#41
On Sep 1, 4:30*pm, "vaughn" wrote:
wrote in message ... Since my FAA physical is coming up soon I got a normal physical to insure would be no surprises. * *Good for you! *But one could argue that it would be better to get that private physical *AFTER* your FAA physical. Good point Vaughn. Case in point with me. Had DVT which required the use of blood thinners. By the time I got to my medical I was NOT on the medication. But the question on the form does ask if you had any vascular problems (or something to that effect) since the last exam. I could have easily said no as I wasn't on my last medical and I wasn't during this last exam. I did the right thing and reported it. This put a 2 month delay on my medical even though I came in with the proper INR and prognosis documentation per AOPA guidance AND I started the medical process a month before expiration. I don't see the FAA medical exam being a strict exam even though I had this inconvenience.. In a nutshell for a class three certification, they check your vision, hearing and pee to meet minimum requirements and depend on the pilot to be upfront and honest about any other conditions. The actual exam is not strict by any standards. (so much for Mx's knowledge of this process) In my case and I have posted this in the past, my past class three exams revealed pre-melanoma on one exam and extreme high blood pressure (210 over 170) on another exam and I was flying the day before the exam with this blood pressure asymptomatic. Neither of the above prevented me from flying AFTER I came up with the appropriate documentation to recertify my medical. Even with me seeing a doctor once a year, I am all for the FAA exam as my current doctor doesn't check my vision or hearing. |
#42
On Sep 1, 5:30*pm, "vaughn" wrote:
wrote in message ... Since my FAA physical is coming up soon I got a normal physical to insure would be no surprises. * *Good for you! *But one could argue that it would be better to get that private physical *AFTER* your FAA physical. Why? *Because there can be considerable difference between the disease definitions your doctor uses and those contained in FAA regulations. *In particular, the thresholds for blood pressure and blood sugar have been generally lowered over the years, while the FAA definitions have remained unchanged. *For example: if your doctor diagnoses you with type 2 diabetes, you will be required to report that on your medical application and then you will be required to jump through the appropriate hoops to get your medical, even though you may (probably will) pass the AME's very crude urine-based blood sugar test. Vaughn An interesting ethics question would be, what would you have done if your 'ordinary' physical would have disclosed something that would have prevented you from passing the FAA one? |
#43
vaughn wrote:
wrote in message ... Since my FAA physical is coming up soon I got a normal physical to insure would be no surprises. Good for you! But one could argue that it would be better to get that private physical *AFTER* your FAA physical. Why? Because there can be considerable difference between the disease definitions your doctor uses and those contained in FAA regulations. In particular, the thresholds for blood pressure and blood sugar have been generally lowered over the years, while the FAA definitions have remained unchanged. For example: if your doctor diagnoses you with type 2 diabetes, you will be required to report that on your medical application and then you will be required to jump through the appropriate hoops to get your medical, even though you may (probably will) pass the AME's very crude urine-based blood sugar test. Vaughn I got the private physical 6 months before the FAA physical because that would give me plenty of time to take care of any issues per the FAA requirements. It doesn't matter to the FAA what your doctor calls something, what matters is numbers, as in your doctor can say you have high blood pressure but the only thing the FAA cares about is that it is under 155. Also, as you get older and don't take a private physical first, there is the chance you will be denied and there goes everything, including Sport Pilot. -- Jim Pennino Remove .spam.sux to reply. |
#44
#45
a wrote:
On Sep 1, 5:30Â*pm, "vaughn" wrote: wrote in message ... Since my FAA physical is coming up soon I got a normal physical to insure would be no surprises. Â* Â*Good for you! Â*But one could argue that it would be better to get that private physical *AFTER* your FAA physical. Why? Â*Because there can be considerable difference between the disease definitions your doctor uses and those contained in FAA regulations. Â*In particular, the thresholds for blood pressure and blood sugar have been generally lowered over the years, while the FAA definitions have remained unchanged. Â*For example: if your doctor diagnoses you with type 2 diabetes, you will be required to report that on your medical application and then you will be required to jump through the appropriate hoops to get your medical, even though you may (probably will) pass the AME's very crude urine-based blood sugar test. Vaughn An interesting ethics question would be, what would you have done if your 'ordinary' physical would have disclosed something that would have prevented you from passing the FAA one? In my case I had already decided; sell the Tiger and buy a LSA assuming whatever it was didn't mean flying would be stupid, like an aneurism that could blow at any time. -- Jim Pennino Remove .spam.sux to reply. |
