Schweizer 1-34 Pilot Weight capability
Old September 11th 10, 11:27 PM posted to rec.aviation.soaring
RN
Default Schweizer 1-34 Pilot Weight capability
Our club is considering an SGS 1-34 as an addition to the fleet and is
interested in the max pilot weight capability. It looks like the
handbook numbers are quite high, but we would appreciate any real
world inputs from 1-34 pilots or owners.
Old September 12th 10, 02:52 AM posted to rec.aviation.soaring
Frank Whiteley
Ultimately, it depends on how much paint it has. I know of one
chapter that removed the paint and polished the aluminum to gain back
something approaching 30 lbs. But I don't know what the total payload
became. That 1-34 also had O2. Maybe a member will chime in.
Old September 12th 10, 04:17 AM posted to rec.aviation.soaring
Pete Brown
The 1-34 and 1-34R (retractable gear model) both have max gross weights
of 840 lbs. The empty weight of the 1-34 is 570 lbs providing a a max
useful load of 270 lbs. Add a battery, more than basic instruments, a
radio, transponder, and a oxygen system and you are going to end up with
a payload of ~240 lbs for the pilot. That's still a healthy number.
The 1-34R has an empty weight of 595 providing a max useful load of 245
lbs. Adding equipment thereto and the practical pilot weight could drop
into the 215 lb area. Counts me out.
When you find one, get a copy of that particular glider's current W&B to
see what the real empty weight and CG are. In addition to equipment,
repairs can add extra pounds, further diminishing the max pilot weight.
If you want a copy of the aircraft manual in a pdf file, send me an email.
pdbatgcidotnet
Pete Brown
Anchorage Alaska
Going home after a long day
http://farm2.static.flickr.com/1415/...22928754_b.jpg
The fleet at Summit. Mt. McKinley is about 45nm away at 20,320 msl.
http://farm1.static.flickr.com/187/4...cb8d2482_b.jpg
The 170B at Bold near Eklutna Glacier
http://farm1.static.flickr.com/168/4...a216d7bb75.jpg
Old September 12th 10, 06:53 AM posted to rec.aviation.soaring
Frank Whiteley
Ultimately, it depends on how much paint it has. *I know of one
something approaching 30 lbs. *But I don't know what the total payload
became. *That 1-34 also had O2. *Maybe a member will chime in.
http://www.soarboulder.org/equipment/48-schweizer-i-34
Old September 12th 10, 07:35 AM
Walt Connelly Walt Connelly is offline
Senior Member
First recorded activity by AviationBanter: Aug 2010
I have about 35 flights in a 1-34 and was surprised to see the book stating 270 lbs in the 1-34 and 245 in the retractable model, 1-34R. I have seen other 1-34's with a limitation of 218 lbs. I am 5'8" and 190 lbs and found the cockpit to be a bit of a tight fit for me. I have seen someone much larger than myself fly the same glider, a guy well over 220 lbs. I'm not sure that a 270 pounder would fit in the cockpit without vaseline and a shoe horn. That being said, the 1-34 is a fun airplane to fly and handles wonderfully.
Old September 12th 10, 08:25 AM posted to rec.aviation.soaring
Surfer![_2_]
Whatever it says in the manual, remember each glider varies and is
individually placarded.
"RN" wrote in message
Old September 12th 10, 02:34 PM posted to rec.aviation.soaring
I weighed 250 and 6' 3" when I owned mine
Old September 13th 10, 02:03 AM posted to rec.aviation.soaring
Frank Whiteley
Just spoke with Bob Whelan about this 1-34. Some number were built
with filler and fabric over the metal to provide better laminar flow
as was this one. Over 30 lbs was regained by removing all but the
metal.
Frank Whiteley
Old September 14th 10, 02:56 AM posted to rec.aviation.soaring
ray conlon
Just spoke with Bob Whelan about this 1-34. *Some number were built
as was this one. *Over 30 lbs was regained by removing all but the
metal.
Frank Whiteley
Our club had one some years ago, great ship, rugged,roomy and at 6-3/
245# I had no problem with it. The dive brakes are fantastic, point it
striaght down, haul out the boards and forget about exceeding red line
concerns.
Would love to have another one. A close 2nd are the Platius B4's...
FS: Schweizer 1-34, Schweizer Open Trailer F.L. Whiteley Soaring 2 April 10th 04 02:52 AM
Empty/Gross weight Vs. Max. Pilot weight Flyhighdave Soaring 13 January 14th 04 04:20 AM
Pilot weight/Cockpit load Flyhighdave Soaring 3 January 3rd 04 02:54 AM
pilot weight and gliding John Lee Soaring 4 August 31st 03 06:53 PM
Pilot weight and gliding JohnH Soaring 26 August 27th 03 11:08 PM
