Avro 146 G-IRJX Main Panel (combination of five pics - so not perfect)
Old September 27th 10, 02:22 PM posted to alt.binaries.pictures.aviation
Andrew B
Default Avro 146 G-IRJX Main Panel (combination of five pics - so not perfect)
Photo's taken through clear perspex type screen.
Aircraft at Manchester Runway Visitor Park.
I'm not sure that this has worked all that well but....
Andrew B (Cheshire, England)
"Heavier-than-air flying machines are impossible."
(Lord Kelvin, president Royal Society, 1895.)
Click image for larger version
Old September 27th 10, 11:36 PM posted to alt.binaries.pictures.aviation
Graham Harrison[_2_]
"Andrew B" wrote in message
om...
Was that stitched manually or did you use something like Photoshop?
Old September 27th 10, 11:41 PM posted to alt.binaries.pictures.aviation
Oviedo[_4_]
Try using a free program called autostitch.
You can download it he
http://cvlab.epfl.ch/~brown/autostitch/autostitch.html
Old September 28th 10, 01:09 AM posted to alt.binaries.pictures.aviation
Andrew B
"Graham Harrison" wrote in message
om...
A rather rough manual stitching using ACDSee 5.0 and resized with both that
and IrfanView.
There were different perspectives as my position had moved between each of
the shots.
I probably should have taken more time over both the shooting and the
manipulating.
I also have Gimp but I am still learning to use that even at its most basic
level.
Andrew B
"Oviedo" wrote in message
Thanks for that Oviedo.
It seems to work incredibly well with three of the shots but on a quick try
it didn't manage all five together.
Will it handle more than three pictures in the demo version?
I will try it again in the morning and try joining the two quick results
that I have at the moment.
Old September 28th 10, 01:44 AM posted to alt.binaries.pictures.aviation
Oviedo[_4_]
om...
try
I have been able to stitch 8 photos with it. Not sure what the limit is,
but yes, the demo version will handle more than 3.
I have found that it is not "perfect" with all my shots, but I think most of
it has to do with how much overlap there is between the photos. It does
take some practice to figure out how to take photos that will stitch
together nicely. I've found it works well if you have at least 1/4 overlap
between photos.
You can get it to stitch some photos together that at first try wouldn't
stitch by making an adjustment in the Options. In the center of the window
is a Matching Options section. Change Min dim (pixels) from 400 to either
100 or 200. I'm not sure what all the other items in options do because I
haven't found a user's guide. One thing I have found is all the photos must
be the same size.
Experiment and have fun with it. Can't beat the price!
Old September 28th 10, 06:24 PM posted to alt.binaries.pictures.aviation
Andrew B
snip
of it has to do with how much overlap there is between the photos. It
does take some practice to figure out how to take photos that will stitch
overlap between photos.
window is a Matching Options section. Change Min dim (pixels) from 400 to
either 100 or 200. I'm not sure what all the other items in options do
because I haven't found a user's guide. One thing I have found is all the
photos must be the same size.
Hey, once I reverted to the original pictures (same size) it worked for the
five without problem.
Certainly the price is right!
Thanks again.
Best instrument combination ryanglover1969[_2_] Soaring 14 September 14th 10 03:11 AM
Old pics - new scans 3 - Avro Vulcan with AGM-45 Shrike on Ascension Island prior to Black Buck sortie Dave Kearton Aviation Photos 0 January 15th 08 09:44 PM
Need pics of DC3 control panel please. Jim[_14_] Aviation Photos 3 March 7th 07 02:38 PM
Need some 407 panel pics! JP Rotorcraft 0 April 13th 06 06:33 PM
R44 panel pics SHIVER ME TIMBERS Rotorcraft 5 April 1st 05 08:39 AM
