries and so is irrelevant. Lead acid chargers will at least use a constant current bulk mode, then hopefully a constant voltage (or current limited constant voltage) absorption mode and then maybe a float mode. Working out what many of these RC chargers do from their marketing datasheets or manuals can be a challenge hard. Not seen any that don't have float mode? You may want to double check the one you use. I believe (based on measurements from Eric Greenwell) the Multiplex LN5014 for example does not float a VRLA battery and it looks like you may be using the same OEM charger under a RipMax brand right? To float a VRLA battery the charger should be stepping down to 13.5 to 13.8V from a 14.4 to 14.7V voltage during absorbtion stage. And the Multiplex charger only every pulls up to 14.0 volts which is a bit low as Eric has noted. The charger simply ends charge when the charge current falls to 10% of the bulk charge rate you set. I does not enter float mode. (all based on separate conversations with Eric). For most/occasional use this won't matter, but you do leave some capacity on the table. Can you me some examples of widely available RC chargers that have a float mode for VRLA batteries - and a link to a source that shows they have that. [snip] Thanks Darryl |
More about Glider Batteries:
My club's gliders use Gel batteries, probably because they fit the mounts so well, but mostly the private gliders use a battery type with many names, I guess it's an SLA (Sealed Lead Acid) except it's not really sealed. I started to call it an AGM (Acid Glass Matt) which it has, but suddenly it started to be called a VRLA (Valve Regulated Lead Acid). Anyway they are very interestingly made. Although they look sealed many of these have a separate and tightly fitting top which is glued on only at the short sides, (the Valve Regulated gas being allowed to escape through the unglued long sides) and this cap can be pulled off pretty easily exposing the sub-assembly consisting of small recessed nipples rising from the center of little 'moats' that have a fabric packing in them, I guess to absorb any acid that gets out of the valve. Each of these little nipples has a rubber cap which forms a one way valve. Pictures of this can be found he http://picasaweb.google.com/BrianDG3...laneBatteries# As far as I can tell the battery exhausts gas (and/or liquid) whenever the internal pressure rises very much beyond the ambient, but seals tightly when the internal pressure is lower than ambient. When the top is removed the caps are dished down into the nipple from negative pressure and when you pull the cap off there is a considerable hiss of air flow into the battery. So, although they are valve regulated I don't think they 'breathe' much, at least not in. Also in that group of photos is a housing I've made, different from but based on an example I saw Darryl Ramm make, that forms a handle, protects the battery terminals, holds a Klixon aircraft rated circuit breaker and two Anderson Powerpole connector sets. Using clear Lexan for the top is a trick from hospitals, they will sometimes make electrical devices out of clear polycarbonate- you can inspect the terminals that way and see a failure developing. Also makes it easier to work on. Having two outputs is very useful as well. Brian |
On 8/24/2010 6:07 PM, Martin Gregorie wrote:
I would, however, take issue over there being many RC chargers without a float mode. I've not yet seen a multi-chemistry charger that didn't have some sort of float mode for all chemistries: its essential for Li-poly and for high-rate charging of NiCd/NiMH and anyway these charger/cyclers are all microprocessor based, so leaving it off is inexcusably cheap design. Did you mean that some just omit peak detection for lead-acid batteries? The Multiplex LN5014 and it's clones do not have a float mode for lead-acid (Pb in their terminology). The Multiplex manual states that explicitly, saying it's not needed because their self-discharge rate is so low. They are right about the self-discharge, and my LN5014 definitely shuts off when the current drops to 10% of the set charge rate (no peak detection is used for lead-acid). It does have a trickle charge for some of the other chemistries. I have no idea if other chargers offer float mode for lead-acid; in any case, float mode for lead-acid seems unnecessary for a charger powered by a battery, as it's not really practical to leave it running for long enough to make any difference. It's not a feature I'd bother to look for. -- Eric Greenwell - Washington State, USA (netto to net to email me) - "Transponders in Sailplanes - Feb/2010" also ADS-B, PCAS, Flarm http://tinyurl.com/yb3xywl - "A Guide to Self-launching Sailplane Operation Mar/2004" Much of what you need to know tinyurl.com/yfs7tnz |
