New definition of thermal strength
Old September 30th 10, 04:45 AM posted to rec.aviation.soaring
Bob Mowry
Default New definition of thermal strength
From NPR's science guy: http://www.npr.org/blogs/krulwich/20...eighs-how-much
They use a unit of measure to define how much water is in a cloud/
thunderstorm/hurricane. At one point they use elephants/second to
describe the inflow of moisture in a thunderstorm. Quite funny.
Old September 30th 10, 05:15 AM posted to rec.aviation.soaring
Mike the Strike
On Sep 29, 8:45*pm, Bob Mowry wrote:
From NPR's science guy: *http://www.npr.org/blogs/krulwich/20...a-hurricane-we...
thunderstorm/hurricane. *At one point they use elephants/second to
describe the inflow of moisture in a thunderstorm. *Quite funny.
Given something of the order of one gram of water per cubic meter of
cloud in a decent cunim and a smallish storm cell about a kilometer
cube, then you've got around a million kilograms of water - or
somewhere about a thousand tons in American units. I use the same
argument as the NPR clip, only I measure the lift in gliders -
assuming they're 1,000 pounds each - so a small cumulonimbus weighs as
much as 2,000 gliders. Plenty of lift to go around!
Mike
Old September 30th 10, 07:51 PM posted to rec.aviation.soaring
Andy[_1_]
I heard this live yesterday. Being a Python fan I had to wonder if
they were Asian elephants or African elephants. The whole concept is
a bit hard to swallow.
Andy
Old September 30th 10, 08:10 PM posted to rec.aviation.soaring
bildan
The whole concept is a bit hard to swallow.
Andy
Yep, especially since H2O in its vapor state is a lifting gas. The
more water vapor in the air, the lighter it is. http://en.wikipedia.org/wiki/Water_vapor
Old September 30th 10, 09:56 PM posted to rec.aviation.soaring
Mike the Strike
Andy
Yep, especially since H2O in its vapor state is a lifting gas. *The
more water vapor in the air, the lighter it is. *http://en.wikipedia.org/wiki/Water_vapor
Yes, but water vapor is invisible. If you can see a cloud, it has
liquid water or ice particles.
Mike
Old October 1st 10, 02:04 AM posted to rec.aviation.soaring
JS
Is that an African swallow or a European swallow?
Bloody weather!
I heard this live yesterday. *Being a Python fan I had to wonder if
they were Asian elephants or African elephants. *The whole concept is
Andy
Old October 2nd 10, 02:59 PM posted to rec.aviation.soaring
Bloody weather!
Andy- Hide quoted text -
- Show quoted text -
The soaring season must have ended in the northern
hemisphere ....... ;-)
Old October 2nd 10, 03:22 PM posted to rec.aviation.soaring
Mike the Strike
Bloody weather!
Not in Arizona it hasn't.... check OLC USA Region 9.
Mike
Max Tow Weight and Rope Strength 150flivver Soaring 14 April 15th 09 08:53 PM
Thermal Data Files Thermal Mapping Project Australia Mal Soaring 0 December 2nd 05 11:14 PM
ILS DME strength? Jim Burns Instrument Flight Rules 10 November 2nd 05 11:10 PM
Bomber Command strength Drazen Kramaric Military Aviation 2 July 22nd 04 07:09 AM
Tubing strength Ernest Christley Home Built 0 January 16th 04 11:43 PM
