LS1 Tail locking spring
Old September 22nd 10, 11:02 AM posted to rec.aviation.soaring
Andrew[_9_]
Default LS1 Tail locking spring
Looking for the tail locking spring for my LS1-f. DG told me it's not
longer available in their stock
Old September 22nd 10, 02:31 PM posted to rec.aviation.soaring
Westbender
Did you check to see if he had the spring-ball upgrade kit? It
replaces the old spring and looks almost identical to the later models
(3, 4, ...).
Old September 22nd 10, 03:50 PM posted to rec.aviation.soaring
Westbender
See Tech note #51: http://www.dg-flugzeugbau.de/Data/TM-LS/LS1-f/TM51.pdf
Old September 22nd 10, 05:12 PM posted to rec.aviation.soaring
James Anderson
Let me check if I still have the parts.
I upgraded my -1f with the ratchet type
Will get back to you
r/Jim
Old September 23rd 10, 10:09 PM posted to rec.aviation.soaring
Victor Newman
r/Jim
You paid DG their annual extortion fee, and they couldn't bend a piece
of piano wire for you?
Old September 24th 10, 01:02 AM posted to rec.aviation.soaring
Andrew[_9_]
r/Jim
Yes I paid the annual maintenance, and they want to sell me the
upgrade solution of installing the ratchet type as the new LS models,
and they have quoted me € 135 for the freight plus € 245 for the part.
It is avery expensive solution to replace a piece of wire. The new
part is less than 500 grams so I imagine it will be delivered on
Bussines class . Unfortunately looks like I have no other option.
Old September 24th 10, 01:49 AM posted to rec.aviation.soaring
vaughn[_3_]
"Andrew" wrote in message
I haven't seen the part in question, but if it is truly just a length of spring
wire, I would pay a visit to my local 2-way radio shop and rummage in the box
where they throw the old car antenna whips. You might just find some LS1 parts
there...
Vaughn
Old September 24th 10, 02:09 AM posted to rec.aviation.soaring
Westbender
For what it's worth, I bought the new ratchet kit in 2007 from Chris
Klix (Pacific Aerosport) for $190 plus $25 shipping. Still expensive
for what it is, but a whole lot cheaper than DG.
Winpilot pro and Ipaq 4700 locking up. joesimmers Soaring 5 July 17th 08 05:42 AM
90 degree locking pliers? B. Jensen Home Built 8 October 3rd 05 06:50 PM
New Wheel Locking Device TM Products 2 March 29th 05 04:07 PM
Looking for 3/8 in-24 thread/low profile self locking nuts/ Larry Home Built 3 February 22nd 05 03:02 PM
FS: Blanik L-13 Tail Skid & Tail Wheel Assembly Tim Hanke Soaring 0 February 8th 05 01:34 PM