#46
![]() wrote in message ... It doesn't matter to the FAA what your doctor calls something, what matters is numbers, as in your doctor can say you have high blood pressure but the only thing the FAA cares about is that it is under 155. I am not sure that is true; are you? The question on form 2120-0034 is: "HAVE YOU EVER IN YOUR LIFE BEEN DIAGNOSED...". You have only two blocks to check for each listed condition: "Yes" or "No". If you check "Yes", it is up to your AME to resolve to issue as per FAA guidlines, or deny you. My point is that the thresholds that your doctor uses are subject to change based on current research, and they are likely not the same thresholds found in FAA regulations. Also, as you get older and don't take a private physical first, there is the chance you will be denied and there goes everything, including Sport Pilot. Yes, and that might well play into your decision to get a prior physical...or not. If you happen to be a professional pilot, Sport Pilot privaleges may not be terribly important to you. FYI Myself, I see my doctor regularly. I wat to keep flying, but continuing to live is even more important to me. Vaughn |
#47
vaughn wrote:
wrote in message ... It doesn't matter to the FAA what your doctor calls something, what matters is numbers, as in your doctor can say you have high blood pressure but the only thing the FAA cares about is that it is under 155. I am not sure that is true; are you? The question on form 2120-0034 is: "HAVE YOU EVER IN YOUR LIFE BEEN DIAGNOSED...". You have only two blocks to check for each listed condition: "Yes" or "No". If you check "Yes", it is up to your AME to resolve to issue as per FAA guidlines, or deny you. My point is that the thresholds that your doctor uses are subject to change based on current research, and they are likely not the same thresholds found in FAA regulations. Yes, the FAA uses the FAA numbers. If you were to check yes becuase, for example, your blood pressure was 145, which most doctors concider "high blood pressure", in the notes you say it was 145. The AME in any case is going to take your blood pressure and if it is under 155, that is the end of it. Taking a private physical well in advance gives you the opportunity to get a treatable condition under control to FAA standards and get the required paper done to prove it before you see the AME. Also, as you get older and don't take a private physical first, there is the chance you will be denied and there goes everything, including Sport Pilot. Yes, and that might well play into your decision to get a prior physical...or not. If you happen to be a professional pilot, Sport Pilot privaleges may not be terribly important to you. Again, it gives you the opportunity to get a treatable condition under control to FAA standards and get the required paper done to prove it before you see the AME. -- Jim Pennino Remove .spam.sux to reply. |
#48
Mark writes:
No really. With today's epidemic of diabetes it's not uncommon for police to intercept drivers who have become totally disoriented and incapacitated due to low blood sugar. Hypoglycemia is mainly a risk for insulin-dependent diabetics, who represent only a small minority of diabetics (particularly when one considers only those who are especially at risk of hypoglycemia). There are some jurisdictions that prohibit diabetics from driving, although that's an extreme overreaction with no justification in reality. Also, the idiots who drive under the influence are "medically incapacitated" while they're high on booze or drugs, which account for a large percentage of accidents. Alcoholism and drug addiction is considered a disease. Substance abuse is a choice that one makes independently of uncontrollable medical factors. Alcohol is a leading cause of automobile accidents, but nothing forces anyone to drink alcohol. |
#49
#50
vaughn writes:
For example: if your doctor diagnoses you with type 2 diabetes, you will be required to report that on your medical application and then you will be required to jump through the appropriate hoops to get your medical, even though you may (probably will) pass the AME's very crude urine-based blood sugar test. The doctor doesn't have to diagnose it. He may simply have a concern about high blood glucose, which is not the same as a diagnosis of diabetes. The diagnosis must be reported, but not just the doctor's verbally articulated concern. And indeed, an occasionally high blood glucose doesn't necessarily equate to diabetes, so jumping to a diagnosis isn't always warranted. In contrast, if there really is diabetes, then it's better to get it diagnosed and fixed, and whether this occurs before or after the FAA medical is irrelevant. If you are diagnosed a day after the FAA medical, then you are no longer fit to fly until you get it fixed. |
Question on the medical... | Richard | Piloting | 25 | March 29th 06 04:41 PM |
Yet another medical question | Rachel | Piloting | 13 | February 5th 06 10:44 PM |
Medical question | Michael | Piloting | 10 | December 7th 05 06:58 PM |
FAA medical question | G. Sylvester | Piloting | 17 | March 12th 05 11:13 AM |
Question Medical | Captain Wubba | Piloting | 5 | June 11th 04 05:12 AM |
