World Record for first human powered ornithopter sustained flight
Old September 23rd 10, 02:17 PM posted to rec.aviation.soaring
Paul Remde
Default World Record for first human powered ornithopter sustained flight
Hi,
http://www.avweb.com/avwebflash/excl..._203330-1.html
http://www.youtube.com/watch?v=WpobKBR6n9U - be sure to watch it in HD for
best picture
Very cool! What a lovely machine in flight!
Congratulations to the designers for a job well done!
Paul Remde
Old September 23rd 10, 06:14 PM posted to rec.aviation.soaring
Bob
It may interest RAS readers to know that the project was supported by
the members and facilities of the Great Lakes Gliding Club on (Mike)
Ronan Field at Tottenham Ontario in 2009 and 2010. The construction
took place in the barn and clubhouse there, and Todd had his only
glider training at the club. All flights were at Ronan Field.
It was something to behold!! The only time when you can says 'flutter
is good'!
Old September 23rd 10, 06:41 PM posted to rec.aviation.soaring
Martin Gregorie[_5_]
Default World Record for first human powered ornithopter sustainedflight
Ronan Field at Tottenham Ontario in 2009 and 2010. The construction took
place in the barn and clubhouse there, and Todd had his only glider
AHA! That explains a comment made about this article:
http://www.theregister.co.uk/2010/09/23/pedalo/
signed by 'Great Lakes Gliding - Member' who mentioned involvement by
Todd and University Of Toronto Students Aerospace/Mechanical as well as
students from France, and Holland but not that Great Lakes Gliding was
involved.
It was something to behold!! The only time when you can says 'flutter is
good'!
A good effort, but IMO they need to do better: all other man-powered
aircraft have gained appreciable height after take-off and maintained it
for most of the flight. With all due respect for the participants, the
only published videos I've seen show a bare ability to maintain height
while well inside ground effect.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old September 23rd 10, 09:38 PM posted to rec.aviation.soaring
Bob
It is the FLAPPING WING that makes it a record. Propeller driven craft
are much easier to do of course and can take off and fly long
distances.
Are you saying 19 seconds at 25 KPH is all ground effect? Surely you
might agree that even in ground effect one loses height and speed at
some rate? Or have you discovered perpetual gliding? ;-)
The FAI representative is said to think otherwise. Approval is
expected in October.
And it was uphill on the field. I saw the late fall flights last year
in person. I guess the data will have to speak for itself.
Old September 23rd 10, 11:40 PM posted to rec.aviation.soaring
are much easier to do of course and can take off and fly long distances.
Fairly minimal flap amplitude.
One thing I'm genuinely curious about: given the flapping amplitude, why
is the pylon so high?
No, of course not, just that I don't recall other MPA attempts claiming
records until the Cramer Prize had been collected.
Subsidiary question which others have asked in other places: what is the
glide performance without flapping? The aircraft looks as it it should be
a fairly efficient glider, so I'm curious about its sinking speed and
glide ratio.
And it was uphill on the field. I saw the late fall flights last year in
What data? Apart from a couple of videos, neither of which are said to be
of the record attempt, I've seen no other information. A link to it would
be very much appreciated. So would a description of the flapping mechanism
org |
Old September 24th 10, 12:35 AM posted to rec.aviation.soaring
Bob
snipminimal flap amplitude.
I am not expert on this and was not involved in construction... the
pylon is merely for wing support at rest, the flapping is achieved by
drawing down on a cable to the underside of the wing, generated lift
makes the wing rise up, and the process repeats.
This is for a flapping flight.
glide ratio.
The team could likely tell you, see: hpo.ornithopter.net
As a glider pilot I would describe the sink rate as considerable, lots
of drag, not a floater to my eye.
There are now lots of stories on the major news sites in Canada, big
press conference at the field with satellite trucks and all!
The FAI has attended the flight and reviewed data and is to approve
the flight officially in October I was told. I cannot say if the data
would be released to the public, but I would guess the team would tell
you what they recorded and how.
See Youtube for more videos, including one crash...:
www.youtube.com/user/OrnithopterProject
The pilot pushes out with his legs, by pulleys that draws a cable
downward on both wings, lift generated then lifts the wings back up,
repeat... very simple. They did not use arm motion as originally
planned.
Bob
Old September 24th 10, 12:48 AM posted to rec.aviation.soaring
Gary Osoba[_3_]
It is particularly, at times like this, that our late friend Paul
MacCready is missed.
He would be the first to applaud this effort, as we all do!
Best Regards,
Gary Osoba
Old September 24th 10, 02:10 AM posted to rec.aviation.soaring
Mike the Strike
I really laughed when I saw it fly. I'd always thought a human-
powered ornithopter was all but impossible and I was amazed to see it
go as well as it did. I think it might have climbed a little bit and
with a bit of tweaking and a stronger pilot it might actually be
capable of doing a figure-eight course. A remarkable achievement and
presumably on a tight budget.
Nice job!
Mike
Old September 24th 10, 02:18 AM posted to rec.aviation.soaring
Darryl Ramm
On Sep 23, 6:10*pm, Mike the Strike wrote:
I really laughed when I saw it fly. *I'd always thought a human-
go as well as it did. *I think it might have climbed a little bit and
capable of doing a figure-eight course. *A remarkable achievement and
Nice job!
Mike
Absolutely. Congratulations to the team. This is a major achievement
and I hope they do more.
But Eh I hope they passed over Molson and found some real beer to
celebrate with.
Darryl
Darryl
Old September 24th 10, 02:30 AM posted to rec.aviation.soaring
rlovinggood
Well stated, Gary!
The first time I watched the video, it appeared the glider was just
gliding down from the ground launch and making the most out of the
ground effect. But I've watched other videos on YouTube and from the
camera angle given (the tow vehicle), it sure looks like he maintains
about a constant height above the ground.
The wave amplitude is shallow, but I think it is quite elegant.
Well done, Team Canada!
Ray Lovinggood
Carrboro, North Carolina, USA
PS: Like the Smart Car for the ground launcher! :-)
PPS: Seems like they could have found a wider runway for this type of
work!
Human Powered Flight, pt 2 - Japan 12.jpg (1/1) Mitchell Holman[_2_] Aviation Photos 0 January 11th 09 01:21 PM
Human Powered Flight - Japan 08.jpg (1/1) Mitchell Holman[_2_] Aviation Photos 0 January 10th 09 01:03 PM
Human Powered Flight - Japan 06.jpg (1/1) Mitchell Holman[_2_] Aviation Photos 0 January 10th 09 01:03 PM
human powered flight patrick timony Home Built 10 September 16th 03 03:38 AM
Illusive elastic powered Ornithopter Mike Hindle Home Built 6 September 15th 03 03:32 PM
