Glider use of 1201 encouraged.
Tow planes use 1200. Thanks for ping from Elliott Crawford, CFI-G. Frank Whiteley SSA State Governor, Colorado |
On Sep 22, 2:38*pm, Frank Whiteley wrote:
Glider use of 1201 encouraged. Tow planes use 1200. Thanks for ping from Elliott Crawford, CFI-G. Frank Whiteley SSA State Governor, Colorado Not all areas are set up to accept 1201 codes just yet. Our local approach control needs to change a letter of agreement with a jump school. There local LOA has assigned 1201 to the jump plane, long before the national discussion for a US wide glider code. BT |
On Sep 23, 2:22*pm, BTiz wrote:
Not all areas are set up to accept 1201 codes just yet. Our local approach control needs to change a letter of agreement with a jump school. There local LOA has assigned 1201 to the jump plane, long before the national discussion for a US wide glider code. I would think that a jump plane using the same code as a glider tow plane would be entirely sensible. Both are climbing higher and more quickly in a small area than typical GA, and then descending as quickly as practical. If you have them both (and people doing aerobatics) on 1201 with gliders then it can be a code for "rapid and/or uncontrolled altitude excursions" with people droning from place to place at a relatively stable altitude on 1200. |
On Sep 23, 12:06*am, Bruce Hoult wrote:
On Sep 23, 2:22*pm, BTiz wrote: I would think that a jump plane using the same code as a glider tow plane would be entirely sensible. Both are climbing higher and more quickly in a small area than typical GA, and then descending as quickly as practical. Not when the jump plane calls TRACON for permission to jump and the "automatic data block" is attached to the tow plane not on approach frequency. |
1201 & Tow Planes | Jamie Shore | Soaring | 5 | September 13th 10 02:35 AM |
Transponder squawk code 1201 approved for ZDV | Frank Whiteley | Soaring | 0 | June 7th 10 08:00 PM |
1201 VFR Glider Code - Approved PHL-ABE-NY Tracon | RL | Soaring | 0 | April 13th 10 07:47 PM |
Chicago Tracon, Glider Code 1201 | Herb | Soaring | 1 | April 7th 10 12:06 AM |
FAA: LA ARTCC Outage Blamed On Maintenance | A Guy Called Tyketto | Piloting | 0 | September 17th 04 08:38 PM |
