prova
Old October 12th 10, 09:44 PM posted to alt.binaries.pictures.aviation
Fabio
Default prova
Jess Lurkin ha pensato forte :
Fabio wrote in news:4cb329f5$0$23145
Content-Type: text/plain; charset="iso-8859-15"; format=flowed
Content-Transfer-Encoding: 8bit
prova
Attachment decoded: Meteor p1 08.JPG
------=mesnews_0_1011101717--
Thanks Fabio
Interesting design. from the pics you've posted
and the others found elsewhere, your pic is the
only Meteor with a rocket-assist pack. I saw a
pic with a steam catapult, and what appeared to
be some high tension spring system. As noted by
another poster, some of them had props to big for
the skid position. This pic with the RATO looks
just about right for recovery without *too much*
damage.
The
Usually from 1965 onward they used the booster assisted launch from a
short catapult. There was no skid at all so no problem for the props.
The aluminum variable pitch propellers in the last versions used to
bend when entering the water at sea. A parachute and a self inflating
device underneath the engine helped to facilitate recovery without
damage. ciao
Fabio
Old October 12th 10, 09:46 PM posted to alt.binaries.pictures.aviation
Fabio
Default prova
Nel suo scritto precedente, Jess Lurkin ha sostenuto :
prova
Attachment decoded: untitled-2.txt
Content-Type: image/jpeg; name="Meteor p1 08.JPG"
Content-Transfer-Encoding: base64
Thanks Fabio
damage.
This is one of the earliest models
ciao
Fabio
Old October 12th 10, 09:50 PM posted to alt.binaries.pictures.aviation
Fabio
Default prova
Jess Lurkin scriveva il 12/10/2010 :
prova
Thanks Fabio
damage.
here a pic of the model with the variable pitch prop
ciao
Fabio
Old October 12th 10, 11:34 PM posted to alt.binaries.pictures.aviation
John Szalay[_2_]
Default prova
"Dave Kearton" wrote in
"Fabio" wrote in message
prova
http://www.probertencyclopaedia.com/I_METEOR_P1.HTM
It's a target drone, quite fascinating. I'm curious as it has a
ventral skid, as if it could be used to land on - but the prop
clearance, even when stopped, wouldn't prevent damage on landing.
Looking at all the photoa, it my opinion that its part of the launching
cradle,or rear support, not part or the aircraft..
Old October 13th 10, 12:15 PM posted to alt.binaries.pictures.aviation
Andrew Chaplin
Default prova
Jess Lurkin NULL wrote in news:Xns9E0F986446DF5IPHIDEinuseALERT@
74.209.136.93:
prova
Thanks Fabio
damage.
I worked with drone contractors at 35mm, 40mm, Blowpipe, Javelin and
ADATS firings. All had two-bladed airscrews. The modus operandi was to
fly them until they ran out of fuel and when the prop stopped, it would
be in a horizontal position, and they would belly-land on either grass or
snow. Props were often damaged, typically when a launch went wrong, but
easily replaced.
Andrew Chaplin
SIT MIHI GLADIUS SICUT SANCTO MARTINO
(If you're going to e-mail me, you'll have to get "yourfinger." out.)
prova Fabio Aviation Photos 11 October 13th 10 07:23 PM