On Aug 24, 7:08*pm, brianDG303 wrote:
More about Glider Batteries: My club's gliders use Gel batteries, probably because they fit the mounts so well, but mostly the private gliders use a battery type with many names, I guess it's an SLA (Sealed Lead Acid) except it's not really sealed. I started to call it an AGM (Acid Glass Matt) which it has, but suddenly it started to be called a VRLA (Valve Regulated Lead Acid). Anyway they are very interestingly made. Although they look sealed many of these have a separate and tightly fitting top which is glued on only at the short sides, (the Valve Regulated gas being allowed to escape through the unglued long sides) and this cap can be pulled off pretty easily exposing the sub-assembly consisting of small recessed nipples rising from the center of little 'moats' that have a fabric packing in them, I guess to absorb any acid that gets out of the valve. Each of these little nipples has a rubber cap which forms a one way valve. Pictures of this can be found he http://picasaweb.google.com/BrianDG3...laneBatteries# As far as I can tell the battery exhausts gas (and/or liquid) whenever the internal pressure rises very much beyond the ambient, but seals tightly when the internal pressure is lower than ambient. When the top is removed the caps are dished down into the nipple from negative pressure and when you pull the cap off there is a considerable hiss of air flow into the battery. So, although they are valve regulated I don't think they 'breathe' much, at least not in. Also in that group of photos is a housing I've made, different from but based on an example I saw Darryl Ramm make, that forms a handle, protects the battery terminals, holds a Klixon aircraft rated circuit breaker and two Anderson Powerpole connector sets. Using clear Lexan for the top is a trick from hospitals, they will sometimes make electrical devices out of clear polycarbonate- you can inspect the terminals that way and see a failure developing. Also makes it easier to work on. Having two outputs is very useful as well. Brian SLA == VRLA == AGM it is all the same stuff. But why use a TLA when you can use a LFLA :-) Some VRLA batteries are also referred to technically as recombinant, or valve regulated lead acid recombinant, or lead acid recombinant batteries. All basically the same stuff. Most situations where glider pilots are referring to "gell cell" they turn out to be VRLA batteries. There really is no benefit of the old gel cell technology (electrolyte gelled with a silica powder) and some disadvantages, including repeated deep cycling and rapid charging causing gas pockets in the gel. VRLA construction tends to be a bit more robust against misshandling - with the plates really solidly packed in a compressed sandwich that gel cells, but both are pretty robust. The neoprene valves that Brian describes hold a slight over pressure of the battery and prevent gas escaping under normal charge situations. The valves will vent if the battery gets hot and/or is overcharged. This why its normally OK to operate a VRLA battery in any orientation but just don't charge them when upside down or they can blow out a few drops of acid with the venting gas (even if they have absorber designed to catch that acid). Darryl |
![]() "Martin Gregorie" wrote The only place I've been happy to use untimed chargers is with low capacity NiCds. My favoured approach there is to use a "1% charge rate", i.e. charge at 0.01C, and leave the battery permanently on charge unless I'm flying the model its installed in. NiCds are frequently used as low- maintenance emergency batteries and these are invariably left on charge at the 1% rate for years at a time so they like this treatment. Its really convenient: put the model box back on its rack after a contest or trimming session, open the lid, connect the charger and forget about it until next time you go flying. My strategy for RC NiCads is to charge them with peak charger after flying, then hook them onto a power strip with all of the other factory chargers or equivalent which is powered by a 7 day charger. I set it to come on for 2 hours, once per week. -- Jim in NC |
Still interested in Lithium batteries for your glider? | Eric Greenwell | Soaring | 5 | March 5th 05 02:32 PM |
Battery Chargers | Stan Amyett | Soaring | 2 | March 12th 04 05:27 AM |
Battery Chargers | Mike Rapoport | Owning | 11 | December 2nd 03 11:55 PM |
Rechargable AA batteries and chargers | TripFarmer | General Aviation | 2 | October 17th 03 06:34 PM |
Rechargable batteries and chargers....... | TripFarmer | Products | 2 | October 17th 03 06:31 PM |
